  4. Feature questions before purchase
18 Posts 6 Posters 5.9k Views 1 Watching
  • F Nick F Nick
    Hi, I'm a happy Scenic app user, but I'm interested in myrouteapp should it offer some features. can anyone confirm if:-
    a) you can build a route consisting of several sections (denoted by way-points aka vias), where each section has a different amount of curvature e.g. A->B->C. A->B is a direct route, and B->C is very curvy. This feature is available in kurviger.
    b) alternative to route-trip generation.... the scenario..... i want to meet someone in a cafe 20 miles away in about 2hrs. generate a fun route from where I am now (point A) to the cafe (point B) which will involve a long but varied circular route taking 2 hours so that I arrive on time.
    Lynchy67
    Lynchy67
    Lynchy67
    @Fifield-Nick
    I don't think MRA can simulate exactly what your after.
    Calimoto is probably your best bet for that.
    However why not try out creating your own route directly in MyRoute-App.
    Anyways ,the info below outlines what the MRA Scenic Route Generator can do.
    You can generate Routes based on Time or Length.
    You can then decide how Curvey you want the Route
    You can then set the Height of the Route
    You are then given 3 different Route options.
    You also have the option of setting the length of the Route.
    You also get the Curvey and Height options and also you can dictate the direction based on North, East, South and West as shown below.
    You donโ€™t stop riding when you get old, you get old when you stop riding.
    • Bouke Ent
      point A is also there with segments is OSM map.
      • F Nick
        F Nick
        F Nick
        Thanks for all the replies .
        Not clear on the answers to my questions.
        Not convinced the features are provided as described- not looking for workarounds as I already have those in scenic .
        • richtea999
          Yes, and yes!
          > a) can you build a route consisting of several sections, where each section has a different amount of curvature
          Do it in stages - which is what you have to do anyway since you're after different curvature for certain sections.
          Step 1:
          Create each sub-section of your route. Each one can have different curvature.
          Use the 'Create Scenic Routes' option at the top level of the web Route Lab (https://www.myrouteapp.com/routelab)
          • select 'Create a scenic roundtour' and make it 'Create a scenic route'
          • add your start and end points for this sub-section of the route
          • pick your wiggle factor (see Lynchy's screenshots above)
          • save the route
          • repeat for all the different subsection that make up your full route
          Step 2:
          Stitch together the sub-routes into your full route.
          • create a new route
          • in the lefthand menu (where it says 'Waypoints') tap the 3-bar menu & pick 'Routes'
          • add your (sub-)route
          • add another (sub-)route, etc
          • for each route you've added, press '+' and decide where to add it ('Beginning' or 'End').
          • then convert from route-track to route so you have waypoints you can edit if you want to fine-tune it ('Edit route-track' option -> 'use as route')
          Limitations:
          • you need to keep below 200 waypoints for the final route, so keep an eye on your sub-route waypoint count.
          • you can't juggle the subroute order after merging them with 'Beginning'/'End', so you name your sub-routes carefully to help get the merge order correct
          The 'Create Scenic Routes' option at the top level of the web Route Lab will take time as well as distance as the main driver for your scenic route
          F Nick 1 Reply Last reply
          • Bouke Ent
            take a test drive with trail.
            • F Nick F Nick
              @Fifield-Nick said in Feature questions before purchase:
              I am also not convinced. Some people are suggesting the sections feature, but that is a planning feature, not a Navigation feature. If you want to navigate with the app, the HERE maps are not compatible with sections. So that's not going to work unless you compare the route To the HERE map and adapt it to follow the curvatures without using sections and curvy options. That is a really great feature, but will probably be seen as a workaround in this case.
              Bouke Ent richtea999 2 Replies Last reply
                @Con-Hennekens if you use segments and make a route then you can convert it to here map and use it in MRA Next or keep it as track and then also use it in MRA Next
                  @Con-Hennekens said in Feature questions before purchase:
                  Note Nick's language 'can I build...'. He wants to use the planner. And he's posted in the Web side of the forum, not the app side.
                  Here's an example from Burford to Cheddar Gorge and back:
                  1. I built a wriggly scenic route out, and left ALL the auto-generated waypoints in, so there's no loss of 'wriggliness'.
                  2. I built a second scenic route that was direct (I decreased the number of auto-generated waypoints because I know it's approximately direct, so I don't need so many of them)
                  3. I merged them into a single route (see instructions above)
                  It took about as long to write this reply as it did to construct the route.
