  2. Routes & Tracks
  3. Export to BMW Nav V
Export to BMW Nav V
12 Posts 5 Posters 1.2k Views 3 Watching
  • Mike Evans 1undefined Offline
    Mike Evans 1
    New here, investigating alternatives to Basecamp.
    I created a test route, my first route in MRA. I created a start and end point with a basic plan. I noticed I cannot drag a route. Does that functionality come if I upgrade? And if I can drag a route does it place a waypoint/shaping point that would replicate in the Nav V?
    Thanks.
    Nick Carthewundefined Mzokkundefined 2 Replies Last reply
    • Mike Evans 1undefined Mike Evans 1
      Thanks.
      Nick Carthewundefined Offline
      @Mike-Evans-1 said in Export to BMW Nav V:
      Thanks.
      Hi and welcome. Your basic account should also be able to do this:
      If you hover your mouse cursor over the route line until you see the black ball, you can then click and drag the route line to a new location, this will add a shaping point at the new location.
      Yes, shaping points and via points can be exported to your device.
        Thanks.
        Mzokkundefined Offline
        @Mike-Evans-1 You download the route as GPX1.1 to get the Via points and shaping points. GPX 1.2 downloads an exact route/track of the MRA route but it will re-calculate the whole route if you go off route and have autorecalculation turned on. I have a Garmin XT and use GPX1.1 others have good reasons to use GPX1.2
        • Aiello antoninoundefined Offline
          I have never used gpx 1.2, a question, zumo xt with recalculation disabled, if I jump to the next waypoint, does this take me to the end of the route or does it actually go to the next waypoint?
          • Aiello antoninoundefined Aiello antonino
            @Aiello-antonino no if you go off route with recalculation turned off the Zumo goes silent and will only start giving directions again if you find your way back to the magenta line.
            Aiello antoninoundefined 1 Reply Last reply
            • Mzokkundefined Mzokk
              @Mzokk but if I tell you to skip a waypoint, how does he behave?
                @Aiello-antonino as far as I'm aware the waypoint disappears as if it didn't exist, but the route stays as it is. Not sure though as I don't think I've tried.
                  Mike Evans 1
                  Thanks all. I have bought Gold membership to try it out, my research indicates this or Kurviger are the best options.
                  I am trialling a route and have worked out how to drag it as I would in Basecamp. It seems to insert these as the MRA equivalent of Basecamp's shaping points. However, when I transfer the route to my Nav, the shaping points appear as way points in the Nav, not as shaping points.
                  Am I doing something wrong?
                  Mzokkundefined Neil Whiteundefined 3 Replies Last reply
                    @Mike-Evans-1 the inverted teardrop points are shaping points and the Hand points are via points. If you export the route to your Garmin as GPX 1.1 the shaping points should appear as blue dots and the waypoints as flags.
                      @Mike-Evans-1 This is what it looks like on the overview screen of my old Zumo 390
                      and my Zumo XT
                        Mike Evans 1
                        Thanks for the clarification. That has helped.
                        There seems to be slightly different behaviour in export between Garmin GPX 1.1 and BMW Motorbike GPX1.1.
                        I think I was getting all points as equivalent of Garmin's waypoints exporting as BMW 1.1. But exporting as Garmin 1.1 it exported as I would expect. I.e. the Waypoints and shaping points as expected in my Nav V.
                        What is the actual difference between the two export scenarios?
                          Neil Whiteundefined Offline
                          Neil White
                          @Mike-Evans-1 Mike like you I am or now was a Basecamp user and very proficient in the use of it. I've had MRA for 2-3 years but only used it as a backup for the garmin satnav... This week and seeing as the Zumo XT2 isn't officially supported in Basecamp I thought I'd have a delve into MRA. I must admit it really is an excellent piece of kit and will definitely be my go to. Basecamp will be assigned to the digital cemetry in the sky..
                          Mzokkundefined
                          Neil Whiteundefined
                          Neil White
                          Mike Evans 1
                          • Feature Request | Optimize route based on time or distance
                            Alex redsundefined
                            Alex reds
                          • use pause time when you navigate the route
                          • When adding pauze in a route, it doesn't get calculated in the app
                            Alex 79undefined
                            Alex 79
                          • Feature request for MRA Navigation app: detour (for next x km)
                            Lex.Kloet.RXundefined
                            Lex.Kloet.RX
                            835
