  4. 4.1.3 - Not working offline
25 Posts 4 Posters 202 Views 2 Watching
    @Con-Hennekens if I understand correctly, he does not have a route. He is using search to generate an A to B route.
    ATLast
    ATLast
    ATLast
    @RetiredWingMan said in 4.1.3 - Not working offline:
    Correct.
      @ATLast. I have to agree with Con Hennekens that you must be missing an area map. I tried playing with various options. Note, if I have no internet then the curvy options are not available. I have offline navigation turned on.
      Internet connection NOT available: if I don't have downloaded maps I can't even get this far.
      Internet connection available:
      ATLast
      ATLast
      ATLast
      Well, look at the screenshots of the status of the offline maps I posted : you will see the maps of Belgium and France are downloaded.
      If you press the X button on the right, the program will propose you to remove them.
      By the way, before I leave, I always check that, basic precaution.when I go abroad.
        @ATLast
        When i try it on my phone. I see a different with your screenshots.
        My endpoint is placed on the road. Yours is not. Could this have something to do the problem.
        If i translate the French error message. I says something like it cannot the reach the destination
        ATLast 1 Reply Last reply
        • ATLast ATLast
          @ATLast sorry, I can't help any more from here (Canada). I suggest you enter a Support request. Perhaps they can figure out the problem.
            ATLast
            ATLast
            ATLast
            Thank you a lot for your time and your suggestions.
            I hope the people @mra read these posts...
              @ATLast
              ATLast
              ATLast
              ATLast
              @M-Schrijver said in 4.1.3 - Not working offline:
              The endpoint is set by the program: I simply enter the address.
                ATLast
                ATLast
                ATLast
                But that doesn't match the situation I was in: if you look at the screenshots I posted when I was facing the problem, you'll see there was a 5G connexion.
                I don't rule out a "special" behaviour of the French roaming operator but, as I said, I conducted a few tests on my own to check if the Internet was available or not: the New York Times refreshed its page and mails and Whatsapp were ok.
                • ATLast ATLast
                  @ATLast
                  I did also and mine is put in middle of the road. I enter the address i could read from your screenshots
                    @ATLast
                    ATLast
                    ATLast
                    ATLast
                    I use a Google Pixel 8 Pro on Android 14, are you on Android ?
                    It is strange that you cannot get the same result as me.
                      Yes Pixel 6 Pro and Android 14
                      ATLast
                      ATLast
                      • Testroute segmenten
                        Michael 2v
                        Michael 2v
                      • Hide warnings on the map
                      • Map Layers
                        Martin White
                        Martin White
                      • Bollard trouble
