  4. maximum speed for all vehicle types
17 Posts 4 Posters 4.2k Views 2 Watching
  • Vincent Curren
    Vincent Curren
    Vincent Curren
    Interesting idea! For me, a feature like this would be helpful for a different reason.
    When touring the French Alps last October, I learned the hard way that the estimated times calculated by MRA were off by about a third. If MRA predicted that a route would take 3 hours to ride, I found it actually took 4 hours. I found that I was averaging maybe 40 km/hour on those mountain roads, if that. But the legal speed was much higher, which I think contributed to the difference.
    I would find it very helpful to have an option to specify a maximum speed (or an average speed, either could work) in the route planner that reflects my own riding style.
    Vinnie
    Peter Schiefer Cookie On Tour 2 Replies Last reply
    • Vincent Curren Vincent Curren
      Vinnie
      Peter Schiefer
      Peter Schiefer
      Peter Schiefer
      @Vincent-Curren
      On Garmin Basecamp you can set your own averages Speed per vehicle.
      But again, this is only for estimation at the green desk.
      The Nav Sat will use this info by settings too as far as I know at start, but it will adjust all estimated times by the real speed and average time per driven distance.
      Again, with years of experience you get a knowledge.
      Daytime drives, normal traffic condition. Car no trailer
      On Highway 100+/-5 per hour.
      Country roads interrupted with small villages at about each 10 Kilometers average 50+5 kilometers /hour.
      City traffic 20-25 km/h unbeleavable but true, with a car in the cities you are not so much faster than a bicycle.
      Peter
      Vincent Curren 1 Reply Last reply
      • Peter Schiefer Peter Schiefer
        @Vincent-Curren
        Vincent Curren
        Vincent Curren
        Vincent Curren
        @Peter-Schiefer said in maximum speed for all vehicle types:
        That has been my experience too.
        The difference in arrival accuracy between MRA and Google maps is pretty dramatic, though. Google maps is usually pretty good. MRA tends to predict arrival much sooner in my experience.
        Vinnie
          @Cookie-On-Tour
          May there is missunderstanding.
          To put your maximum speed im your data to calculate traveltime is an easy thing.
          But dimension and weight to avoid too small roads or low bridges ia another story. For this you need the data in the maps and for these extra data MRA must pay.
          This morning I saw on YT from a WoMo driver a report about Sygic.
          You can buy a special version for camper and must pay about 30 € in average per year above Lifetime use of the program for extras.
          Database for Sygic is the competitor from HERE for data and map supply TomTom.
          Sygic has no own route planer.
          I habe the standard Premium Sygic as Standby. You can Import MRA GPX files and get the route, but no info verbal or via text about POIs, coffee or lunch break stops.
          By the way with now more than 50 years of travelling by car, 12 years on business with car.
          I never worked with estimated time calculated from the Nav System „on the minute“ What ever you get is a possible time which can be wrong all the time on your way.
          An when you know your max speed in the Highway is max 90 and your distance on the highway is 450 km it is not 5 h it is about 6 h.
          On country roads your average is max 40 or sometimes less. because your accelaration is less, your max speed may only 75-80. Passing trucks impossible.
          The only way for you for time estimating is experience.
          Cookie On Tour
          Cookie On Tour
          Cookie On Tour
          @Peter-Schiefer for a regular car you, unfortunately, can't set a max speed, unless I don't know how.
          Joerg
          (Cookie-On-Tour.de)
          Peter Schiefer 1 Reply Last reply
            Vinnie
            Cookie On Tour
            Cookie On Tour
            Cookie On Tour
            @Vincent-Curren agree, I would love the max. speed for a car, as you may have an oldtimer and you can't go faster than x km/h, so it would be really helpful.
            Now while I am in Sweden, most roads are 80 km/h so MRA, when choosing car is pretty close in time calculations, however, when the route gors via a highway, MRA is off, and I agree, it's then about a third of the time.
            Joerg
            (Cookie-On-Tour.de)
            • Cookie On Tour Cookie On Tour
              Peter Schiefer
              Peter Schiefer
              Peter Schiefer
              @Cookie-On-Tour
              Joerg
              do you need rearly such calculation „exact on the minute“
              Why is it such a problem.
              I know your caravan is a very compact and slim one.
