  4. BMW Connected Ride Navigator not importing waypoints
41 Posts 7 Posters 27.9k Views 4 Watching
  • paul69 paul69
    @Philip-Goh
    that to me looks like you have imported the track and not the route/waypoints.
    i doubt anyone would plan a route with 2800 waypoints, that would be excessive in my view
    somebody may correct me on this fact.
    did you read the post i inserted above.
    Philip Goh
    Philip Goh
    Philip Goh
    @paul69 I imported the route. However there is little difference in the route vs track when it comes to support points. Importing the waypoints alone gives me just a straight line between the start and the end.
    HABVEN aka MrMRA Dikke Wim paul69 4 Replies Last reply
    • Philip Goh Philip Goh
      @Philip-Goh
      The 2 points are the via points in the route, don’t use this route
      The other 2 you can use, the one with more then 1000 start porting points is the track
      The other one is the route
      Philip Goh 1 Reply Last reply
        @Philip-Goh
        Philip Goh
        Philip Goh
        Philip Goh
        @Hans-van-de-Ven-MR-MRA So the one that is the "route" with the 2851 support points i the one I want while the "track" with 2849 support points is the one I want to avoid?
          @Topcat502
          Use the TomTom map, use max 50 shaping points. Then send it to the connected app, choose the track and route with 50 points.
          Then in the route file tick on the 3 dots in the upper right corner and choose convert to route with points. The 50 points will be visible.
          Choose that route on the CRN and you can also make the track visible on the CRN
          Dikke Wim
          Dikke Wim
          Dikke Wim
          @Hans-van-de-Ven-MR-MRA said in BMW Connected Ride Navigator not importing waypoints:
          @Topcat502
          Superbedankt Hans. Op die manier worden er inderdaad punten zichtbaar. Ik heb niet het idee overigens dat dit de punten zijn die ik in MRA heb aangemaakt. Dus een lunchstop of koffiestop heeft mogelijk geen punt in de CRN.
          Heb je misschien daar weer een oplossing voor?
            Dikke Wim
            Dikke Wim
            Dikke Wim
            @Philip-Goh
            This is also what I see when exporting from MRA to the Connect Ride app on my iPhone WHEN I EXPORT the route as a GPX1.2 file. When exporting as a GPX1.1 file, the number of point in the route are always below 50.
            Like the Track, also the route with the many points (sometimes >3000) can be used by the CRN!
            • Dikke Wim Dikke Wim
              @Topcat502
              @Dikke-Wim
              Klopt TT kent geen via punten of harde punten. De route splitsen bij de koffie, lunchstop is een optie
                @Philip-Goh
                i have just exported a simple route from MRA to my connected app, if you notice the two are very different, one has 2517 support points and the other only 22. obviously the lower number is the route with the waypoints.
                perhaps you should try to import again and see if you get the same result
                i cannot explain why you would have so many way/support points in a route.
                K1600 GTL
                iPhone 13 Pro, carpuride 702b
                  @Philip-Goh
                  i have downloaded the same route as the one you used, i do not seem to be having the issue that you have
                  as you can see i have something similar to you except my route only shows 32 support points.
                  i have added a capital A to the name just for reference.
                  this was in the mRA app on my iPhone.
                  the route saved in my routes on the website,
                  MRA app>click route> click download as 1.1gpx>then click export>click connected app>this gives the above page>select route to import.
                  K1600 GTL
                    @Philip-Goh
                    Philip Goh
                    Philip Goh
                    Philip Goh
                    @Dikke-Wim This was it!! I was always using GPX 1.2 and that seems to generate files that are 2x the size of the GPX 1.1 files. When I switch to using GPX 1.1, then it works as expected!
                    GPX 1.1 is the way to go for BMW’s connected ride app and navigator.
                    Dikke Wim 1 Reply Last reply
                      Dikke Wim
                      Dikke Wim
                      Dikke Wim
                      @Philip-Goh said in BMW Connected Ride Navigator not importing waypoints:
                      Exctually, I'm not sure yet that GPX1.1 is the best option. If I look at the ROUTE in the pictures above, I see differences between the route and the Track.
                      A good check is to:
                      • make the track visible (e.g. in the color black instead of the default white color)
                      • then start the route with the fewer waypoints (<50)
                      • compare the route with the tack on the map.
                      • differences are easily seen when the blue line (route) deviates from the black line (track).
                      I'm curious about the result.
                      Please let me know the outcome!
                        A good check is to:
                        Philip Goh
                        Philip Goh
                        Philip Goh
                        @Dikke-Wim you have to do what Hans suggested above, which is to take the route, convert it to a set of waypoints and then the route looks very similar to the track. Much better than what was in the screenshot.
                          Dikke Wim
                          Dikke Wim
                          Dikke Wim
                          #17
                          @Philip-Goh
                          Thanks for adding this information. Very useful.
                          Indeed, the route becomes much better and similar to the track after calculating the routepoints in de Connect Ride App on the smartphone. Once inside the Connect Ride Next it looks good!
                          So the small image of the route in de App is misleading.
                          paul69 1 Reply Last reply
                            @Philip-Goh
                            @Dikke-Wim said in BMW Connected Ride Navigator not importing waypoints:
                            and that is exactly the information given in the link i posted at the beginning of this thread.
                            K1600 GTL
                            • paul69 paul69
                              Dikke Wim
                              Dikke Wim
                              Dikke Wim
                              @paul69
                              Sometimes I'm hard learning... 🙂
                                @paul69
                                hi
                                did you look at the thread I inserted. although it's a different forum.
                                I have actually copied into pdf doc and have easy access to it, for when i forget how to do it.
                                K1600 GTL
                                • paul69 paul69
                                  hi
                                  Dikke Wim
                                  Dikke Wim
                                  Dikke Wim
                                  @paul69
                                  Could you upload the pdf file here?
                                  That would be nice.
                                    @Topcat502
                                    Dikke Wim
                                    Dikke Wim
                                    Dikke Wim
                                    Hans, I'm curious. Why would you use the route with the waypoints visible? There is no difference between VIA-points and FORM-points. For me it would make sense if you could maken only the VIA-point visible (lunch stops, coffee breaks, castles, etc.). When do you use these waypoints that are visible in the CRN as balloons?
                                    Maybe I miss it but wat is the advantage of seeing all waypoints? The route without the waypoints is the same.
                                    The only thing I can think of is that you can REMEMBER that e.g. waypoint 20 is a coffee break.
                                    A workaround is to add favourites by hand (one by one) in the CRN. These points are visible as a balloon with an asterisk.
                                    Hope te hear from you!
                                      @paul69
                                      That would be nice.
                                      @Dikke-Wim
                                      hi,
                                      not sure it's possible to upload files
                                      K1600 GTL
                                      • paul69 paul69
                                        @Dikke-Wim
                                        hi,
                                        Dikke Wim
                                        Dikke Wim
                                        Dikke Wim
                                        @paul69
                                        I don't see an option either. No problem. I think I have enough information already.
                                          @Dikke-Wim
                                          The CRN sees all points as injured points, if you change the name of the points, you will see the name in the CRN at a point, for example Coffee or lunch.
                                          You will not receive a notification from the CRN, but you can see them. Or indeed remember the number where you want to stop.
                                          Dikke Wim
                                          Dikke Wim
                                          Jez 0
                                          Jez 0
                                          Kenneth de Miranda
                                          Kenneth de Miranda
                                          Philip Goh
                                          Philip Goh
                                          Topcat502
                                          Topcat502
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
