  4. Route Makes Unexpected Detour
21 Posts 7 Posters 8.6k Views 3 Watching
  • John S Parry John S Parry
    @Gary-Coates Thanks for the input Gary. 95% of the time I save the route as a GPX 1.1 file and import it into my Zumo XT. The XT it doesn't have direct functionality for waypoint messages. Maybe I could do something with a waypoint name....
    I was also thinking that when the XT recalculates the route after import, it might continue on straight. The XT uses HERE maps also, but I haven't always found routes to calculate exactly the same in MRA and the XT. I'll try that when I get a chance.
    Gary Coates
    Gary Coates
    Gary Coates
    @John-S-Parry Please forgive me if you know all this already but.....
    I transfer my routes as GPX 1.1 to my BMW Nav 6 which is basically a garmin zumo. My waypoints are announced.
    I had a quick look on the internet and found Zumo XT users discussing their anouncements on their Zumo XT's - https://www.zumouserforums.co.uk/viewtopic.php?t=1570
    In the MyRoute-app route planner I set the point to be a waypoint (shows as a hand icon) and type the text I want read out as the waypoint name.
    Good luck.
    • Gary Coates Gary Coates
      Good luck.
      @Gary-Coates Thanks again for input. I try to keep hard (announcing) waypoints limited to real meaningful points. That means either an actual stopping point, or a point I want to measure to for route tracking progress purposes.
      I get that I can “trick it” past a point where HERE is screwed up. I guess that’s at least a workaround. I’m more irritated that it should be required at all. All other maps (Google, Apple, TomTom, and OSM) get it right. Over time, I’ve found HERE to be the most inaccurate among the basket of maps. This is just one example among several situations I’ve encountered.
      Regardless, I appreciate your recommendations.
        Can roadworks or accident in one direction be a cause?
        Just tried to make a route over the US 101 at that place.
        TomTom and Here made the same route. No detour as in your picture.
          @M-Schrijver I’m not sure what you’re looking at. The MRA detour is still there on the 101. I just also just tried the MRA Routeplanner in the app. The same detour appears.
          What’s interesting is that the native HERE app doesn’t show the detour. Maybe MRA has some avoidance on that I’m not aware of. I tried to set up zero avoidances, but who knows.
          MRA Web desktop is my favorite planner. But in cases like this, I switch to another app that I sometimes use. Again, I don’t want to set up odd waypoints in an attempt to trick the route into being useful.
            As you can see in my screenshot. The route is made in the direction as you screenshot and is made on the HERE map.
            No devation/reroute
            Found the cause.
            Change the transport mode from Motor to Car and your problem is solved.
            You can find a lot of topics were people are told to use Car instead of Motor.
            Transport Mode Motor does more damage than it has benefits.
            John S Parry Leike Lodiers 2 Replies Last reply
              No devation/reroute
              Found the cause.
              @M-Schrijver Thank you! Yes, I can see where this can cause a lot of confusion. I never would have figured this out. I appreciate your help.
                No devation/reroute
                Found the cause.
                @M-Schrijver @Corjan-Meijerink why don't you change the transport button to car/motor for the time being. That would take care of a lot of problem and explaining.
                • Leike Lodiers Leike Lodiers
                  @Leike-Lodiers When in "Car" mode, routes do show a picture of a car and a motorcycle on top of each other for mode. BTW, is there a way to change the mode for routes already created? I can't figure out how to change it for other older routes.
                  In any case, when in motorcycle mode, the route calculated in my example is just plain wrong at any level. Different for an explainable reason is OK, but that's not the situation here. What happened in my case is clearly a bug.
                  @Corjan-Meijerink, is this on a list of upcoming fixes?
                  Corjan Meijerink Rob Kelley 2 Replies Last reply
                    @John-S-Parry what exactly would be?
                      @Corjan-Meijerink The fix?? I guess to calculate the route correctly. Which in this case is a direct line between two points.
                      I'm not sure I understand the why there is confusion. The route I showed was a trip south on a major interstate (US-101) in California. There isn't a scenario I see where it makes logical sense to detour off the interstate to a side road, and then get back on. It doesn't make sense regardless of transportation mode.
                      If in fact there is a reasonable explanation, please share. Otherwise, I don't know how else I'd frame it other than being a route calculation bug.
                        Rob Kelley
                        Rob Kelley
                        Rob Kelley
                        @John-S-Parry said in Route Makes Unexpected Detour:
                        Open the route in MRA on your PC and from the left bar menu select 'Route Information' and change it under 'Transport Mode'
                        GSA1250
                        HD Street Glide
                        XT500 x 2
                          @John-S-Parry Exactly! Please report it here: https://mapfeedback.here.com/#/report
                          We are not responsible for the HERE route calculation itself.
                          I'll report it too! Makes stuff gets notices quicker 😉
                          I know that for customers it doesn't matter who fixes it, as long it works in MRA but nothing much I can do about this specific case 😞
                            @Corjan-Meijerink Thanks for your response. I'll report when time permits.
                            What's interesting is the native HERE app (HERE WeGo), using the motorcycle profile setting, calculates correctly. I'll also try importing into the XT (also HERE) to see what's actually calculated. I don't know why MRA's HERE implementation would be different, but I guess there are complexities in play I don't understand. At least there is a solution I can implement now.
                            • Rob Kelley Rob Kelley
                              #19
                              @Rob-Kelley Thanks for pointing me to the right place. 👍
                                Correction to my previous comment that motorcycle mode routes correctly on the HERE WeGo app. It doesn’t. 😳
                                Car mode routes correctly, while motorcycle has the same issue found in MRA. It’s definitely a HERE bug.
                                  @John-S-Parry perfect, thanks for confirming!
                                  • John S Parry John S Parry referenced this topic on
                                  Rob Kelley
                                  Rob Kelley
                                  Gary Coates
                                  Gary Coates
                                  • Route wordt afgesneden
                                    Wim Hompes
                                    Wim Hompes
                                    Jacob Waterweg
                                    Jacob Waterweg
                                  • OSM Routing with MRA
                                    Pedro de Cleen
                                    Pedro de Cleen
