  3. Timmelsjoch HERE / MRA mapping problem...
26 Posts 7 Posters 3.7k Views 1 Watching
  • Tom Grzelinskiundefined Offline
    Tom Grzelinski
    Hi, I am planning a new Alpine trip and currently have a work-in-progress map here:
    https://www.myrouteapp.com/en/social/route/8734835?mode=share
    I will eventually split it in to day maps, but my problem is in the Timmelsjoch region, waypoints 53 to 63. I have had to add lots of waypoints on this road to get the HERE map, or MRA, to navigate straight between 53 and 63. Without all these points it tries to make a route up and through Innsbruck and back down.
    In fact, that loop can be seen on the map because I am tonight trying to get it to go straight from my hotel on Sölden, back over Timmelsjoch and on to waypoint 70. I have placed lots of extra waypoints but MRA is still determined to route me up to Innsbruck and back down.
    What is happening? Can anyone help me please??
    Thanks, Tom
    Jack van Tilburgundefined Garry Davisundefined Erdnaundefined 3 Replies Last reply
    • Tom Grzelinskiundefined Tom Grzelinski
      Thanks, Tom
      Jack van Tilburg
      @Tom-Grzelinski
      I don't exactly understand with you want to plan in this region.
      Is this what you want?
      Tom Grzelinskiundefined 2 Replies Last reply
        @Tom-Grzelinski
        Tom Grzelinski
        @Jack-van-Tilburg Hi Jack, yes, you are correct.
        I want to drive from 53 to 64 and back to 53, but MRA does not like this. I have to put many waypoints to get MRA to join 53 to 64 without diverting around. And now I cannot get it to do the return journey at all.
          @Tom-Grzelinski
          Tom Grzelinski
          @Jack-van-Tilburg
          Hi Jack,
          OK, it I do not understand. Now, it is all working properly. I have deleted all the extra waypoints and the route is working.
          The problem was as if 'Disable seasonal closures' was not working, but only on the Timmelsjoch road.
          Anyway, for now it is working! Thank you for your time anyway.
          Tom
          Tom Grzelinskiundefined Jack van Tilburgundefined 2 Replies Last reply
            Thanks, Tom
            Garry Davisundefined Offline
            Garry Davis
            wrote on last edited by Garry Davis
            @Tom-Grzelinski said in Timmelsjoch HERE / MRA mapping problem...:
            Thanks, Tom
            I went to this museum last year, you'll love it, lots to see. They've even got lockers as you go in on your left. Enjoy it, and your trip overall.
            Tom Grzelinskiundefined 1 Reply Last reply
            • Garry Davisundefined Garry Davis
              Thanks, Tom
              Tom Grzelinski
              @Garry-Davis
              Thanks Garry. We drove through there two years ago, but we were on such a tight deadline to get from Innsbruck down to Brescia that we couldn't stop at the museum. I am looking forward to taking my time this year!
              Cheers, Tom.
                @Jack-van-Tilburg
                Hi Jack,
                Tom
                Tom Grzelinski
                @Tom-Grzelinski
                And now it's not working again. Argh!
                  @Jack-van-Tilburg
                  Hi Jack,
                  Tom
                  Jack van Tilburg
                  @Tom-Grzelinski
                  The placed waypoints have numbers. And those numbers must be in order of the route. In your route the numbers were mixed up.
                    @Tom-Grzelinski
                    Tom Grzelinski
                    @Jack-van-Tilburg
                    Hi Jack, I know this and I also thought maybe the numbers were not in order, but this is not the problem.
                    Take a look at the map now, with all the extra waypoints removed and you will see that MRA / HERE is refusing to route back from Solden (54) direct to point 56.
                    Interestingly, if you delete waypoint 55, it all works correctly, but only for a short time (2-5 mins?) before the map goes back to routing through Innsbruck.
                      @Jack-van-Tilburg
                      Jack van Tilburg
                      @Tom-Grzelinski
                      Make sure that all your waypoints are on the road.
                      As soon as I correct 54 the route is corrected.
                        @Tom-Grzelinski
                        Tom Grzelinski
                        @Jack-van-Tilburg
                        Wow, thank you Jack, well spotted. 👍
                        I was sure I had checked that, but obviously not. Lesson learned!
                        richtea999undefined 1 Reply Last reply
                          @Jack-van-Tilburg
                          richtea999undefined Offline
                          @Tom-Grzelinski
                          I'm just here to say I'm jealous. Carry on!
                          Actually, on point 38, I'd move that to be after the junction otherwise you may get waypoint information showing during the ride rather than turn information, and the turn info is more important. Like so:
                          Before:
                          After:
                          Same for 35, etc.
                          Placing points right on junctions always feels like the right thing to do when you're looking at the map, but not necessarily when you're actually riding.
                          One other tip is when you click on the waypoint and get the little info pop-up, if you then click the magnifiying glass that zooms you in to the max level of detail. Then use the left/right arrows to go along and check every waypoint - it's quick and efficient (well, until you find a problem 😊 ).
                            Tom Grzelinski
                            @richtea999
                            RichTea - thank you! You are welcome to join me in September. I will be doing this in the car though as I am not sure I could ride my Ducati 998 that far without my arms falling off!
