  4. Shaping point not skipped
7 Posts 3 Posters 1.3k Views 3 Watching
  • Herman Veldhuizenundefined Offline
    https://www.myrouteapp.com/route/open/10824858
    Using App version 4.3.8
    Using all waypoints, skip waypoints automaticly, No automatic recalculation, navigate route as track.
    Today the shaping points in this route were not skipped. It looked like the app was treating the points as via points. It started already at point 2. I did stay on the main road as I had nobody to drop off at point 2 which is just off the main road. The app tried to send me back to point 2 for multiple times. Same problem at the following points.
    This is a serious issue for me. It used to work and it maybe still does for other routes. This route I drove for the first time. Luckily the road was easy to find and the view was magnificent and I could ignore the audio instructions.
    • Herman Veldhuizenundefined Herman Veldhuizen
      @Herman-Veldhuizen said in Shaping point not skipped:
      This sounds like you are NOT driving in "route as track" mode. It then takes about 3 recalculations to skip a waypoint.
      Herman Veldhuizenundefined M. Schrijverundefined 2 Replies Last reply
        @Con-Hennekens I agree but the setting was that I was navigating as a track. See picture below. I suspect that the app is not always using the setting as it should.
        Herman Veldhuizenundefined 1 Reply Last reply
          @Herman-Veldhuizen The only thing I can think off what I did different is that for this route I have used both the route planner in the app and the planner on the web to edit and move points. Usually I just import routes from an xml file.
            @Herman-Veldhuizen It happened again today. This time I was able to get screen dump of the settings during navigation and the log on arrival at the destination.
            I added a shaping point (7) called 'to be skipped' before starting the navigation specifically for testing . There is definitely something broken. No white line (planned track) becomes visible after I decided to stay on the main road (skipping the point). After passing the point the tries to send be back to that point.
            The route
            https://www.myrouteapp.com/route/open/10819850
            I can email the MRA log.
              M. Schrijverundefined Offline
              Even in Route-as-Tracks it takes 3 recalculations before a point is skipped.
              That is not no good enough.
              If you use Route-as-Track and you are getting (back) on the track. The track should immediately pick up without any recalculations.
              Besides this. The recalculation should not only be based on the amount of recalculations but also on how long (time) you are back on track/route.
              Example.
              Let say you are back on your route/track for 15 sec but there has only been 1 recalculation. The shaping point should be skipped. Because you were given time enough to decide what to do. And you choose just follow the route in the right direction and skip the missed shaping point(s).
              As i experienced more than once. 3 recalculations can easily takes multiple kilometers to be executed. That is far to long.
              The thing also is that the 3 recalculations is used for every missed shaping point. If you were forced into a detour and because of this, you missed 3 shaping points. You need to wait for 9 recalucations before the missed points were skipped. In this time there is large change you'll pass new shaping points but MRA is still busy with the missed ones. The passed ones will be placed in list of missed shaping points also.
              You get the idea of this problem.
                Example.
                @M-Schrijver It didn't recalculate on my other routes (I have the setting to automatically recalculate set to off). Maybe the shaping point is closer to the main road than the points I had on previous routes.
                I totally agree that the app should not recalculate (with the recalculation set to off). When I have ignored instructions to drive a planned route then I can have made a conscious decision to do so and expect the app to be silent about the missed point(s), a non intrusive warning that I am deviating from the planned route would be fine. And as soon as I am back on the planned route the App should just forget about the point(s) which I skipped. Indeed when the app tries to send me back to the skipped point I miss the instructions to navigate to the next point.
                Eventually I hope that this behaviour can also be the behaviour for via points (when navigation a route as track) but that's for another time.
                  Peter Zehentreiterundefined
                  9.2k
                • Hi everyone!
                  TomOnTourundefined
                  TomOnTour
                • Improve Menu Font Size and Readability
                  44
                  948
                • Vrij rijden
                  Rob Verhoeffundefined
                • How to reverse route?
                  Lex.Kloet.RXundefined
                  Lex.Kloet.RX
                • Franse Alpen route
                  Lex.Kloet.RX
                  73
