  4. Use routes created with TT map on BMW Nav device
3 Posts 2 Posters 897 Views 1 Watching
  • Rudi Timmermans
    Rudi Timmermans
    Rudi Timmermans
    Hello,
    What would the best practice for the following scenario?
    A friend uses a TT and creates routes with the TT map, we have BMW NAV and use Here map...
    Is ok OK to export his TT routes directly to our BMW Nav?
    Or better to "Use Route" and convert to the HERE map first.
    Any other suggestion?
    Tnank you!
    Rudi
    • Rudi Timmermans Rudi Timmermans
      Hello,
      Tnank you!
      Rudi
      @Rudi-Timmermans if one of you has a GOLD subscription then you can use the Toolkit Compare function to make sure the TT route matches the Here route. Once they do there should be no differences when you install the route on your devices.
      Rudi Timmermans 1 Reply Last reply
        Rudi Timmermans
        Rudi Timmermans
        Rudi Timmermans
        @RetiredWingMan , we have both a GOLD subscription so yes we use this functionality to compare.
        Rudi Timmermans
        Rudi Timmermans
        • Online map settings
          885
          Axel Lange
          Axel Lange
        • In het kort......
        • voice prompts are unitelligable,
        • View a route from the previous planner
