  2. MRA Café
  3. Route Here Map
Route Here Map
17 Posts 7 Posters 5.7k Views 2 Watching
  • Cookie On Tourundefined Offline
    Cookie On Tour
    wrote on last edited by Cookie On Tour
    Yes, it's a different story, planning and ad-hoc navigation. I need both, but don't want to use multiple apps - but at the end I do.
    I tested the TomTom app - dismissed it, because the speed information was 88% inaccurate and the app layout/CarPlay experience was not very satisfying me.
    I used HERE WeGo, most time on my last trip, it's okay, but there are a few drawbacks, when I plan the next day route on my browser, it will not synchronize to the app. Importing GPX is having issues and not usable. So, I mostly just checked the destination point and added it as a favourite to easily find it for navigation on the mobile. (BTW - this is the same procedure, I use on MRA).
    Apple and Google Maps - well it is cumbersome to download the maps on both for offline navigation (just in case).
    As I am not a biker (anymore) just using my car with an attached tiny-camper trailer, most I need is just a pure navigation that will lead me where I want to go.
    However, when using MRA next, sometimes it's not reliable - my wife for example used MRA to get to a parking with transfer to the airport. She used it a few times and all time the system routed her differently using the same settings. Only one time it used the best and fastest and most uncomplicated route. The other times it took routes through rural and city areas, whereas there is a very close by highway exit and you just need to take two turns and you are at the parking. I mean a navigation system should be optimized for such a route. As said no changes of any setting. Not to mention, that such a navigation sometimes is time sensitive and critical. And when you end up in 30 km/h zones etc. you start to shiver and scold.
    Joerg
    (Cookie-On-Tour.de)
    • Cookie On Tourundefined Cookie On Tour
      Nick Carthewundefined Offline
      @Cookie-On-Tour To be able to navigate accurately, on the roads that you want to use, you first have to route plan accurately. Your example above does highlight a strange phenomenon in the HERE map, but by positioning an extra route point you can make the HERE map follow the same route as TT and OSM.
      It is the same for your wife travelling to the airport, with route points positioned on the roads that you want to use, the same route will be used each time you travel on it.
        Cookie On Tour
        @Nick-Carthew I agree, but as said most of the time for any pure navigation software or device, when it is used as ad-hoc navigation - not being in the position to plan the route, the outcome should be more consistent and reliable.
        While planning, sure I can add waypoints, however, this only makes sense if you know the area and the best route. Shouldn't a smart navigation system do this for you? 😉
        Joerg
        (Cookie-On-Tour.de)
        BertMundefined 1 Reply Last reply
          BertMundefined Offline
          @Cookie-On-Tour said in Route Here Map:
          I fully agree!
          Just for A to B MRA is acting strange:
          The last time I used it directed me over the Schiphol airport roads thrue the arrivals and then back to the same highway... WTF??
          Cookie On Tourundefined 1 Reply Last reply
            People call that sightseeing 😝
            MRA Lifetime Gold
            • BertMundefined BertM
              I fully agree!
              Cookie On Tour
              @BertM said in Route Here Map:
              I fully agree!
              Well the TomTom was not better as I tested it 🙂
              Joerg
              (Cookie-On-Tour.de)
                I fully agree!
                Brian McGundefined Away
                these navigation devices are nothing but statistical engines, for the same input parameters will give give the same output, there is no chaos theory involved in how they calculate routes
                if you are getting different outputs then there must be a different input,
                this could be something like traffic because we all know we want consistent routes but also want to avoid traffic which blows your consistency out of the water
                or it could just be something as simple as the time of day, one route might be faster at 9am than another route at 9:05
                • BertMundefined Offline
                  @Brian-McG
                  It is not a different input when going from A to B, it is just one simple thing:
                  I am at point A and want to point B.
                  If the program routes me off the Highway and put me back on the same Highway at the same junction that cannot be the fasted route.
                    @Brian-McG
                    @BertM, actually, depending on the routing engine, in the Netherlands it can 😉
                    Since in the Netherlands max speed on highways is 130kph but during daytime limited to 100 with signs, it can happen that on highway entrances the 100 sign is somewhere in the distance, making it lawful from the entrance to the first 100 sign the max speed is 130 during daytime. Not all highway entrances immediately have a 100kph sign, making the detour faster than staying in the highway (in theory).
                      Cookie On Tour
                      When I shift the starting point as far as I can down the route OSM and TomTom takes and switch the setting to "shortest" Here still routes "his" way
                      Shortest distance: Here 3.98km vs. 2.37 OSM/TomTom
                      Here is very bad a math!
                      Joerg
                      (Cookie-On-Tour.de)
                        @Con-Hennekens said in Route Here Map:
                        have you ever driven through the arrival section of an airport at 100 km/h???
                        Try i sometime @ Schiphol 😉
                        Nice theory, but I do not believe this is the issue
                          @BertM, I was not implying that this is your issue, but rather posting an anecdote about leaving a highway being theoretically faster, and proving this can be an issue navigation software.
                          Cookie On Tour
                          BertMundefined
                          Giuseppe Marinoundefined
                          Giuseppe Marino
                          • Carpuride scherm vast
                            De Ploey Georgesundefined
                            De Ploey Georges
                            168
                          • I just want to browse the map!
                            white.mouseundefined
                            Nick Dawsonundefined
                            Nick Dawson
                          • Three new scenic routes in southern England
                            Anonymouseundefined
                          • Move blocks of routepoints
                            Yannick_van_Vugtundefined
                            Yannick_van_Vugt
                          • Roundabout Symbol and Exit Number
                            Kirsten De Weerdundefined
                            Kirsten De Weerd
                            444
                          • Creating routes on HERE versus TomTom
                            Hans Ruttenundefined
                            Hans Rutten
