  2. Routes & Tracks
  3. How to create a route from a track that matches the track?
9 Posts 4 Posters 3.3k Views 3 Watching
  • Martin van der Lindenundefined Offline
    How to create a route from a track that matches the actual track? And this without manually comparing and checking and adding waypoints? I thought that's why we have computers!
    • Martin van der Lindenundefined Martin van der Linden
      Reinhard-32undefined Offline
      @Martin-van-der-Linden
      Open your track and then follow the hints at the screenshots:
      Kindly regards
      Reinhard
      Montana 700i and Mac
        @Reinhard-32 This is only the first part of the track->route process...
        TS still had to "show" the original track underneath the "created" route and add or move waypoints to manually make the route equal to the track. The auto convert from route to track is never 100% accurate so one shall always perform some manual adjustments... Nevertheless, 80% of the work is done for ya this way. 😄
        Martin van der Lindenundefined 1 Reply Last reply
          @StefanHummelink Exactly my point. But I have a bunch of offroad tracks (TET trails) and then the route is not 80% accurate but 80% not accurate. And how hard can it be to just set the waypoints exactly on the track-line? No matter whether there is a tarmac road underneath!?
            Or even better, why is there no possibility to load a track on the Android/iOS MRA app and navigate that one?
              @Martin-van-der-Linden Wow, you mentioning Offroad is a game changer!
              The algorithm tries to match your track with the roads that exist in the map used, that's how navigation on a map works...😋
              Offroad is a very special aspect of the routeplanning, and I'm not sure if this type of routes/riding can be designed correctly in the maps available in MRA. Note that Offroad requires waypoints to be set to Offroad/Skip to correctly be an off-road waypoint.
              Perhaps one of the more experienced riders and MRA specialists will respond here. @Hans-van-de-Ven-MRA-Master or perhaps @Nick-Carthew? These came up in my head straight away, definitely not saying others are not as experienced. 🤣😄
                @Martin-van-der-Linden Because they are different apps with different purposes now. You need to realise that the MRA Nav app makes use of the Garmin Here map for navigation! A track may not exactly fit Garmin Here map for 100% so discrepancies are always applicable!
                Maybe this'll become an functionality in future updates of the app.
                  I think MRA would need to implement a topographical map to make possible what you want. Then the need to bind waypoints to roads would not be there anymore, and a track could be split into segments that can be routed by what Garmin explains as "Direct route", so not binded by roads. You can make your waypoints unbinded by roads like this:
                  But that is more like intended to overcome situations where the routing engine fails to see the possibility of passage.
                  I am afraid that off-road navigation will need the use of specific apps like Osmand for the foreseeable future.
                    I see, track navigation is a completely different thing from route navigation. Ijust found OsmAnd and installed it on my iPhone. It seems perfectly happy loading gpx tracks and let you navigate them. I will test it the coming weeks. Maybe MRA will be able to do so in the future too!
                      Steve Jarrellundefined
                      Steve Jarrell
                      3.2k
                    • Move blocks of routepoints
                      514
                      LennyOundefined
                      Peter Zehentreiterundefined
                      LennyOundefined
                      Reid Squierundefined
                      Reid Squier
                    • Hello guys again, please help
                      Aggelos Minoudisundefined
                      Aggelos Minoudis
                    • v5.2 (473) Feedback
                      C.A. Kielenundefined
                      C.A. Kielen
                      758
