  3. Timmelsjoch HERE / MRA mapping problem...
26 Posts 7 Posters 8.7k Views 1 Watching
  • Tom Grzelinski
    Tom Grzelinski
    Tom Grzelinski
    @richtea999
    RichTea - thank you! You are welcome to join me in September. I will be doing this in the car though as I am not sure I could ride my Ducati 998 that far without my arms falling off!
    This is my rough map and I will then go in and check each waypoint and move them, especially at junctions, but thanks for pointing those out.
    Your 'one other tip' is awesome, thank you for this, that will save a lot of time.
    Cheers, Tom.
    • Tom Grzelinski Tom Grzelinski
      Hi, I am planning a new Alpine trip and currently have a work-in-progress map here:
      https://www.myrouteapp.com/en/social/route/8734835?mode=share
      I will eventually split it in to day maps, but my problem is in the Timmelsjoch region, waypoints 53 to 63. I have had to add lots of waypoints on this road to get the HERE map, or MRA, to navigate straight between 53 and 63. Without all these points it tries to make a route up and through Innsbruck and back down.
      In fact, that loop can be seen on the map because I am tonight trying to get it to go straight from my hotel on Sölden, back over Timmelsjoch and on to waypoint 70. I have placed lots of extra waypoints but MRA is still determined to route me up to Innsbruck and back down.
      What is happening? Can anyone help me please??
      Thanks, Tom
      Erdna
      Erdna
      Erdna
      @Tom-Grzelinski
      Hi Tom,
      great plan, but that route is a mess. No offense, but there are so much more misplaced waypoints...^^
      I do agree that there may be an issue with Timmelsjoch seasonal closing depending on what map you are using. HERE can do it correct or not when reloading on my PC.
      BTW: in my opinion, you are missing some of the best experience of those roads by returning at the top of some passes.
      For your consideration a personal POI list with more than 600 entries that may give some additional options. 🙂
      https://www.google.com/maps/d/u/0/edit?mid=1wRIVqBxCOUcmLwVvuTIejBr5bh_r4pA&usp=sharing
      Regards from Austria,
      André
      Tom Grzelinski 2 Replies Last reply
      • Erdna Erdna
        @Tom-Grzelinski
        Hi Tom,
        André
        Tom Grzelinski
        Tom Grzelinski
        Tom Grzelinski
        @Erdna
        Hi André,
        Give me a break, this is a rough map! I know it has issues and I’ll be spending this weekend tidying it up. 😁
        Seriously, thank you for your link. I will look through it this weekend. My route is based on my past experiences, looking at shared routes here on MRA and being aware of time limits and trying to do as much as possible each day.
        BUT, if I am missing good drives, then I am very happy to alter my route. 👍
        I have not booked any hotels yet, so everything is flexible.
        I will keep my map public and will do a big update, and tidy up this weekend, for you and Josef. 😜
        Cheers, have a great weekend,
        Tom
        • Erdna Erdna
          @Tom-Grzelinski
          Hi Tom,
          André
          Tom Grzelinski
          Tom Grzelinski
          Tom Grzelinski
          wrote on last edited by Tom Grzelinski
          @Erdna
          Hi André,
          I have had a quick look at your POI map - wow!
          You say I am "missing some of the best experience of those roads by returning at the top of some passes." Please help me with these.
          Your map has so many POIs, but no route. Please tell me some of your favourite locations near my route that stand out for you, and I will try to change my journey.
          Thank you,
          Tom.
          Tom Grzelinski 1 Reply Last reply
            @Erdna
            Hi André,
            Thank you,
            Tom.
            Tom Grzelinski
            Tom Grzelinski
            Tom Grzelinski
            @Tom-Grzelinski
            The Timmelsjoch problem is back, even with very few waypoints, all correctly positioned on the roads! So, maybe these were not the problem?
            See the map here:
            The problem is between points 53 to 56. I want to drive from 53 to 56 and then back down the same road to 56. I do not want to be routed up to Innsbruck!
            If I delete a waypoint, like 55, then the map works as it should. But then later (5 mins) it reverts to routing up to Innsbruck.
            Can anyone from MRA shed light on this problem that @Erdna has experienced too?
              @richtea999
              Cheers, Tom.
              @Tom-Grzelinski WHAT??? Come on mate, I did these kind of tours on a 900SS, 916 and a 999 🏍 💪 😁
              Tips: split every day in its own route, you have more overview.
              Change your "highlights" in your route (red, yellow and green) into waypoints. In stead a upsidedown waterdrop change it into a hand. In that case you will be notified when you arrive at that point.
