  4. MRA 5.0 - 422 RX Bibliothek - Download? - better to use the routes section on your phone? // Dowenload ? - besser unter Routen auf dem Handy ?
12 Posts 4 Posters 56 Views 2 Watching
    That being said, I think adding a "add route to my library" would be beneficial. Something like below. And the option "Add to downloads" could be removed from the download menu, making use of routes within the MRA ecosystem quite distinctive from using them outside of it.
      @Con-Hennekens said in MRA 5.0 - 422 RX Bibliothek - Download? - better to use the routes section on your phone? // Dowenload ? - besser unter Routen auf dem Handy ?:
      Or to keep it unified with the website planner + Use route
        @Nick-Carthew, Indeed, but I am gambling on that being changed too in the new version 😉
        If "+Use Route" would be used, it would also make sense to open it in the in-app planner immediately (like in the web-planner).
          @Con-Hennekens Add route to my library is very clear maybe to save space Add to library would work better?
          • Hubert Thoring
            @Con-Hennekens : @Nick-Carthew;
            Hey guys, first of all, thank you so much for your support! Using RX routes more often would be a great idea and would definitely make it more fun!
            Your ideas are exactly what will help us improve the MRA in this described application.
            Question:
            • Who actually needs the "Download" function anymore?
            • Is this perhaps an old feature that can now be removed?
              Question:
              @Hubert-Thoring said in MRA 5.0 - 422 RX Bibliothek - Download? - better to use the routes section on your phone? // Dowenload ? - besser unter Routen auf dem Handy ?:
              That has been answered in my first response to your OP:
              Downloading routes is mainly intended for distribution to non-MRA apps or dedicated navigation devices.
                • Downloading won't be removed as that's the way to get routes to your navigation device (when it's not the app). Quite heavily used looking at statistics.
                • Adding to your own library could be a nice addition but not for now
                • Syncing the entire library for offline use is undesirable
                Most users have internet anyway when they want to grab a fun route out of the library.
                If you plan a trip you will copy the routes to your account anyway as most people will adjust at least start / finish. These will then be synced anyway.
                Not going to make short term changes to this.
                A "add to my routes" (or whatever) button could make sense for not only this page but also routes from friends etc.
                  @Corjan-Meijerink said in MRA 5.0 - 422 RX Bibliothek - Download? - better to use the routes section on your phone? // Dowenload ? - besser unter Routen auf dem Handy ?:
                  @Corjan-Meijerink :
                  Yes, such an addition would be very helpful!
                  For your information: Currently, to save a route on my phone, I go to "RX Library" or "Friends Routes" and then take the detour via the "Edit" option. I don't actually change anything on the route itself, but instead, under "Route Information" - under "Description" - I write the text...
                  • Copy RX Route
                  • Copy Friends Route
                  and then save. The result is that the route is now in my own route library. 🙂
                  Best regards and keep up the good work!
                  • Hubert Thoring
                    Nachtrag zum Download: @Corjan-Meijerink ; @Con-Hennekens
                    Weil vieleicht durch die Übersetzung falsch verstandnden, es geht um dieses hier, ich meinte die eine untere Funktion hier.
                    • Zum Dowenload hinzufügen s. Bild Auschnitt 1
                    • Im Konto unter dem Menü "Download" s. Bild Ausschnitt 2
                      Wozu brauchen wir das, das habe ich noch nicht verstanden wenn man jetzt das Synkronisieren hat.
                    Addendum regarding the download:
                    Because the translation might have been misunderstood, I'm referring to this one; I meant the lower function here.
                    • Add to download (see image excerpt 1)
                    • In the account under the "Download" menu (see image excerpt 2)
                      What do we need this for? I still don't understand if we already have the synchronization feature.
                    Excerpt 1
                    Excerpt 2
                    • Hubert Thoring
                      😎 Addendum regarding saving the RX-Route: have now found in the new MRA 5.0-422 app that you can probably save a selected RX route under Edit directly after activation, this leads to the fact that it is stored under your own routes. This route is still public at the moment, and you should know that .!!
                        Marcel Versluis
                        Marcel Versluis
                        Parantapa
                        Parantapa
                        TomOnTour
                        TomOnTour
                      • Android Auto TFT
                      • Route punt overslaan
                      • Notche
                        Adriaan Vonk
                        Adriaan Vonk
