  4. Waypoint skipping. MRA vs Beeline.
4 Posts 2 Posters 1.2k Views 2 Watching
  • Herman Veldhuizen Offline
    I have 2 videos showing how MRA and Beeline handle situations where I ignore instructions and skip shaping points (on purpose).
    The route has 2 shaping points between a start and a finish :
    https://www.myrouteapp.com/route/open/11438693
    warning. large files around 400MB each:
    MRA:
    https://drive.google.com/file/d/1MyC4n6FIF2xw1Syp7WD4xSaHoxPTeeol/view?usp=drivesdk
    Beeline:
    https://drive.google.com/file/d/1gqHwu-rZHajmVUM5C5iKiFgt3zDUaR_0/view?usp=drivesdk
    I would like to use MRA but cannot. Its the Beeline behaviour related to skipping which I am missing. I have tried multiple combinations of options but cannot get the skipping to work. In this example MRA tries to send me back 7 times to the missed point. During this time I might miss instructions to navigate to the next point and I am without the ETA info to that next point. On highways this can be a long time.
    When I ignore multiple instructions to leave the main road I have decided to skip a shaping point and don't really want to touch the screen to skip the point point manually. In fact I am not allowed in my job. According to the in-app documentation the Beeline type of behaviour should be possible and I think that it has worked like that in the past for me.
    I hope the team will make this possible one day, not necessarily as the default but as a possible type of behavior.
    Interesting also is the warning from Beeline for being off-route at around 3 minutes into the video.
    • Rob Verhoeff Online
      Rob Verhoeff Online
      Which version of the app are you currently using? Right now, version 4.4.0 (build 403) is being tested in beta. The current skipping algorithm has been designed with slightly more conservative behavior when it comes to skipping shaping points. It’s quite possible that points 2 and 3 in your sample route are just a bit too borderline for the algorithm (perhaps even unintentionally!).
      In my experience, MRA behaves more like in the Beeline example video you posted. I haven’t seen the behavior from the first video recently. I don’t find it strange—just interesting 😉.
        @Rob-Verhoeff Using 4.3.9 -395 which is the latest official as far as I know.
          Rob Verhoeff Online
          Rob Verhoeff Online
          @Herman-Veldhuizen yes, correct.
          • Herman Veldhuizen Herman Veldhuizen referenced this topic on
            25
            59
            19.6k
          • Offline Navigation
          • Update 5.2.2 - Quick fix
            ginogino
            ginogino
            1.7k
            Don Stauffer
            Don Stauffer
            584
          • MRA V2.2.2 (489) with Remotek One V2.1.0 – functions have been adapted /// mit Remotek One V2.1.0 - Funktionen sind angepasst
          • status quo: progress regarding map spinning resolvement
            peha
            peha
          • opslaan naar plantomtom
