  3. MRA Navigation Next recent learnings
9 Posts 6 Posters 3.2k Views 3 Watching
  • David Rudgley
    David Rudgley
    David Rudgley
    Hi, I followed a route as a track on Sat and it all worked very well on my Phone App. A couple of issues which caused slight confusion;
    1. Somehow I never passed WP 1 which was checked beforehand as being on the route. As the first WP is a via point it was trying to send me back to the start. I simply pulled over safely and skipped WP1 before going on my way. NEVER try to do this while riding, and don't think it will auto skip because Via points will never be auto skipped.
    2. Make sure your off line maps are up to date before you ride, I stopped the route halfway through and needed to restart again only to discover that I didn't have a phone signal. Thankfully the app switched to off-line mode and I was able restart again and skip to next shaping point. My learning here was; don't stop the route then you'll be able to continue where you left off.
    3. Be aware of your waypoints and in normal circumstances when you pass them you proceed to the next one. If your WP is slightly off the route for whatever reason the App will suddenly want you to turn around... be patient the Auto Skip should correct this. For me this happened not at the next waypoint but at the one after that. If all else fails, pull over safely and skip to the next WP along the route.
    My other learnings were, don't panic, if the app isn't behaving for whatever reason, pull over, take the time to get things corrected and back on track.
    Issues 1 & 2 above were probably due to my planning mistakes. i.e. WP's not quite on the route, easy to blame the app for my mistakes!!!
    Credit to the MRA team for the continued improvements to the app
    Android Pixel 9 Pro XL
    TomTomGo as backup
    KTM 1290 Super Adventure S
    Quad Lock + Phone +Carpuride W702
    KTM 790 Duke
    Quad Lock + Phone
    • David Rudgley David Rudgley
      @David-Rudgley WP1 should not be exactly where you start your route (for example, in front of your garage). Put it somewhere at around 300 meters in the direction your route is supposed to take so you will pass through the WP.
      Also when planning a route, zoom in and make sure the waypoints are on road (and on the correct side of the road !)
      Adrian
      Stanisław David Rudgley 2 Replies Last reply
      • Adrian Avram Adrian Avram
        Stanisław
        Stanisław
        Stanisław
        @Adrian-Avram WP1 could be skipped automatically every time I start the route and the point is less than XX meters from my position. I have this problem quite often and usually I skip it manually before starting the trip.
        Staszek
          David Rudgley
          David Rudgley
          David Rudgley
          @Adrian-Avram I did exactly that, positioned it away from the start along the intended route. I have no idea why it never ticked off WP1Screenshot 2025-03-25 150331.jpg
          TomTomGo as backup
          KTM 790 Duke
          Quad Lock + Phone
          • Stanisław Stanisław
            @Stanisław said in MRA Navigation Next recent learnings:
            The problem with WP1 is that it is a VIA point, and they do NOT get automatically skipped. Often WP1 is the start from a route somewhere at a meeting point, therefore we don't want it to be able to skip automatically. If you insist om placing it on your doorstep (funny thing is that many people consider that a privacy violation anyway) skipping it manually before take off is the right action.
            Stanisław 1 Reply Last reply
              Stanisław
              Stanisław
              Stanisław
              @Con-Hennekens I know that is is not skipped automatically, my intention was to treat it as a special kind of via point that is skipped by default (maybe as an individual setting). Anyway it is not a big problem when you have a possibility to skip it manually by riding, some of us can not do it without stopping and taking gloves off.
              Staszek
                @Stanisław sometimes if wp1 is close to me, I'll skip it before i leave just to make sure.
                BFG 1 Reply Last reply
                  BFG
                  BFG
                  BFG
                  wrote on last edited by BFG
                  I encountered this early on, and it's also relevant when exporting from the planner to a .itn file.
                  When planning a route, the actual start point is essential for understanding route duration. So whether your doorstep or a meet point for a group, the information is needed for the person and for the route planner. Omitting the start point is inconvenient.
                  The workaround is to make a nearby point.
                  Making that user wisdom into a feature would be welcome.
                  E.g Start point being distinct from WP, and not part of turn-by-turn navigation.
                  • BFG BFG
                    @BFG not sure how that would work if riders used MRA Navigation to direct them to the meeting point ... ie VP1
                    David Rudgley
                    David Rudgley
                    Stanisław
                    Stanisław
                    BFG
                    BFG
                      42
                    • Live tracking
                      202
                    • screen
                    • Routenplaner on iPad
                    • Rondrit generator ervaring
