  4. Undesirable routing!
7 Posts 5 Posters 1.9k Views 1 Watching
  • stuart marrittundefined Offline
    stuart marritt
    Hi All,
    Yesterday when I was out on the bike I did a route from the location I was at to home
    This was done by searching my home address and changing the options to give me a twisty/adventurous route
    I haven't used the navigation much and always just had it as a back up incase my Zumo XT gave up but I have recently thought I would give it a try
    One thing I noticed is that if I missed a turn it was trying to reroute me back to the route which is fine but what is not OK is that at one point I missed a turned but then it was trying to take me down the next road to then turn around and come back down the same road to join the same road I was on! see the image attached
    This should have continued straight until i met the route again and not tried to take me down the same road twice
    There was no waypoints or shaping points along the route just a straight get me home in a twisty fashion
    Is there a setting to change to stop this happening? I have looked but can't see anything
    Thanks
    Stu
    Con Hennekensundefined Luk4s7undefined 2 Replies Last reply
    • stuart marrittundefined stuart marritt
      Hi All,
      Thanks
      Stu
      @stuart-marritt, I am not so sure that it should. Sometimes people just turn around, and then will be lead to that same point again. That is not a possibility when it skips ahead like you propose. Of course you can go straight ahead like you propose, and you will see that the route will pick that up after a short while.
      stuart marrittundefined 1 Reply Last reply
        Hi All,
        Thanks
        Stu
        Luk4s7undefined Offline
        Luk4s7
        wrote on last edited by Luk4s7
        @stuart-marritt I noticed similar problem. See attached screenshot - why left? I set curvy route to the destination. I’m missed one or two turns, checked some side roads etc. expecting it will reroute and navigate to the point.
        Later on forced me to turn around to that point. I did not set any via points - only set destination.
          stuart marritt
          @Con-Hennekens said in Undesirable routing!:
          But without zooming out you won't see what is happening and just follow the instructions then be turned around! It's a pointless exercise
          • Luk4s7undefined Luk4s7
            stuart marritt
            @Luk4s7 said in Undesirable routing!:
            Yes that's exactly what happened to me I only managed to get one screenshot but it was always trying to route me back!
            If I have a route with no waypoints and I have missed the turn then just route to the next available joining point without going back on yourself
            siebo vd bergundefined 1 Reply Last reply
              siebo vd bergundefined Offline
              siebo vd berg
              wrote on last edited by siebo vd berg
              Hallo mensen bij mra,
              Hier hetzelfde probleem.
              Een route gemaakt, een paar tussenpunten gemaakt. Door een afsluiting een punt moeten omzeilen.
              De navigatie blijft mij terug sturen naar dat punt. De vervolg route is dan wel zichtbaar als lichte lijn maar de donkere lijn is telkens weer terug, hij pakt hem dan niet meer op. Bij elke afslag moet ik dan weer omkeren volgens de dame.
              Vreselijk irritant. Ook in beeld geen mogelijkheid om het over te slaan.
              Ik rij met android auto maar ook op de telefoon hetzelfde.
              Route geopend met de bmw app en ik kan hem weer gewoon verder rijden. Maar dan op de telefoon, bmw app heeft geen AA.
              Ik probeer de route bij te voegen maar dat wil niet.
              M v gr Siebo.
              <iframe style="border:none;overflow:hidden" width="600" height="286" scrolling="no" frameborder="0" src="https://www.myrouteapp.com//embed/route/10992117?lang=nl"></iframe>
              Dit zou de route moeten zijn.
              Leike Lodiersundefined 1 Reply Last reply
              • siebo vd bergundefined siebo vd berg
                M v gr Siebo.
                Leike Lodiersundefined Offline
                wrote on last edited by Leike Lodiers
                @siebo-vd-berg Route even op public zetten en dan de link in je webbrowser kopiëren en hier als link plakken.
                Je hebt wel veel waypoint niet op de weg geplaatst maar een stuk ernaast. Deze altijd even goed op de weg plaatsen. Hierdoor krijg je ook dat hij je wil terug sturen omdat hij het punt gemist heeft. En zet je begin punt altijd iets verder weg dan je orginele startpunt. Dan heeft de navi tijd om je goed op naar je eerste punt te begeleiden
                Set the route to public and then copy the link in your web browser and paste it here as a link.
                You have placed many waypoints not on the road but a piece next to it. Always place these well on the road. This also gives you that he wants to send you back because he missed the point. And always set your starting point a little further away than your original starting point. Then the navi has time to guide you well to your first point
                stuart marritt
                siebo vd berg
                Luk4s7undefined
                Luk4s7
                  Steve Jarrellundefined
                  Steve Jarrell
                  3.5k
                  216
                  John S Parryundefined
                  972
                • Updated beta! 5.2.1 (486)
                  pehaundefined
                  peha
                  470
                • Move blocks of routepoints
                  Yannick_van_Vugtundefined
                  Yannick_van_Vugt
                  599
                • Offline Track Navigation - Path Errors with Large Distance Between Points