                  There-wriggly (generated by Scenic route generator):
                  https://www.myrouteapp.com/en/social/route/9648289?mode=share
                  Back-direct (generated by Scenic route generator):
                  https://www.myrouteapp.com/en/social/route/9648300?mode=share
                  There and back (combined manually in a few clicks):
                  https://www.myrouteapp.com/en/social/route/9648307?mode=share
                  Where's the problem?
                  Try it Con!
                  [Nick, you'll not be able to decrease the waypoint count without a Gold level membership.]
                  Lynchy67 F Nick 2 Replies Last reply
                  • richtea999 richtea999
                    Try it Con!
                    Lynchy67
                    Lynchy67
                    Lynchy67
                    @richtea999
                    Bloody marvelous, I'd not considered stitching sections together like that. ๐Ÿ‘
                      Try it Con!
                      F Nick
                      F Nick
                      F Nick
                      wrote on last edited by F Nick
                      @richtea999 thanks. That's feature B sorted,
                      Now all I need to see is feature B.
                      BTW, unable to post via Chrome on macOS.
                      richtea999 1 Reply Last reply
                      • F Nick F Nick
                        @Fifield-Nick B or B? ๐Ÿ˜ต .
                        I covered both A and B!
                        B is dead easy, and very short compared to A - hence it may have got lost at the bottom of my first post.
                        If I've not answered it correctly, let me know and I'll have another go!
                        In terms of not being able to post it's worth noting the forum gets upset if you open multiple tabs at the same time and then try posting but not from the most recently opened tab. Refreshing the tab that you're going to post on solves the problem.
                          Yes, and yes!
                          Step 1:
                          • save the route
                          Step 2:
                          Limitations:
                          F Nick
                          F Nick
                          F Nick
                          @richtea999 just spotted this . So I can ask the planner to take an extravagant route (say 2 hours of curves) between two points ( say 20mins direct) ?
                          • richtea999
                            @Fifield-Nick Ah - you've found a small hole in the features there.
                            If you do a round trip (A->A) you can request a time of say 2 hours.
                            If you auto-create a route (A->B) you can't.
                            I reckon that's a feature worth asking for. Let's see what Corjan says. It may be very easy to implement. Or not. (If it is, don't expect it to appear next week, just understand that the MRA team do listen to requests, which is a rare treat in software development!)
                            Ref:
                            https://forum.myrouteapp.com/topic/7485/suggestion-add-duration-distance-options-to-scenic-a-b-route
                            • Bouke Ent Bouke Ent
                              @Bouke-Ent, When you switch to the HERE map, you lose the segments. Of course you can always use a track indeed.
                              @richtea999 said in Feature questions before purchase:
                              Yes but he is also
                              That's an indication that Nick is also looking for an alternative to the navigation app ๐Ÿ˜‰ And even if he is not, the warning stands as a valuable piece of added information.
                              Try it Con!
                              Haha, you don't need to teach me how to use the planner. I would do it differently anyway. I would be done after step1 and let Navigation just lead me to WP1 quickest way. No need for a route number 2! ๐Ÿคฃ
                              Bouke Ent 1 Reply Last reply
                                Yes but he is also
                                Try it Con!
                                #17
                                yes but not route. if you switch to here it will copy it to new route and add waypoints to follow route of OSM (i think it uses a track for that segment to convert it to here route). only negative it can give that there is a max of 200 waypoint and that can be a problem to follow the contour of all the segments.
                                same you have when you import a track in MRA planner.
                                personaly i do not use this option.
                                  Ref:
                                  F Nick
                                  F Nick
                                  F Nick
                                  @richtea999 I work in software development ๐Ÿ˜Š
                                  F Nick
                                  F Nick
                                  Lynchy67
                                  Lynchy67
                                  • Elevation profile: cursor that follows the route on the map
                                    60
                                  • Question on Beta access
                                    320
                                  • Guida Libera
                                  • Totaaltijd veranderd niet
                                    Gerard Caspers
                                    Gerard Caspers
                                  • Route Opacity Viewing Existing Routes in Library
                                  • Device Limit โ€“ There Are Limits to My Understanding
                                    BMcG
                                    BMcG
                                  • A to B Navigation with Extra Stop.
