  3. [App-Beta] Announcements
  4. New beta! 4.3.7 (384)
25 Posts 8 Posters 370 Views 5 Watching
  • Dave J 0 Dave J 0
    @Corjan-Meijerink Just done a bit more testing and the following allow drag pan on screen (even when in active navigation): Google Maps, TomTom Go and Guru Maps.
    @Dave-J-0 well, I know they allow it.
    We just can’t due to limitations within the SDK πŸ˜‰
    Not too bad as since day one CarPlay has the button that supports panning the map. I’d like to allow dragging but that’s up to HERE πŸ™‚
    Dave J 0 1 Reply Last reply
      @Corjan-Meijerink oh ok. Understand. πŸ‘
      iPhone 18 Pro
      Google Pixel 6 Pro
      • Dave J 0 Dave J 0
        @Dave-J-0 thanks πŸ˜ƒ
        • Peter Greenacres
          Peter Greenacres
          Peter Greenacres
          I really hope you get there quickly Corjan. In my humble experience MRA Navigation has significantly improved since launch, but even with the last big update on track navigation it's still too buggy to trust 100%. For reference, I use DMD2 as my primary navigation, routes planned in MRA. The export track only function has worked flawlessly to date
          My riding buddies are starting to use MRA as it's a much cheaper investment than the full DMD2 ecosystem and it's a pain in the arse when there's discrepancies between DMD2 Track (planned and exported in MRA) and MRA track navigation (tracks I've sent them).
          The familiar:
          "Mine says turn left and mine says turn right !!!
          I really look forward to the day when MRA track navigation means track navigation and not some hybrid solution. If there's a need to deviate from the track eg road closure, then fine, tell me, warn me, deviate me BUT get me back to the nearest point on the track ASAP because that's what I planned in MRA
          Keep up the great work!
          • Peter Greenacres Peter Greenacres
            The familiar:
            @Peter-Greenacres then I do recommend testing this version! Active navigation while keeping to all rules and fully sticking to the track is hard.
            The scenario you describe now is how it should be in the app.
            Peter Greenacres 1 Reply Last reply
              Still waiting for the update in the Android Playstore! Hope it will there be somewhere today! Improvements look great to me.
                Hi all! πŸ‘‹
                A new beta has arrived for iOS and is coming for Android.
                Track navigation improvements
                A lot could go wrong when navigating a track. Either from your own library or a generated scenic route / roundtrip. No real images to add for this but rest assured that the stability of track navigation has been improved a lot! πŸ˜ƒ No more unexpected detours, no more recalculations straight to the finish and no more frustration. Initial results are very positive but more of my time will be dedicated in finetuning the track navigation.
                CarPlay changes
                Zoom buttons are available on screen!
                While navigating, they are hidden under a submenu to preserve space for future buttons πŸ™‚ When entering the zoom interface, the topdown mode is enabled and you can change the zoom level. After closing that menu, the last used camera modus before entering the zoom interface is used again πŸŽ‰
                Android Auto
                Same as for CarPlay! πŸŽ‰
                Besides that however another nice feature is added! You can now pan the map 😏
                When you have a touchscreen, simply drag the screen.
                If you do not have a touchscreen, a button will appear to enable the pan interface.
                Note: dragging the map is not supported on CarPlay
                Other changes
                • Fullscreen mode is now a preference (Navigation settings > screen layout)
                • Improved zoom limits in CarPlay / Android Auto (sometimes you were zoomed in way too much)
                • Updated HERE and Flutter SDK
                Have a nice weekend!
                Cheers,
                Corjan
                @Corjan-Meijerink : Thank you πŸ™
                  @white-mouse it should be available! Could you check in the Play Store?
                  a white mouse on the motorbike Marinus van Deudekom 2 Replies Last reply
                    Peter Greenacres
                    Peter Greenacres
                    Peter Greenacres
                    @Corjan-Meijerink thank you for your reply. I tested the updated beta today. All good until I deliberately went off track. MRA asked to recalculate, when i confirmed MRA tried to take me back to the point where i left the track, even when i re joined the track further along. Is this deliberate or do i need to adjust something in settings?
                    Ideally, if I deviate from the track I want to get back on the track at the nearest point without stopping the motorcycle
                    Thank you
                      Thank you
                      @Peter-Greenacres If you have "skip waypoints" turned off, that makes sense. Otherwise it should start taking you to nearest point on the track after a bit. Normally that should be immediately but kinda depends on some factors.
                        @Corjan-Meijerink I navigated a track today over some 200 miles and the new version performed really well. When I deviated from the track, I was given a very quick route back to track and this kept updating. Worked really well for me with no problems
                        iPhone 18 Pro
                        Google Pixel 6 Pro
                        • Dave J 0 Dave J 0
                          @Dave-J-0 cool! πŸ˜ƒ
                            #17
                            @Corjan-Meijerink Yes. Now it's available. And the update looks great.
                            Going to try it on Tuesday!
                            Once again you all did a good job.
                              @Corjan-Meijerink it is on 5he Google playstore
                              • CD130
                                Thanks for the update and all the energy that has been put back into it. Also look forward to the complete rework of the home screen of the app. Is this update still expected in March?
                                The adventure starts where the plans end | READY TO >> RACE 🧑
                                • CD130 CD130
                                  @CD130 First Alpha version is definitely expected in March.
                                  Beta maybe end of the month.
                                  Public release is very unknown as there is also a contractual / license part involved with our supplier.
                                  CD130 1 Reply Last reply
                                    @Corjan-Meijerink Oh, more difficult than expected? Good luck with this puzzle 😬
                                    • Dave J 0
                                      @Corjan-Meijerink With this and the previous version with the new CarPlay zoom functions, I have regularly encountered a problem with the β€˜Zoom’ button allowing me to select a zoom level in Top Down view but then not returning to the previous dynamic view that I have selected on CarPlay. I find that I have to complete a whole cycle of view changes on my iPhone before this function works as stated. After this cycle of views on my iPhone, I do not have anymore issues with the zoom function for the reminder of the ride.
                                      Some limited testing appears to show that I encounter this problem if I start the route on the iPhone and/or have the app open on the iPhone before connecting to CarPlay. If I open the route only through CarPlay, then the problem does not appear to happen. I need to do some more testing but I have just done a total reinstall of the new version just in case. More testing to be done.
                                      iPhone 18 Pro
                                      Google Pixel 6 Pro
                                      • Dave J 0 Dave J 0
                                        @Corjan-Meijerink Done some more testing and the problem for me happens all the time if I have the app open with a navigation session initiated or the app has not been opened and not running in the background. If the app is active in the background with no navigation, then I do not have the problem with the Zoom initiation button not returning to the original selected view (from top down with manual zoom).
                                        iPhone 18 Pro
                                        Google Pixel 6 Pro
                                        • Dave J 0 Dave J 0
                                          @Dave-J-0 Sorry, I've tested the behavior and I cannot understand what is going wrong. I do not seem to be able to reproduce the issue you are having.
                                          Could you contact me through support including a video of the issue?
                                          I am more than eager to fix it but I currently am not able to understand what exactly is going wrong.
                                          Peter Greenacres
                                          Peter Greenacres
                                          • Testroute segmenten
                                          • Bollard trouble
                                          • Minimap
                                            LE DIZES Freddy
                                            LE DIZES Freddy
                                            Erdna
                                            Erdna
                                          • Hide warnings on the map
