  4. Changing start point
2 Posts 2 Posters 453 Views 1 Watching
  • Murat Bas Offline
    Murat Bas Offline
    Murat Bas
    I am nearly sure this question has been asked before, but I want to ask it again and thanks a lot for answering.
    If I want to start the route from a point which is nearby my home (so not from the beginning) and I want to ride all the route, so the start will not 1 but 23 for example. And the end point is 48 but I want to go on from 48 to 1 till I am back by 23, after 23 I want to ride back home. Is this possible?
    • Murat Bas Murat Bas
      @Murat-Bas, Yes that is possible in two ways:
      • you can adapt the route in the planner and change point 23 into the starting point.
      • you can just start the route as it is, long press WP 23 to start from there. When you reach the endpoint start the route again and start from WP1 until you reach WP 23 again.
      Murat Bas
      Murat Bas
      • MRA groups
        Steve Standing
        Steve Standing
      • POI naming/text display
      • Stemgeluid sterker bij afspelen muziek
      • scenic routes maken werkt niet
      • Folders that can store tracks and waypoints
        martin-phogel.de
        martin-phogel.de
      • Onbegrijpelijke afslagen
        465
