  4. Distance 0 mi, Duration 1 min
21 Posts 7 Posters 155 Views 2 Watching
  • Eugene7 Eugene7
    I've shared a TEST route - made it Public.
    Hope that works.
    The routes are all generated via TYRE, as that is our preferred method for generating routes.
    @Eugene7 said in Distance 0 mi, Duration 1 min:
    shared
    Please share the URL of the route here ... That way we don't have to search for your route in your account if we can even find your account since your forum nick may not be the same as your account name.... πŸ˜ƒ
    Eugene7 1 Reply Last reply
      shared
      Eugene7
      Eugene7
      Eugene7
      https://www.myrouteapp.com/en/social/route/9115557?mode=share
      www.7-dna.com
      www.youtube.com/user/bogclub7
      • Eugene7 Eugene7
        @Eugene7
        The route has been made using the TomTom planning map. Not recommend for MRA Navigation.
          @Eugene7
          @Nick-Carthew Even though that is correct, it does not explain the behaviour of the app @Eugene7 is showing. It seems like the app was unable to calculate the route... That has nothing to do whether or not the route was made in TomTom or HERE, surely discrepancies may occur but that's irrelevant for now imho regarding the issue @Eugene7 has. 😊
          What I do notice is that the route he shared with us has 12 waypoints, and his has 13. What happened there? It seems like his app calculated directly to the end which is also almost his start position.
          Anyhow, I cannot explain the app behaviour based on this shared route. There seems nothing wrong with it. πŸ˜…
            @Stefan-Hummelink Yes, all very true. I was merely pointing out that the TomTom planning map had been used.
              @Nick-Carthew said in Distance 0 mi, Duration 1 min:
              Hehe I know. πŸ˜ƒ
                Hehe I know. πŸ˜ƒ
                @Stefan-Hummelink Also interesting or strange is that the map on the screenshot that @Eugene7 shared is not in focus. And the route title is different.
                  Eugene7
                  Eugene7
                  Eugene7
                  Ignore the TEST route...
                  I stupidly made it in MyRoute, not in TYRE.
                  As said, the issue is with routes made outside of MyRoute.
                  www.7-dna.com
                  • Eugene7 Eugene7
                    Eugene7
                    Eugene7
                    Eugene7
                    Here is another Test route that has the issue: https://www.myrouteapp.com/en/social/route/9123837?mode=share
                    www.7-dna.com
                    Nick Carthew Corjan Meijerink Lynchy67 3 Replies Last reply
                    • Eugene7 Eugene7
                      @Eugene7 Again this is caused because the TomTom map has been used for planning the route and the onscreen message tells you this. Press Navigate and after choosing to use as a route or a track the time and distance calculations are available. If using the track you will need to be online.
                      You can of course use the Compare with tool in the route planner to align the HERE route to the TomTom route.
                      • Eugene7 Eugene7
                        @Eugene7 Interesting, I just checked the metadata of this route and can indeed confirm that distance / duration is not set (therefore the app displays these values).
                        Did you import the route and that's it? Metadata is updated on every waypoint placement / adjustment but if you never modified anything that might explain why information is missing! πŸ™‚
                        • Eugene7 Eugene7
                          Lynchy67
                          Lynchy67
                          Lynchy67
                          @Eugene7
                          In "New Test" there is no Waypoint 25?
                          Waypoint 26 is duplicated.
                          • Lynchy67 Lynchy67
                            @Eugene7
                            Eugene7
                            Eugene7
                            Eugene7
                            True - it is a duplicated point - makes no difference to the issue though.
                            Seems any externally generated routs show zero duration when imported into MyRoute...
                            www.7-dna.com
                            • Eugene7 Eugene7
                              @Eugene7 so when importing a route, this is indeed the issue? I can fix that!
                              Can you confirm that simply dragging one waypoint slightly updates the route information correctly? πŸ™‚ (or adding / removing one, just any route manipulation to be fair)
                              Dae 0 1 Reply Last reply
                                Dae 0
                                Dae 0
                                Dae 0
                                I’ve definitely seen that when I imported my old Basecamp routes. All had zero time and distance until I β€œtouched” them
                                • Dae 0 Dae 0
                                  @Dae-0 thanks! I’ll get that sorted πŸ™‚
                                    Fixed πŸ™‚
                                    Dae 0
                                    Dae 0
                                    Lynchy67
                                    Lynchy67
                                    Eugene7
                                    Eugene7
                                    • Testroute segmenten
                                      Michael 2v
                                      Michael 2v
                                    • Hide warnings on the map
                                    • Map Layers
                                      Martin White
                                      Martin White
                                    • Bollard trouble
