  4. MotoButtons Lite DIY project!
52 Posts 10 Posters 38.3k Views 3 Watching
  • richtea999 richtea999
    @Jörgen said in MotoButtons Lite DIY project!:
    @Con-Hennekens I have problems with this joystick. Up, down, left, right is ok but Center switch is difficult to use.
    As in difficult to press, or difficult not to accidentally rock sideways when pressing?
    @richtea999 Yes moving in any direction instead hitting Center is nearly always happen.
    I would give Center a new button if I had more space in the small case.
    richtea999 1 Reply Last reply
    • Jörgen Jörgen
      @Jörgen Thanks Jörgen, very useful info, if/when I get around to making one.
      • harupipapaZZZ
        harupipapaZZZ
        harupipapaZZZ
        wrote on last edited by harupipapaZZZ
        #34
        I also love the moto button.
        I tried making something like this.
        I sent a request to Github, but the long press of the center button works as a virtual button.
        I would like to set it so that the A and B buttons are also long pressed.
        But I don't know how.
        Does anyone know?
        7EF20038-17B7-44E1-9D0E-7F17D22695D4_1_105_c.jpeg 95735343-C683-48FA-B500-C617A1C2DB4B_1_105_c.jpeg A286EED6-15EE-4DD2-AE1B-166A0AB6798E_1_105_c.jpeg
        Jörgen 1 Reply Last reply
        • harupipapaZZZ harupipapaZZZ
          Does anyone know?
          @harupipapaZZZ Hi, you need to add something to the existing code, you need programming skills (I think it's written in C).
          A friend did this for me and put the function "skip waypoint" on the A key when you press and hold it.
          This works in principle, but the long press triggers a zoom in. So it's not perfect yet.
          Jon the developer has now released a new version, but the function is built in incorrectly.
          He's reacting a bit slowly at the moment, he's probably very busy.
          My friend is currently looking at how Jon has programmed the function and is comparing it with his version. Maybe we can find a solution in the meantime.
          There is alittle change in the zoom +/- function needed, that zoom react only on one key hit (means one click zooms one step) with this a long press will not zoom in/out a lot when a long press function is added.
          harupipapaZZZ 1 Reply Last reply
          • Jörgen Jörgen
            harupipapaZZZ
            harupipapaZZZ
            harupipapaZZZ
            @Jörgen
            Is it possible to send your code?
            I'll try and compare.
              @Jörgen
              @harupipapaZZZ send me a PN with your mail address. I can do it later.
              • Jörgen Jörgen
                harupipapaZZZ
                harupipapaZZZ
                harupipapaZZZ
                @Jörgen
                I don't know how to PM so I put a message in your chat.
                  @Jörgen
                  @harupipapaZZZ said in MotoButtons Lite DIY project!:
                  That's quite the same thing... 😉
                  • Jörgen Jörgen
                    @Robert-Jeffries Hi, Robert interesting version you made. Do you have a picture how and where you mount it to the bike?
                    I ask Jon to implement „skip way point“ to make it more compatible to MRA. Have you seen the latest version of the code.
                    I have little problem when the controller lost power while navigating, MRA then hangs and need restart. Have you seen this as well?
                    Robert Jeffries
                    Robert Jeffries
                    Robert Jeffries
                    @Jörgen yes I have updated the code to the latest version but have not yet tried the skip waypoint feature.
                      @Robert-Jeffries, very interesting! Did you use the same joystick? Did you press the rubber against the inside of the case?
                      Robert Jeffries
                      Robert Jeffries
                      Robert Jeffries
                      @Con-Hennekens yes I have used the same joystick and rubber cover. The joystick is clamped to the inside of the "box" and I've not any problems with water ingress although it could also be sealed with a fine bead of silicone if necessary.
                      • harupipapaZZZ
                        harupipapaZZZ
                        harupipapaZZZ
                        Thanks to @Jörgen's communication, I found out the difference in the code of the long press program.
                        Unfortunately, my controller is being modified and I can't try it out.
                        The rest is the mode switching operation.
                        Rather than switching sequentially,
                        When you press the A and B buttons at the same time for more than 1 second, the mode will change to "Receiving changing mode".
