  4. reverse the path after reaching the destination
2 Posts 2 Posters 950 Views 2 Watching
  • Albyus
    Albyus
    Albyus
    Hi everyone, I created a route from point A to point B. If once I get to point B I want to go back to point A using the same route I set previously, how do I do it on the app? TNX Alberto
    • Rob Verhoeff
      There are two ways to do this. You can do it via the Toolkit menu in the web planner or by using the app. Since you mentioned wanting to reverse the route upon arrival, open the route. Click on the pencil icon, then click on Menu and choose the 'Reverse route' option.
      Do keep in mind that you might end up with a somewhat odd route. Waypoints placed on roads with separated carriageways always cause issues or require adjustments. The software isn’t clever enough to automatically place the waypoint on the correct side of the carriageway for the return journey.
      Albyus
      Albyus
        Andy Nicholson
        Andy Nicholson
      • MRA 6.0.0 (532) Display schaltet um auf Standby?
        Jack 13
        Jack 13
      • Event attendees
        cerfskysky.com
        cerfskysky.com
      • Live connection with EV
      • Route uploaden
        Johan 5q
        Johan 5q
      • Track colors by section.
        Òscar
        Òscar
