  4. Route Sync and General Comments
17 Posts 7 Posters 126 Views 3 Watching
    @Nick-Hodge, I don't mean no disrespect, just checking... Did you download all needed maps for offline use? It is normal that, when in online mode, offline mode is asked for and vice versa, but when switching to offline mode and all maps present, your route should be able to calculate. That is: when it is no track you are trying to navigate. Tracks can only be calculated online (HERE limitation). Keep in mind that "routes" you make through curvy options or roundtrip generator are factually tracks, not routes.
    Nick Hodge
    Nick Hodge
    Nick Hodge
    @Con-Hennekens you make interesting comment and no, I made no separate effort to download the offline maps as I (maybe wrongly) thought the sync had done away the need to download the maps as that was cumbersome as there was no clue what map was being used. Connected app only needs to have the route opened and if you don’t have the map(s) needed for the route to run offline it tells you which you need and downloads it/them.
    These were routes, not tracks BTW. Are we saying we do still need to download the maps needed for offline?
    Marinus van Deudekom MotoCon 2 Replies Last reply
    • Nick Hodge Nick Hodge
      @Nick-Hodge yes Nick you must download the map. Advantage is also that the navigation Goes faster
        Indeed, downloading offline maps is definitely a requirement!
        DerRoteBlitz Nick Hodge 2 Replies Last reply
          DerRoteBlitz
          DerRoteBlitz
          DerRoteBlitz
          @Corjan-Meijerink said in Route Sync and General Comments:
          Hi, why not to add an automatic download opportunity for maps? Based on existing routes available? I would use it....
            @Nick-Hodge said in Route Sync and General Comments:
            This is an interesting idea 😉
            I think it would be possible when starting a route, to automatically check if all needed maps are already available offline, and get a warning, or invitation to download them. On the other side, most users have a habit of navigating in their own and their surrounding countries / states, and have no real need for this automatic check. You could post it in the suggestions category 😉
              Nick Hodge
              Nick Hodge
              Nick Hodge
              @Corjan-Meijerink ok I misunderstood. I think it’s essential that some guidance is given of map(s) needed (as the connected app). I have no idea what region/district/oblast without research I’m travelling in and maps are large if a phone has restricted memory
              Thanks for clarity though
              Peter Schiefer 1 Reply Last reply
                Peter Schiefer
                Peter Schiefer
                Peter Schiefer
                Nick
                in your first report your wrote „ I travelled 4000 km through Europe“
                Now you wrote „I have no idea in what region I am travelling.“
                Sorry this is unbeleavable
                Clear complete EU maps are 18 GB but for those 4000 km and region of countries you will be knowing before you start you need perhaps 3-4 GB for maps. When you travel from GB to the Alps you do not need Sweden, Spain, Poland,
                At every time you can delete and install countries as needed if the memory on the phone is too small, which could happen as far as i know only on iPhones not able to add memory cards and her older version with 64 GB or less in memory space.
                Peter
                Nick Hodge 1 Reply Last reply
                • Peter Schiefer Peter Schiefer
                  Nick
                  Nick Hodge
                  Nick Hodge
                  Nick Hodge
                  @Peter-Schiefer My point Peter, was for example, France and Germany are large maps (4Gb on a 16Gb phone is a lot) broken into regions. I have no idea if I am in Rhineland-Westphalia, etc, etc. I know I'm in Germany, maybe Germany North West. My point is and I am a software developer, you shouldn't need to research getting from A-B by using other tools to identify the area you are in. I know where Rutland is in the UK, you may not). Opening the route on BMW's Connected App and it tells you exactly what you will need. No such think on MRA.
                  NOTE: This doesn't affect me personally now my understanding of offline/sync is clarified and I have a phone with 512Gb of space, BUT, we are trying to build a go-to, simple and accurate tool. Hence my further request.
                  Peter Schiefer Stanisław 2 Replies Last reply
                    Peter Schiefer
                    Peter Schiefer
                    Peter Schiefer
                    #14
                    @Nick-Hodge
                    Nick, fun fact, I travel through west Europe about 50 years and I have bit a knowlogde of this geographie and the postion of the main cieties, but at all I was not so familar with the location of main cities in UK before I was traveling for business there.
                    Anf regard to I know where Rutland is, no I don‘t know.
                    But I must repeat and this makes me a bit speachless. When I travel from UK to the Alps Italy, France Switzerland I collect informations regard the maps I need, the expected route I like to use and areas. So regard to the Bundesländer of Germany. You wrote „I do not know wher Northrine westfalia (NRW is the abbreviation) is“. But you have an idea with the overall map of Germany that you from London to the Munich not travel via Berlin, if there is no need but you pass for sample Cologne (my Hometown). Google Cologne and you will see that Cologne is NRW, you see you pass Frankfurt and you find Frankfurt is located in Hessen, you see Nürnberg and Munich and this is Bavaria, you do not need Saarland, Thüringen, Sachsen. Sorry a bit of work upfront is necessary for such a big trip.
                    Sometimes by some comments I ask myself, how did we survive in the past without Sat Navs.
                    Peter
                      Stanisław
                      Stanisław
                      Stanisław
                      @Nick-Hodge I agree, some help with downloading needed maps would be very nice, for example I don't know what "Basilicata" means in Italy and if I need it or not. Maybe some graphical presentaion would be possible, on the map. Or, as you suggested, a message by MRA "Your route needs some additional maps, do you want to download it?"
                      Staszek
                      • Stanisław Stanisław
                        Peter Schiefer
                        Peter Schiefer
                        Peter Schiefer
                        @Stanisław
                        Bailikata, surprising me too is not the Vaticano.
                        But as mentioned before, You can google Basilicata and find that this is the area of the foot sole of the Italian boot. I get now a bit more informed too. You always will learning.
                        Peter
                        Stanisław 1 Reply Last reply
                          @Stanisław
                          Stanisław
                          Stanisław
                          Stanisław
                          @Peter-Schiefer For me that are problems very low priority, it could be an improvement but of course we can also improve our knowledge 🙂
                          Staszek
                          Stanisław
                          Stanisław
                          Peter Schiefer
                          Peter Schiefer
                          DerRoteBlitz
                          DerRoteBlitz
                          Nick Hodge
                          Nick Hodge
                            guenniguenzelsen
                            guenniguenzelsen
                          • Club routes public/private
                          • Bollard trouble
