  3. Format sound Bluetooth
19 Posts 4 Posters 3.8k Views 1 Watching
    The profile does not affect this. This is programmed in the software of the headset
    What brand and model headset do you use?
    jclaudejundefined 1 Reply Last reply
      jclaudejundefined Offline
      jclaudej
      @M-Schrijver
      Thank a lot for your contributions
      I use SENA SMH05FM
      And for example I can't use Google Map or Waze beacause when the communication is open between my wyfe and me I can't received message from these applications
        According to the manual. Intercom should be interrupted by a mobile phone.
        Try pairing your Phone as a GPS device with A2DP profile. Which is probably the default profile.
          jclaudej
          @M-Schrijver
          Ok I will test next week 😉
          • jclaudejundefined jclaudej
            Hi from France,
            I would like to know what is the format of sound by bluetooth because I would used MRA Navigation Next with my motor bike and my Helmet and if I want keep the communication with my passenger. For that the sound format must be output smartphone communication and not music.
            I don't found how manage this point inside MRA Navigation Next,
            Can you help me ?
            Philip Robertsundefined Offline
            Philip Roberts
            @Jacquet-2 I found it depends on which device I connect first, I usually connect my SatNav first then my phone for voice, I I would ensure the BT con phone is connected to headset before opening Navigation Next
            • jclaudejundefined Offline
              jclaudej
              I tried different solutions without success because I either have the intercom between our two helmets or the navigation information.
              An example with Cruiser who manage exit
              text alternatif
              Perhaps the new generation of Sena manage this functionnality ?
                text alternatif
                jclaudej
                @jclaudejIn fact if you have an intercom with "audio multitask" you haven't a problem but with a basic or old intercom this functionality is not possible 😉
                  @jclaudej
                  That function is not available on his headset. But it is the solution.
                  The Sena Spider could be a good budget friendly replacement. Which has Mesh intercom and Audio Multitasking
                    Hi from France,
                    Can you help me ?
                    Leike Lodiersundefined Offline
                    @jclaudej i would install cardo edge on youre helmet. You can communicate with youre duo and connect to two devices, phone and gps..
                    • Leike Lodiersundefined Leike Lodiers
                      jclaudej
                      @Lei-Lodiers Hi, thank you for your contribution but I have a bad experience with Cardo especialy with the SAV of this company and I prefer choice à Sena product who help these after the warranty.
                      I think to buy Sena SF4 duo.
                      Leike Lodiersundefined M. Schrijverundefined 2 Replies Last reply
                        @jclaudej hi I have no experience with sena. We use cardo edge sometimes with a group of 15 bikers and it works flawless. With communication and navigation. Don't now how sena works.... Hope you can answer this in the future... 👍🏻👍🏻
                          Sena and Cardo have very simliar functionality in the same price range. But both brands cannot mix with eachother
                            @jclaudej
                            Please do not buy the SF4.
                            The Spider has mesh for nearly the same price as the SF4.
                            Take my word. Mesh is the prefered choice for intercom. Even with 2 persons
                              @jclaudej
                              jclaudej
                              @M-Schrijver I use intercom only with my wife who is behind me 😉 so mesh isn't necessary for us.
                                Mesh is a part of your solution.
                                Mesh is advertised as THE intercom for groups. But it is also the better one for two persons compared to Bluetooth intercom.
                                Therefore the advice.
                                When you buy a new intercom, ALWAYS buy one with mesh.
                                  jclaudej
                                  Hi,
                                  I solved my problem with a new Sena Spider ST1 😉
                                  jclaudejundefined
                                  jclaudej
                                  Philip Roberts
                                    Nick Carthewundefined
                                    202
                                  • v5.2 (473) Feedback
                                    Lenny Oundefined
                                    Lenny O
                                    1.2k
                                    Lenny Oundefined
                                    Lenny O
                                    Paul Borghoutsundefined
                                    Paul Borghouts
                                    Lenny Oundefined
                                    Lenny O
                                    434
                                    nomkoundefined
