  4. Some comments to V335
14 Posts 4 Posters 97 Views 2 Watching
    @Jörgen The Lock Screen option is in the navigation menu.
    This post is deleted!
      • Jörgen Jörgen
        [[topic:post-is-deleted]]
        @Jörgen said in Some comments to V335:
        @Nick-Carthew
        Ok, it should be here then?
        Yes, click the 3 dots to open the navigation menu.
          @Nick-Carthew said in Some comments to V335:
          Ok, found it. Very well hidden. 😰
          • Jörgen
            I thought there was a fixed button on the screen with which you could switch this on/off. Thanks for the hint.
            • Jörgen Jörgen
              I don’t think it’s hidden, it’s in the navigation menu! Where else would be better?
              Jörgen 1 Reply Last reply
                @Jörgen Likes is used in the English version
                It can be used in German as well. It is common practice.
                  Ok, hidden for the old blind man. 😉
                  • Jörgen Jörgen
                    @Jörgen, the disable lock screen button only comes on once you enable lock screen from the menu. It is intended only for navigation purposes, hence it is not available in other parts of the app.
                    Also keep in mind that it is no "real" screenlock like some specific screen lock apps do. Else the on-screen unlock button would be impossible 😉 . It is just that all other screen operation is suspended while the lockscreen layer is on top. Hence also the Android soft-buttons will not be locked and also the system gestures are not locked (they are not within reach of the app functions). But of course the risk of raindrops interfering with your navigation is really a lot less this way.
                    Personally I would prefer the lock function to appear higher in the menu though, so no scrolling is necessary. But yeah, there must be left something to desire 😉
                      Awkward translations are fixed in the release!
                      • Strange translation
                        40
                        10.6k
                      • Shared toggle switch
                      • Undo/Redo tool is hidden
                      • Crazy routing