              MRA Lifetime Gold
                @Tom-Grzelinski
                See the map here:
                @Tom-Grzelinski the problem lies in a little piece of road on the Timmelsjoch in the direction of Sölden. If you place the shapingpoints like this, the problem should be solved. Try to toggle with point 54, drag it somewhat to the south and you will see that the problem comes back again. The markers in my example should solve it. 7d82df97-e5cd-429c-9319-19d7fcd554ea-image.png
                MRA Lifetime Gold
                • Travellexxie Travellexxie
                  Tom Grzelinski
                  Tom Grzelinski
                  Tom Grzelinski
                  @travellexwill-cyou
                  Thanks Will, it was always my intention to cut this in to separate days. I think I said that earlier. This is my overview of the whole route.
                  Ha ha, I find my 749RS so much more comfortable than the 998, but unfortunately (or maybe fortunately for my license?) it is not road legal 😆
                    Tom Grzelinski
                    Tom Grzelinski
                    Tom Grzelinski
                    @travellexwill-cyou
                    Thanks Will. I will try this but I am not sure this is the total problem.
                    When I was first building the route I got to 53 then searched for Timmelsjoch in MRA, choosing this:
                    Timmelsjoch High Alpine Road
                    46.911210, 11.087460
                    and placed a waypoint. Straight away the map would not route between 53 and this point. I had to add lots and lots of waypoints between 53 and this waypoint to make MRA make a direct route.
                    So, I think maybe the whole area has a problem. Maybe seasonal closing is not being ignored here?
                    This is not a massive problem for my trip as when I break the map in to separate days, it should work. And also I am intelligent enough not to get up in the morning and let the map take me to Innsbruck 🤣 but I think the problem needs investigating and fixing in MRA or HERE, whichever is at fault.
                    Thanks for your help 👍
                      @travellexwill-cyou
                      @Tom-Grzelinski there is something strange with the Timmelsjoch, that is correct, because I deleted the 2 points, and the route stayed the same 🤦 d73164f5-d051-4af4-9fe3-2986dcc22021-image.png
                      But the problem is only a small strip around the top. It might be the seasonal closing, but in some way that is working, because when I disable (or able) the seasonal closure I see this e6d0d784-8081-4e12-b93b-8432e543de58-image.png , so yeah it is working, but yeah, there is something spooky at the Timmelsjoch. Just travel to the place, enjoy it all, because it is fabulous over there and ignore the problems on your navigation. By the way Basecamp has the same problems with this stupid mountain.
                      Greetings,
                      Lex
                      MRA Lifetime Gold
                      • paul69
                        #23
                        hi @Tom-Grzelinski
                        I noticed this anomaly last year. I did write something on the forum.
                        it is a lesson learned for me, it is not a major issue, as long as you are aware when planning the routes.
                        if you did not check them and send them to friends, then you would be parting ways at the approach road to the passes. 🤣🤣
                        I planned my routes, around the Alps. then save and close the MRA planner.
                        When I went back a few days later, to add another route or to amend a route, I found some routes had changed, especially on the passes, without my input.
                        I do not know why this happened.
                        what I will add, after end of May, this stopped happening, so it has to be something to with the passes being shut in the winter.
                        also, as you have found, it made no difference if seasonal closure was ticked/disbaled or not.
                        I now make sure that when I plan a route, if its the final version, I will make a track out of it, that way I always have the original planned route.
                        I have not made routes in the alps this year so I am unaware if this still happens, but it looks like it does.
                        I am touring the Scottish highlands/Lake District/Yorkshire Dales, so no high passes, but still awesome.
                        K1600 GTL
                        iPhone 13 Pro, carpuride 702b
                          Greetings,
                          Lex
                          Tom Grzelinski
                          Tom Grzelinski
                          Tom Grzelinski
                          @travellexwill-cyou
                          Thanks Lex. Sorry I read your name wrong!
                          • paul69 paul69
                            hi @Tom-Grzelinski
                            Tom Grzelinski
                            Tom Grzelinski
                            Tom Grzelinski
                            @paul69
                            Thanks Paul. Enjoy Scotland, we will be doing some of Scotland next year in our camper.
                              @travellexwill-cyou
                              @Tom-Grzelinski no worries it's OK, since you are riding a Ducati 😁
                              PECCO!!! 🏅 🏆
                              MRA Lifetime Gold
                              Garry Davis
                              Garry Davis
                              Tom Grzelinski
                              Tom Grzelinski
                              Erdna
                              Erdna
                              • Route wordt afgesneden
                                Wim Hompes
                                Wim Hompes
                              • OSM Routing with MRA
                                Jacob Waterweg
                                Jacob Waterweg
                              • Route MRA importeren in Google Maps
