  4. Screen Alignment - INNOVV & Android Auto
4 Posts 3 Posters 1.8k Views 3 Watching
  • OneLooseNut Offline
    OneLooseNut Offline
    OneLooseNut
    I have an issue where the Android Auto display for Next navigation seems out of alignment, and largely unusable. I have tried many settings changes in the app, but have not found a solution.
    When in Android Auto displaying the MRA map, the view is as expected (position indicator in the centre of the screen). When using for navigating (planned route, or on the fly), the directions fill the left of the screen, and the position marker is on the far extreme of the right side of the screen...sometimes not visible (i.e. off the screen).
    Google Maps works fine, correctly positioning its marker in the middle of the map space.
    The app on the phone behaves as you would expect the navigation to work... clear, with the marker in the centre.
    Android Auto: 13.4.645054
    MRA: 4.3.5 (Gold, Lifetime)
    Android OS: 15
    Display: INNOVV N1
    Unfortunately, in fitting the INNOVV (fairings off, and wired front to back on the bike) the Garmin is no longer on the bike, and removing the INNOVV will take some time.
    Does anyone have a similar problem?
    Is there a fix?
    Am I missing a setting (I have tried many)?
    See the position marker far right?
    Without navigation, the marker displays in the centre as you would expect.
    • OneLooseNut OneLooseNut
      Android OS: 15
      Display: INNOVV N1
      Is there a fix?
      Corjan Meijerink Offline
      @OneLooseNut Now that is an issue I have not seen ever before ๐Ÿ™‚
      This is indeed very unusable.
      Could you create a support ticket (myrouteapp.com/support) about this subject. Please add:
      • The app logs (long press version number at the bottom of the page where all the settings are)
      • The images
      • If possible a screenrecording
      Things that could possibly help are:
      • Tapping the compass button on the phone or using the settings in Android Auto
      • Tappping the Android Auto screen in general
      • Changing the view of Android Auto by using the button bottom left (of Android Auto itself)
      Let's keep in touch in the ticket.
      If you also mention this forum message and me, I will make sure it gets assigned to me ๐Ÿ™‚
      OneLooseNut 1 Reply Last reply
        • The images
        OneLooseNut Offline
        OneLooseNut Offline
        OneLooseNut
        @Corjan-Meijerink Thanks Corjan - there should be a ticket raised by email 21st January, but I will raise via the link and provide additional detail.
        • Mobin 1 Offline
          Mobin 1 Offline
          Mobin 1
          I have noticed the same issue on my Android Autoโ€”Nissan T33 2024 model. I came back eventually.
          OneLooseNut
          OneLooseNut
          Mobin 1
          Mobin 1
          • Paar onduidelijkheden.
            169
          • Wegwerkzaamheden worden niet goed toegepast
          • Route app reageert niet
          • Update 5.2.1 - Android availability
          • Oranje wegdelen op de route?
