music volume different
Hello,
I have the following setup: iPhone with Cardo PackTalk.
Is there a way to set the volume of the music and the driving instructions differently? It would be important for me to have the driving instructions louder than the music.Best regards, Heinrich
Hello,
@Sanktjohanser Samsung has Sound Assistant where you can set individual volumes for different apps. As far as I know there is no alternative app for iPhone.
@Adrian-Avram
I just noticed that when using an Android phone with the Cardo PackTalk, the music is completely muted when a voice command is given through MyRoute.
Can this also be implemented on an iPhone? -
hi for information, i use an iphone and a packtalk NEO, when the MRA announces instructions, my music turns off, this can also be visualised on the carpuride screen. as when the MRA announces, the music "play" icon shows and not the "pause" icon. obviously as you will be aware the pause icon shows when music is playing
i have not set it up this way, it seems to be default, not much help I know but at least you know it can be done.
@paul69
Hi paul69,
That sounds great.
There are two ways to pair your smartphone with the Carpuride. One is from the phone to the Carpuride and then from the Carpuride to the headset. The second is to have the audio stream go directly from the phone to the headset.
How is your pairing? (The Carpuride pairing status is always briefly displayed when you turn it on.) -
Hello,
@Sanktjohanser This is a wish I shared here a long time ago. Unfortunately not (yet) possible with the iPhone.
@paul69
Hi paul69,
That sounds great.
How is your pairing? (The Carpuride pairing status is always briefly displayed when you turn it on.)@Sanktjohanser said in music volume different:
i use the set up in the screen shot below, the one on the right, Iplay/Auto
i have tried the other one but find the voice instructions to Cardo work better with the iplay, in my experience anyway.
Also too add, i do not have the cardo app and have not changed any settings in the carpuride -
Also too add, i do not have the cardo app and have not changed any settings in the carpuride@paul69
Thank you very much
