  4. 4.1.3 - Not working offline
25 Posts 4 Posters 202 Views 2 Watching
    @ATLast, if it happens at straight routes, it is very likely that, despite being confident that you have the maps downloaded for offline use (all needed regions...?) , you actually have not 😉 . Are you aware of the fact that the last version removed the possibility to download maps to your SD card? If you had them on SD card, you will have to redownload them to local memory (due to a problem with the HERE SDK).
    Can you make screenshots of the downloaded map overview? If maps are actually present, I would be interested in your shared route.
    ATLast Offline
    ATLast Offline
    ATLast
    @Con-Hennekens said in 4.1.3 - Not working offline:
    @ATLast, if it happens at straight routes, it is very likely that, despite being confident that you have the maps downloaded for offline use (all needed regions...?) , you actually have not . Are you aware of the fact that the last version removed the possibility to download maps to your SD card? If you had them on SD card, you will have to redownload them to local memory (due to a problem with the HERE SDK).
    Yes, all the maps were downloaded and up-to-date as we have to download them everytime they release a new version.
    Screenshots here.
    By the way, I'm not a total newbie: I work as an IT and use other programs: Waze, maps, Osmand... And I tried several others to et what I'm looking for. Myrouteapp can deliver what I want, but is still too buggy.
    I will post another problem I've run into yesterday.Capture d'écran 2024-05-27 150123.jpg Capture d'écran 2024-05-27 150208.png
      Do you have roaming enabled. Offcourse only necessary when you are not in our own country.
      ATLast Offline
      ATLast Offline
      ATLast
      @M-Schrijver said in 4.1.3 - Not working offline:
      I even switched from 5G to LTE in case the roaming operator would prevent me to use its 5G network.
      But, once again, none of this should apply if the application would work offline as it should.
      • ATLast ATLast
        RetiredWingMan Offline
        wrote on last edited by RetiredWingMan
        @ATLast. I have to agree with Con Hennekens that you must be missing an area map. I tried playing with various options. Note, if I have no internet then the curvy options are not available. I have offline navigation turned on.
        Internet connection NOT available: if I don't have downloaded maps I can't even get this far.
        Internet connection available:
        ATLast 2 Replies Last reply
        • ATLast ATLast
          Screenshots here.
          @ATLast, are you willing to share the route? If you don't want it pubic, you may sent me a link by DM.
            @Con-Hennekens if I understand correctly, he does not have a route. He is using search to generate an A to B route.
            Con Hennekens ATLast 2 Replies Last reply
              @RetiredWingMan, yes of course, you are right.
                ATLast Offline
                ATLast Offline
                ATLast
                @RetiredWingMan said in 4.1.3 - Not working offline:
                Correct.
                  ATLast Offline
                  ATLast Offline
                  ATLast
                  Well, look at the screenshots of the status of the offline maps I posted : you will see the maps of Belgium and France are downloaded.
                  If you press the X button on the right, the program will propose you to remove them.
                  By the way, before I leave, I always check that, basic precaution.when I go abroad.
                  • M. Schrijver Offline
                    @ATLast
                    When i try it on my phone. I see a different with your screenshots.
                    My endpoint is placed on the road. Yours is not. Could this have something to do the problem.
                    If i translate the French error message. I says something like it cannot the reach the destination
                    ATLast 1 Reply Last reply
                    • ATLast ATLast
                      @ATLast sorry, I can't help any more from here (Canada). I suggest you enter a Support request. Perhaps they can figure out the problem.
                        ATLast Offline
                        ATLast Offline
                        ATLast
                        Thank you a lot for your time and your suggestions.
                        I hope the people @mra read these posts...
                          @ATLast
                          ATLast Offline
                          ATLast Offline
                          ATLast
                          The endpoint is set by the program: I simply enter the address.
                            ATLast Offline
                            ATLast Offline
                            ATLast
                            But that doesn't match the situation I was in: if you look at the screenshots I posted when I was facing the problem, you'll see there was a 5G connexion.
                            I don't rule out a "special" behaviour of the French roaming operator but, as I said, I conducted a few tests on my own to check if the Internet was available or not: the New York Times refreshed its page and mails and Whatsapp were ok.
                            • ATLast ATLast
                              @ATLast
                              I did also and mine is put in middle of the road. I enter the address i could read from your screenshots
                                @ATLast
                                ATLast Offline
                                ATLast Offline
                                ATLast
                                I use a Google Pixel 8 Pro on Android 14, are you on Android ?
                                It is strange that you cannot get the same result as me.
                                  Yes Pixel 6 Pro and Android 14
                                  ATLast
                                  ATLast
                                  • The slow death of Zumo...
                                  • Route Breakdown
                                  • MRA Touring Romania Group
                                  • I can't see Road Closures
                                    Lary
                                    Lary
                                    Arno van Lochem - Senior RX
                                    Carl Lee
                                    Carl Lee
                                    636
