  2. Routes & Tracks
  3. Walking route created with MRA
12 Posts 4 Posters 3.9k Views 2 Watching
  • Jorge del Valle Jorge del Valle
    I recently created a walking route using MRA. As a fair amount of the route was going to be not on roads, but in trails and fields, I set the route to offroad (Toolkit > Offroad) in the Routeplanner. I then manually traced the route and placed several shaping points as well as via points, some with added notes.
    When time came to use the route in the app I found a few issues:
    • The track line which joins all the waypoints doesn't show in the app.
    • If I tap on any of the points in the route nothing happens, so I can't see any of the notes I added to them.
    If I make a copy of the route and tick off the offroad option, I can now see the route line, although it's all mangled as the app is trying to use roads for portions of the route that are meant to be off road, but I still can't get anything when I tap on the waypoints.
    Am I doing something wrong? Is there a way to create a walking route that shows the route line, and also where I can get access to the notes I've added to my waypoints?
    @Jorge-del-Valle
    Use the OSM map, open the route and tick on the compass needle then start walking
    Jorge del Valle 1 Reply Last reply
      @Jorge-del-Valle
      Jorge del Valle
      Jorge del Valle
      Jorge del Valle
      @Hans-van-de-Ven-MR-MRA
      Thank you for your reply.
      When you say "tick on the compass" I assume you mean the icon on the bottom left of the app? If so, that's what I was already doing. When I to that I don't see the trail lines, and I don't get anything when I tap on the waypoints.
      Jorge
        @Jorge-del-Valle
        Right, just follow the line
          @Jorge-del-Valle
          Jorge del Valle
          Jorge del Valle
          Jorge del Valle
          @Hans-van-de-Ven-MR-MRA But that's just the thing. I don't see a line. I have to scroll around until I find the next waypoint, but there's no line connecting them
          Jorge
          HABVEN aka MrMRA Nick Carthew 2 Replies Last reply
            @Jorge-del-Valle
            Did you create a route?
              @Jorge-del-Valle
              The route must be made using the planning map from OpenStreetMap and you must have By foot (walking) selected as transport mode.
              Open the route and tap the location marker twice, (I have arrowed it in my screenshot) then as you walk the map will move with you as you follow the line. There are no turn by turn navigation instructions.
              • Jorge del Valle
                Jorge del Valle
                Jorge del Valle
                Yes, that's what I'm doing. But, at least for me, if I have the route set to "offroad" (which I need to as part of the route is in the middle of the countryside), I don't get a line to follow when I use the app.
                As an example, here's a test walking route I've made in the route planner, set to offroad:
                And this is how the same route appears in the Android app (zoomed in to the start of the route):
                As you can see, in the Android app version there are no lines for the route joining the navigation points.
                Jorge
                  Jorge del Valle
                  Jorge del Valle
                  Jorge del Valle
                  @Jorge-del-Valle I should also clarify that I don't get a line when I double-tap the location marker twice, as Nick instructed. For me there's no line to follow.
                  Jorge
                  MotoCon 2 Replies Last reply
                    @Jorge-del-Valle, This clearly is a routed route. Disable offroad and try to load it again. I have been hiking this way through Luxemburg without a problem. What I did was download the GPX 1.1 track only version, and start that one from the Downloads folder. You will lose Waypoints though.
                      @Jorge-del-Valle, To add to myself, I just tested the offroad setting and it does indeed match your description exactly. If you want to walk offroad route, it is better to download it as a GPX, track only, and open that one in MRA.
                        Jorge del Valle
                        Jorge del Valle
                        Jorge del Valle
                        @Con-Hennekens Thank you both. I'll give that a try. Shame that I will lose waypoints as I would have loved to be able to keep notes, but I can live with that.
                        Jorge
                        Jorge del Valle
                        Jorge del Valle
                        • Hide warnings on the map
                        • Testroute segmenten
                        • Map Layers
                          Martin White
                          Martin White
                          Michael 2v
                          Michael 2v
                        • Bollard trouble