                        It would be very convenient if you could press UP, DOWN, LEFT, and RIGHT during this time to change directly to each mode.
                        Even if I ask Chat GBT, they won't tell me the correct code.
                        It would be nice to have someone who knows.
                        This is mine.
                        To make the remote part thinner, a tact switch is used and the XIAO is stored in a separate box.
                        this is another version
                        Buttons glow in the dark.
                        • joncox
                          joncox
                          joncox
                          I updated the open source, DIY, low cost MotoButtons navigation controller to version 2.0. Check out the video and the new GitHub repository. It now features a 3D printed case design and, optionally, a commercial waterproof joystick. This is an open source project and you have to build it yourself.
                          https://youtu.be/i00laBGHPMg?feature=shared
                          https://github.com/joncox123/MotoButtons2
                          • Jörgen
                            @joncox Nice Update. 👍
                            Since some weeks I have problems with the first version. After power off, I need to pair the BT connection to my tablet, always new.
                            joncox 2 Replies Last reply
                            • Jörgen Jörgen
                              joncox
                              joncox
                              joncox
                              @Jörgen What is the model and operating system version of your tablet where this happens? You could try reprogramming the device after updating the Arduino IDE and all of the support libraries in the IDE (the support libraries should prompt you automatically to be updated).
                              • Jörgen Jörgen
                                joncox
                                joncox
                                joncox
                                @Jörgen Thanks, I think I will also design a second version of this case for the original, $3 USD 5-way joystick. These commercial, IP68 joysticks keep getting more expensive.
                                To keep the cost very low, its best to use the original joystick. It sounds like that is still working for you, right?
                                • joncox joncox
                                  @joncox said in MotoButtons Lite DIY project!:
                                  I use an Oukitel RT3 (150,-€ in the moment) with Android 12.
                                  Maybe you're right that I need to reprogram all.
                                  I found someone who added the skip waypoint function for MyRoute-App in the code (I have no idea how to do this). With this version I drive for some month and it is a very useful help, and it's fun to navigate with it, especially if you want to change your route on the way or have to look for another road because it's blocked.
                                  Does your new Code include skip waypoint?
                                  Can I use the new code for the old hardware version?
                                  I am not sure if the changes I (let) made are 100% correct.
                                  The additional switch could do the skip WP instead of pressing one button longtime to do Skip WP.
                                  joncox Jörgen 2 Replies Last reply
                                  • Jörgen Jörgen
                                    joncox
                                    joncox
                                    joncox
                                    @Jörgen I can't find the key assignment for "skip waypoint" listed anywhere on the internet. Can the developer of MRA say which keyboard code (HID code) is assigned to "skip waypoint"?
                                    • Jörgen Jörgen
                                      The joystick is working still ok, the center button is a bit difficult to hit, so another button for center is maybe the solution, but then you four buttons (zoom +/-, Center and Skip WP) plus joystick.
                                      joncox 1 Reply Last reply
                                      • joncox joncox
                                        #50
                                        @joncox Ok, it is a "d"
                                        Joystick is "up, down, left right" (like cursor)
                                        Zoom is "+ / -" on button A and B
                                        Center is "c" (on joystick)
                                        long press Center "n" for menu
                                        And I have long press an B skip waypoint "d" HID_KEY_D
                                        • Jörgen Jörgen
                                          joncox
                                          joncox
                                          joncox
                                          @Jörgen Here is a MotoButtons 2 case design that uses the $2.50 USD joystick. This will be a lot easier to assemble because of the cutouts for the Adafruit $2.50 5-way joystick.
                                          This will be almost as inexpensive as the original MotoButtons to build, around $45 USD.
                                          MartinW
                                          MartinW
                                          Leo Klein
                                          Leo Klein
                                          Robert Jeffries
                                          Robert Jeffries
                                          joncox
                                          joncox
                                          harupipapaZZZ
                                          harupipapaZZZ
                                            Erdna
                                            Erdna
                                          • Minimap
                                            LE DIZES Freddy
                                            LE DIZES Freddy
                                          • Bollard trouble
                                          • Map movement
