  4. Route Violation
Route Violation
13 Posts 4 Posters 340 Views 2 Watching
  • Jörgen
    I had this the other day again, and wish that this will be changed, as bluetuz said into display some seconds and disappears.
    • Jörgen
      I had this issue again. Because of false information in Here maps, the road was closed, but it was not.
      1. I would like that this "Routenverstoß" message should not cover the Route information box.
      2. It would be useful if this message disappears in some time. (or was blinking if this was the only place to display).
      3. And in case of false information it would be useful if this could be switched off. to take this road anyway.
      I remember TomTom Rider Time, for this issue you could restart the Rider with switched off live traffic information, and then you could drive these streets however.
      • Jörgen Jörgen
        Hi, I had an issue the other day when I missed the exit, I was on the Highway and got this messages (because I had "Avoid motorway" on).
        It is ok so far, but I can not stop on the highway to tap on the X to close this window. It covers the speed information.
        It would be useful if it could be displayed blinking e.g. 5 sec. on 5 sec. off
        Otherwise, it is too dominant and disturbs.
        @Jörgen said in Route Violation:
        I agree that a message that blinks on and off would perhaps be better but you do not need to tap the X anywhere in the box will do.
          Don’t think we will change anything soon about this.
          You can turn it off completely! 🙂
          Jörgen bluetuz 2 Replies Last reply
            @Corjan-Meijerink said in Route Violation:
            Ok, I will try this.
            In a first step and easy step, you could move the warning position a little higher.
              bluetuz
              bluetuz
              bluetuz
              wrote on last edited by bluetuz
              @Corjan-Meijerink Sorry Corjan, but it doesn't seem like a good solution to deactivate it completely. Perhaps, if you deactivate it, during the route there are other sections where the original route is violated and it would be convenient to know about it, which you would not be able to do if you deactivated it completely. I don't think it's right that a message is permanently obstructing information. In fact, that message allows you to close it but it is displayed again immediately. What is the use of the close button then? I think you should rethink a solution.
              All this always with respect and trying to contribute so that Next improves
              • bluetuz bluetuz
                @bluetuz totally understand, no worries 🙂
                The information obstruction is only the ETA really, not that essential all the time 😉
                I do agree that closing it needs it to remain closed, I’ll check that later!
                bluetuz 1 Reply Last reply
                  bluetuz
                  bluetuz
                  bluetuz
                  @Corjan-Meijerink Great!!! Thank you
                  • Jörgen Jörgen referenced this topic on
                  • Jörgen
                    I've thought about this problem again and had an idea, but haven't tried the idea yet.
                    You would have to interrupt the online connection, as I used to do with the TomTom Rider in the past with a similar issue, so that any closures cannot be included in the route calculation in the first place.
                    With MRA, you would have to download the route beforehand so that it is available offline and, of course, the maps for this region would also have to be downloaded.
                    Then switch MRA to offline mode and load the route again. It may also be necessary to temporarily disable the data download.
                      The issue where a warning would not remain closed after dismissing it, has been fixed for the next update! 🙂
                        bluetuz
                        bluetuz
                        bluetuz
                        bluetuz
                        bluetuz
                        • Testroute segmenten
                        • Bollard trouble
                        • Minimap
                          LE DIZES Freddy
                          LE DIZES Freddy
                          Erdna
                          Erdna
                        • Hide warnings on the map
