New beta! 4.4.1 (406)
There is a button within the MyRoute-app settings to open the app language settings on iOS. I have now also added this in our app for Android however that's not in build 406
For now just follow these steps: https://support.google.com/android/answer/12395118?hl=en
In the next build 407 there will be a button within our app
@Corjan-Meijerink, haha, you are quick!
@Corjan-Meijerink, Thank you for that, and I hope the Alps were refreshing for you
@Hubert-Thoring They were, thanks
MRA -App 4.4.1 (406) From today the21.8.2025
The GPX export from a foreign app to MRA was just successful, in the old version 4.4.0 (404) it just didn't work yet now in 4.4.1 (406) it was successful without error message
Click for info there is also a topic
@Corjan-Meijerink The βOpen Routeβ does not appear to work for me and it was the same with the last build.
When I select βOpen Routeβ, I am taken to this screen with no whole page view of the route seen:
@Dave-J-0 I just tested this on my app. When I tap Open route the map opens on my location and because the start of my route is approximately 500m from my house, initially I did not see my route. As soon as I expanded the map I could see my route.
@Nick-Carthew @Dave-J-0 Here too. And as soon as you hit Navigate, a route is presented to the nearest waypoint on the route or the starting point (whatever your intentions are).
@Rob-Verhoeff @Nick-Carthew Yes. I am sure this used to centre on the route but happy to be corrected. That said, the route is there if I scroll around.
@Dave-J-0 @Corjan-Meijerink
That the route is then displayed directly there, regardless of the location, I mean that was really like that in the past.Would also find it better because some routes that you just want to look at are maybe very far away from the location
- Route should be displayed directly.
Tip: once briefly on the pen, and then back again saves the scrolling
VG
I have seen that issue once but never really after
I'll see if I can reproduce and fix it. -
I'll see if I can reproduce and fix it.@Corjan-Meijerink I tried opening a route from the activity feed that was 120km from me and it opened on my location.
Rob Verhoeff referenced this topic on
@Corjan-Meijerink :
May I ask what exactly this is:- UI/UX
Copy:
What's next?
We are working on a major overhaul of the UI / UX of the app. - UI/UX
@Corjan-Meijerink :
Copy:
What's next?
Hi everyone!
Long time no see. Almost 2 months since the last beta!
Besides that it might not be the best idea to release updates during peak season.Have we been working all the time? Hell no. I've been enjoying some time in the Alps too!
Enough said about that, you could not care less about my driving. You want to know what we were coding
Engine updates
We've updated the internal software of Flutter and the HERE SDK to keep up to date with the latest standards. Quite boring but definitely not unimportant.
Sometimes this causes issues for (mainly older) devices but it can also result in improvements regarding stability and battery usage. Especially the users reporting stuttering menu's in the 4.4.0 version could be very happy with this update. For you all it's just important to report any unexpected issues with the app in general.Language updates
Thanks to @Chudy and @Krzysztofa our app now supports the Polish language!
This is only the app, not the website. So if your app is in Polish, the website will probably be English (or whatever you selected).Android language select
Since day one you could already select a different app language in iOS when accessing the iOS app settings. Now that's possible for Android too!
Especially useful now we have Polish translations.Note: only Android 13 and higher
iOS GPX import issue
Since an update from iOS the GPX import function of the app was broken
That's fixed again! You can now open any GPX file sent to you with our app again.Recalculation improvements
Tweaking the recalculation behavior of the app is quite complex due to the vast variety of situations. Over the holiday we received quite some reports that the app would excessively skip waypoints. In this version we deployed a new version of the waypoint skip algorithm. Very curious what your opinion about the behavior is! Besides that we resolved an issue where sometimes recalculations in track navigation could get stuck.What's next?
We are working on a major overhaul of the UI / UX of the app. Everything will be different and beta testing for this update will last a minimum of 1 month. We hope to start beta testing early September and aim for release in October!
Cheers,
Corjan@Corjan-Meijerink said in New beta! 4.4.1 (406):
What's next?
We are working on a major overhaul of the UI / UX of the app. Everything will be different and beta testing for this update will last a minimum of 1 month. We hope to start beta testing early September and aim for release in October!I don't keep it anymore!!!
With your input, this post could be even better π
