  4. Skyline OS IFCU Harley
2 Posts 2 Posters 926 Views 2 Watching
  • Stöbe13
    Stöbe13
    Stöbe13
    Beim importieren einer Route per USB Stick in das IFCU, werden leider keine Wegpunkte übernommen.
    habe es mit gpx 1.1 und HD Boom Box versucht.
    Hat jemand Erfahrung mit diesem IFCU/Skyline System?
    Besten Dank, für eure Hilfe.
    • Rob Lindsay
      Rob Lindsay
      Rob Lindsay
      Hello, I just took delivery of my 2025 Road Glide CVO. I have just discovered the same problem! I'm sorry I don't speak German, and used Google translate!
      It looks like the Skyline OS is designed to work with the HD planning tool (available free on thier website). This tool generates routes using milestones and destinations. These approximate to MRA 2shaping points" and 2Via points". My next step is to create a route with more via points, to see if that translates successfully through the GPX 1.1 or BoomBox output, and is correctly interpreted by the Skyline OS.
      I see you posted this in April, so hopefully you have made progress? The alternative is to use MRA Navigation through the CarPlay function.
      Rob Lindsay
      Rob Lindsay
      Stöbe13
      Stöbe13
      • Bollard trouble
      • Testroute segmenten
        Alderweireld Rudi 0
        Alderweireld Rudi 0
      • Minimap
        LE DIZES Freddy
        LE DIZES Freddy
        Erdna
        Erdna
      • Map movement
