  4. Lots of small issues
3 Posts 3 Posters 1.1k Views 1 Watching
  • Martin Keenundefined Offline
    Martin Keen
    Last week we were in France heading back to the port Saturday , the weather forecast was for heavy rain and possible lightning, so I wanted to remove some of the way points to enable a more direct route. However mra kept telling me there was no Internet connection when there clearly was. Then I discovered you were doing maintenance on the site. On the way twice the screen went blank, then I am city center in the poring rain it pixilated.I gave up the and switched to waze which worked perfectly. I am also unable to use the function at the bottom of the page to go to way points etc.
    It all seems very clunky and unreliable at the moment
    • Martin Keenundefined Martin Keen
      @Martin-Keen, It is a pita that you were confronted with the maintenance message, which was really a system-outage (the first one iirc). Some explanation is done in the announcement section. I am unsure what you mean exactly by "pixilated". It is always good when something strange happens, to grab a screenshot. If you had trouble with raindrops, there is na function to lock the screen to prevent drops from messing with the app. But Waze would have suffered from the same thing I guess. I hope you will get a better second impression than your first... 😉
      • nomkoundefined Offline
        wrote on last edited by nomko
        Like you said, there were some maintenance on the website/server...
        Just an unfortunate coincidence.....
        | MRA Gold Member |
        | MRA Next + Kawasaki Z650 |
        nomkoundefined
        Martin Keen
        • Expand
          Martin Woodfordundefined
          Martin Woodford
          625
        • Tracklog fails
        • Moving the map
        • Luftlinie zwischen zwei Punkten
          Tuxiundefined
          Tuxi
        • Change Favorites icons on map
          39
          2.2k
        • Routepunt overslaan
          JP dundefined
          JP d