              May in Germanay you have a 100 km Ticket for German highways. in other countrys are different limits on highways and coutry roads.
              Here is an overview
              https://www.ace.de/reisen/reiseberichte/reiseberichte-artikel/artikel/tempolimits-fuer-caravans-in-europa/
              In avarage you are at 80 km/h
              You can add about 25% on estimated times for cars and you have a reference.
              I drove a caravan in the 80 few times to the south of france (Ardeche)
              When I need with the car only about 10-11 h netto for the about 930 Kilometer (google actuall 9:50) then i need with the caravan 14 h netto with an overnight.
              Peter
              Cookie On Tour 1 Reply Last reply
                @Cookie-On-Tour
                Joerg
                Here is an overview
                Cookie On Tour
                Cookie On Tour
                Cookie On Tour
                @Peter-Schiefer yes, I like to have an estimate that suits and is realistic, rather than not knowing when I will be at my destination. Especially when driving - I don't want to calculate all time while driving, I want to concentrate on the road. 🙂
                It's different when I make my planning, I often use the ADAC map and route planner, as they calculate pessimistic, means I usually beat their times. It's mostly about the routes when I have to be there on specific times, like a ferry or train etc. to catch.
                Yes, I now hear your saying you can't count on time, traffic jams, detours etc. up to now I am doing fine, never missed a date. Because, I am adding additional time, but as said I like to see an option for all vehicles.
                I know, I can calculate myself, but - we are talking about software, something that should ease our live. And as software can be changed and made convenient to use, my request is just a thing to make MRA even more userfriendly.
                Joerg
                (Cookie-On-Tour.de)
                  Vincent Curren
                  Vincent Curren
                  Vincent Curren
                  @Cookie-On-Tour said in maximum speed for all vehicle types:
                  @Cookie-On-Tour, for me, it's not the oldtimer car, it is that I, myself, am an oldtimer and >I< can't go faster than x KM/h! 😁
                  Vinnie
                    Peter Schiefer
                    Peter Schiefer
                    Peter Schiefer
                    @Cookie-On-Tour
                    I quote your text
                    on your first thread you wrote:
                    When I choose RV to be able to give the length of my car+trailer and max. speed, within the route planning I get different times (because there is the max. speed not taken into account), but at the nav app it is taken into account, but I need the timings for better planning.
                    Estimate travel time during planning and have here the opportunity to add average speed or a max speed on certain roads is a possibility at Garmin Basecamp. BC will use these values then for calculation of time.
                    But now with your second comment you makes a mental error.
                    At the Sat Nav on the road like a Garmin Camper you can only adress a max speed limit. There is no setting for road type average speed,
                    Original text Garmin Camper 895
                    Bearbeiten von Fahrzeugprofilen
                    Sie können grundlegende Informationen des Fahrzeugprofils ändern oder einem Fahrzeugprofil detaillierte Informationen hinzufügen, beispielsweise die maximale Geschwindigkeit
                    Dadurch wird eine realistischere voraussichtliche Ankunftszeit erstellt. Die Einstellung der maximalen Geschwindigkeit kann auch den Routenverlauf anpassen und zusätzliche Routenvorschläge liefern.
                    So you will get a bit more accurate Calculation when you start but
                    when the camper looks in addition on traffic info too an so an expected total time and time to next Alarm point, which is quite different to the BC calculation. But now when you beginn driving the system calculate constantly your time used and distance driven and present you a always insitu new expected total time. This is a complete different story to the calculation on the green table with e. g. Basecamp
                    Peter
                      @Cookie-On-Tour
                      I quote your text
                      Cookie On Tour
                      Cookie On Tour
                      Cookie On Tour
                      @Peter-Schiefer choosing RV has other down sides. Having the car an option for a max. speed would solve these down sides. That simple.
                      Joerg
                      (Cookie-On-Tour.de)
                      Peter Schiefer
                      Peter Schiefer
                      Cookie On Tour
                      Cookie On Tour
                      Vincent Curren
                      Vincent Curren
                      • Bollard trouble
                      • Testroute segmenten
                        Alderweireld Rudi 0
                        Alderweireld Rudi 0
                      • Minimap
                        LE DIZES Freddy
                        LE DIZES Freddy
                        Erdna
                        Erdna
                      • Map movement
