Avoid Menu
Website Route Lab, in the Avoid menu for a route, what is the ‘Used roads’ function? Other options are self explanatory but not that one?
@Big-Al-1 I assume , roads that have already been used should not be used a second time, e.g. when returning.
@Big-Al-1 Here did you find that option, not in the tolkt I guess
@Marinus-van-Deudekom You will find it when you choose TomTom under avoidance.
@Big-Al-1 Therese setting can be found in the Toolkit options.
@Peter-Zehentreiter Just tested it Peter - you are correct…..again. Thank you for the reply
@Peter-Zehentreiter that's why I don't notice it. Most of the time 99% I use the Here map because the app uses that also.
I guess it's a TomTom thing and I only know the basics of that system -
I guess it's a TomTom thing and I only know the basics of that system@Marinus-van-Deudekom I also use Here Maps most of the time, but it depends on what I want to achieve when planning a route.
Therefore, depending on my needs, I sometimes use OSM or TomTom, as they offer different planning options and calculate the route differently.
Once I'm finished planning, I convert the route to Here and can then follow my Route with the MRA app and Here Maps. -
Once I'm finished planning, I convert the route to Here and can then follow my Route with the MRA app and Here Maps.@Peter-Zehentreiter same here that is I rarely use the TomTom card and its possibility to plan a bizar curvy route After that I make shure its converted to the Here card for navigation
