  4. How to insert fuel stops coffee stops and places of interest when planning a route
9 Posts 5 Posters 1.9k Views 1 Watching
  • roland reayundefined Offline
    roland reay
    Good afternoon ladies and gentlemen,ime after some information regarding how to set coffees stops fuel stops and points of interest when planning a route.When I plan a route and try to insert a coffee stop etc when I ride the route nothing is in place,no instructions showing on the route.If some one could instruct how to rectify this I would appreciate it thankyou
    BertMundefined richard 3vundefined 2 Replies Last reply
    • roland reayundefined roland reay
      BertMundefined Offline
      @roland-reay
      tap on the button left from the route point
      or
      tap the yellow button on the pop-up. Pauze time can be edited on the black button
        richard 3vundefined Offline
        richard 3v
        @roland-reay
        My solution would be to make these Via points instead of merely Shaping points. These will then be announced.
        • richard 3vundefined richard 3v
          @roland-reay
          @richard-3v, shapingpoints can also be announced.
          richard 3vundefined 1 Reply Last reply
            richard 3v
            Hi, yes I know shaping points can also be announced, but MY personnal settings are only Via points are announced. Hence my reponse.
              @richard-3v, Sure, but the ONLY purpose of VIA points is that they will not be skipped by the autoskip algorithm. There is no harm in shaping points being announced. Addresses (anything with numeric numbers in it) will not be spoken. I'd rather not give up normal functioning of the skipping algorithm in order for a waypoint name to be spoken. I'd hate seeing people asking help here for their waypoint not being autoskipped when there is name to be spoken. 😉
              • paul69undefined Offline
                hi @roland-reay
                perhaps i am mistaken, but i think you require certain points to be changed to a viapoint, if this is the case then that action can be taken by clicking the 3 dots which will expand the info box, and there on the bottom row, is the icon to swap between via and shaping.
                hope this helps
                quick amendment, once swapped to via points, this can then be changed in the app settings menu to only announce via points,
                K1600 GTL
                Oukitel RT3
                iPhone 13 Pro, carpuride 702b
                BertMundefined 1 Reply Last reply
                • paul69undefined paul69
                  hi @roland-reay
                  hope this helps
                  I do not understand why someone would only use Via points.
                  This means I always have to adress and "Hit" the Via point.
                  If it is mandantory I understand, but if it for example it is a viewpoint I would use a shaping point, as sometimes I do not want to stop at all the points of interest in a route.
                  • BertMundefined BertM
                    @BertM said in How to insert fuel stops coffee stops and places of interest when planning a route:
                    hi @BertM
                    if you are referring to that small route of mine, i understand your confusion. i know the route above shows all via's but this was not finished i was merely using it as an example for the OP.
                    when i make a route i do not us via points at all, save for start and finish obviously.
                    personally, i find via points a pain in the a*%e, hence why I never use them, however, it is nice to have the option, for those who do use them, which is a major plus point for MRA.
                    K1600 GTL
                    Oukitel RT3
                    paul69undefined
                    BertMundefined
                    roland reay
                    richard 3vundefined
                    richard 3v
                      Marcel Prinsen 0 0undefined
                      Marcel Prinsen 0 0
                    • Route Rx bibliotheek overzetten naar Garmin
                      nomkoundefined
                    • Compass with direction
                      Dave J 0undefined
                    • Mixed mode route
                      Travellexxieundefined
                    • Update/Viapoint announcements
                      Lluis Arasanzundefined
                    • Kleur van de rit veranderen.
                      Mister Bundefined
                      Mister B
                    • Ik krijg bij Scenic de vermijdopties (In mijn geval: Snelwegen, Steden en Woonwijken) niet uitgeschakeld.
                      Cock van Santenundefined
                      Cock van Santen
                    • Input Settings, Turned off v Standard