                            This is my rough map and I will then go in and check each waypoint and move them, especially at junctions, but thanks for pointing those out.
                            Your 'one other tip' is awesome, thank you for this, that will save a lot of time.
                            Cheers, Tom.
                            Lex.Kloet.RXundefined 1 Reply Last reply
                              Thanks, Tom
                              Erdnaundefined Offline
                              Erdna
                              @Tom-Grzelinski
                              Hi Tom,
                              great plan, but that route is a mess. No offense, but there are so much more misplaced waypoints...^^
                              I do agree that there may be an issue with Timmelsjoch seasonal closing depending on what map you are using. HERE can do it correct or not when reloading on my PC.
                              BTW: in my opinion, you are missing some of the best experience of those roads by returning at the top of some passes.
                              For your consideration a personal POI list with more than 600 entries that may give some additional options. 🙂
                              https://www.google.com/maps/d/u/0/edit?mid=1wRIVqBxCOUcmLwVvuTIejBr5bh_r4pA&usp=sharing
                              Regards from Austria,
                              André
                              • Erdnaundefined Erdna
                                @Tom-Grzelinski
                                Hi Tom,
                                André
                                Tom Grzelinski
                                @Erdna
                                Hi André,
                                Give me a break, this is a rough map! I know it has issues and I’ll be spending this weekend tidying it up. 😁
                                Seriously, thank you for your link. I will look through it this weekend. My route is based on my past experiences, looking at shared routes here on MRA and being aware of time limits and trying to do as much as possible each day.
                                BUT, if I am missing good drives, then I am very happy to alter my route. 👍
                                I have not booked any hotels yet, so everything is flexible.
                                I will keep my map public and will do a big update, and tidy up this weekend, for you and Josef. 😜
                                Cheers, have a great weekend,
                                Tom
                                  @Tom-Grzelinski
                                  Hi Tom,
                                  André
                                  Tom Grzelinski
                                  wrote on last edited by Tom Grzelinski
                                  @Erdna
                                  Hi André,
                                  I have had a quick look at your POI map - wow!
                                  You say I am "missing some of the best experience of those roads by returning at the top of some passes." Please help me with these.
                                  Your map has so many POIs, but no route. Please tell me some of your favourite locations near my route that stand out for you, and I will try to change my journey.
                                  Thank you,
                                  Tom.
                                    @Erdna
                                    Hi André,
                                    Thank you,
                                    Tom.
                                    Tom Grzelinski
                                    @Tom-Grzelinski
                                    The Timmelsjoch problem is back, even with very few waypoints, all correctly positioned on the roads! So, maybe these were not the problem?
                                    See the map here:
                                    The problem is between points 53 to 56. I want to drive from 53 to 56 and then back down the same road to 56. I do not want to be routed up to Innsbruck!
                                    If I delete a waypoint, like 55, then the map works as it should. But then later (5 mins) it reverts to routing up to Innsbruck.
                                    Can anyone from MRA shed light on this problem that @Erdna has experienced too?
                                      @richtea999
                                      Cheers, Tom.
                                      Lex.Kloet.RXundefined Offline
                                      Lex.Kloet.RX
                                      @Tom-Grzelinski WHAT??? Come on mate, I did these kind of tours on a 900SS, 916 and a 999 🏍 💪 😁
                                      Tips: split every day in its own route, you have more overview.
                                      Change your "highlights" in your route (red, yellow and green) into waypoints. In stead a upsidedown waterdrop change it into a hand. In that case you will be notified when you arrive at that point.
                                      Geluk/verliefdheid is net als in je broek plassen. Iedereen ziet het alleen jij voelt het.
                                      MRA Lifetime Gold
                                        @Tom-Grzelinski
                                        See the map here:
                                        Lex.Kloet.RX
                                        @Tom-Grzelinski the problem lies in a little piece of road on the Timmelsjoch in the direction of Sölden. If you place the shapingpoints like this, the problem should be solved. Try to toggle with point 54, drag it somewhat to the south and you will see that the problem comes back again. The markers in my example should solve it. 7d82df97-e5cd-429c-9319-19d7fcd554ea-image.png
                                        MRA Lifetime Gold
                                        • Lex.Kloet.RXundefined Lex.Kloet.RX
                                          Tom Grzelinski
                                          @travellexwill-cyou
                                          Thanks Will, it was always my intention to cut this in to separate days. I think I said that earlier. This is my overview of the whole route.
                                          Ha ha, I find my 749RS so much more comfortable than the 998, but unfortunately (or maybe fortunately for my license?) it is not road legal 😆
                                          Tom Grzelinski
                                          Lex.Kloet.RX
                                          richtea999undefined
                                          Erdnaundefined
                                          Erdna
                                          paul69undefined
                                          Jack van Tilburg
                                          Garry Davis
                                          • snelheid zichtbaar
                                            Erik 35undefined
                                            Erik 35
                                          • free ride
                                            Ewout 2undefined
                                            Ewout 2
                                          • Strange behavior
                                            white.mouseundefined
                                          • Just a little tweak
                                            Alex redsundefined
                                            Alex reds
                                          • MRA 5.0.1 - 433 Datei (Route) teilen an MRA
                                          • scenic route inkorten
                                            pehaundefined
                                            peha
                                            2.4k
