  3. Update the connector for Mac users please
11 Posts 4 Posters 2.4k Views 3 Watching
  • Richard Ward
    Richard Ward
    Richard Ward
    I would like to know why the Windows connectorhas more options then the Mac?
    Windows 11
    Mac OSX
    You can see Mac transfers older files and I have noticed a difference between GPX 1.1 and 1.2 when I import directly into my Zumo. If I use a Mac, I end up having to import the GPX 1.1 into BaseCamp and fix it there... and Base Camp is an awful solution.
    • Richard Ward Richard Ward
      Windows 11
      Mac OSX
      @Richard-Ward
      Which version of the connector are you using?
      Rob Verhoeff Dikke Wim 2 Replies Last reply
        @Richard-Ward
        @Hans-van-de-Ven-MRA-Master there is no version-number in the connector! I can't remember installing a connector. My filessystem however says 3.3.0.
          @Rob-Verhoeff Re-installing the app results in the same version.
            @Rob-Verhoeff
            This is the latest version
            I don't know why there are differences between the Windows and Mac versions.
            This will probably be included in the major maintenance of the website
            • Rob Verhoeff
              @Hans-van-de-Ven-MRA-Master that is version 3.3.0
                @Rob-Verhoeff
                @Hans-van-de-Ven-MRA-Master I understand that the source code can no longer be updated because it requires an antique PC. At least, that's what the dev team says. Apparently, the latest hardware can't run that old software.
                  @Richard-Ward
                  Dikke Wim
                  Dikke Wim
                  Dikke Wim
                  Updated the connector for Mac and still no option to export BMW Motor (GPX 1.2). See figure below.
                  • Dikke Wim Dikke Wim
                    @Dikke-Wim dat gaat niet gebeuren ook. Het platform waarop de connector voor MacOS is gemaakt is niet meer beschikbaar. Misschien dat dit ooit nog wordt opgepakt als de website onderhanden wordt genomen. Maar voor nu moet je het hiermee doen.
                    Dikke Wim 1 Reply Last reply
                      Dikke Wim
                      Dikke Wim
                      Dikke Wim
                      @Rob-Verhoeff
                      Bedankt voor de informatie. Voor mij betekent dat, dat ik mijn routes gewoon als GPX 1.2 "bewaar". Geen probleem dus. De Connector is een vorm van luxe die niet écht nodig is (voor mij).
                        @Rob-Verhoeff
                        @Dikke-Wim
                        Ook dat werkt, en dan in de map GPX opslaan op de Navigator
                        Dikke Wim
                        Dikke Wim
                        Richard Ward
                        Richard Ward
                        • Route wordt afgesneden
                          Wim Hompes
                          Wim Hompes
                          Pierre c
                          Pierre c
                        • OSM Routing with MRA
                        • reuse pictures
