  4. Battery drain when navigating
57 Posts 22 Posters 1.0k Views 8 Watching
  • richtea999 richtea999
    You might want to consider using Dark Mode next time, although judging by that screenshot, you may already be there!
    Change both Map layer and App theme in the Navigation Settings. The Map layer one doesn't kick in until you actually start navigating, so ignore the default map view being, confusingly, light mode!
    Paul 41
    Paul 41
    Paul 41
    @richtea999 I’ll try that, although using Low Power mode solved the issue. I wish I knew what MRA was doing to consume so much battery though.
    • Paul 41 Paul 41
      @Paul-41 a lot of battery drain is due to the rendering the maps on your device when online navigating. I guess the rendering remains although you've downloaded maps. The mapsupplier (Here) has to do (also) something to solve this. Google for 'battery drain' on this forum and you'll find more topics. It's under the attention of the MRA-team.
      • richtea999
        #49
        @Paul-41 said in Battery drain when navigating:
        Probably redrawing the screen too often is my guess. However, that's easily written in a glib message like this, and a nightmare to fix as a developer!
        One setting that might be useful would be a choice to decrease the app's screen refresh rate, so 1/5th second, 1/10th second, etc, so users could feed back on their findings. Maybe just in the beta.
        I have to say I couldn't use my iPhone because it overheats and dims the screen, so I'll also be trying low battery mode this afternoon/evening. I had the same problem on a new Samsung Galaxy A54 this past weekend, so I'll also be experimenting that one too, at some point.
          @richtea999, I happen to know that this has been tried, to as low as 40fps. It did not make any significant difference for the battery drain. It looks like something in the SDK is maxing out the processor. Slower phones seems to have less problems with battery drain, but that too is not always fully true.
          • richtea999
            @Con-Hennekens Thanks for the update Con. My bad guesswork.
              @richtea999, I don't think it is bad guesswork at all 😉 It makes perfectly sense, but was already guessed by someone else before. Somehow it does nothing to the battery drain, and that surprised the devvers too. I will not be surprised when that turns out to be part the problem: the rendering engine does not limit itself to the set screenfrequency...
              • Simannjo
                Simannjo
                Simannjo
                Any advances on battery drain issues?
                Like the OP, I am using a quadlock wireless charger on Pixel 6 Pro and with 2.4a USB supply that just cannot keep up...
                • Simannjo Simannjo
                  @Simannjo Still under investigation. I think Here has to come up with a solution.
                  richtea999 1 Reply Last reply
                    @Rob-Verhoeff Is there anything that users can do to help? A little direct customer pressure often hastens a result.
                    However, I don't want to step on MRA's feet, and sour their HERE relationship, of course.
                      #56
                      @richtea999 I think Corjan is on top of this issue. In all honesty, I don't think that we can't do more than what's done as far.
                      • Stephen Rowland
                        Stephen Rowland
                        Stephen Rowland
                        I have been out this morning to have a nice ride in the UK heatwave. Very happy with the newest update. Firstly, I now have sufficient volume in my Sena Intercom. Secondly the phone didn’t overheat (although it was hot) and actually charged up to 99% by the time I got home. The motorway signs are good too.
                        Arno 0
                        Arno 0
                        infoevertkuiken.nl
                        infoevertkuiken.nl
                        Stephen Rowland
                        Stephen Rowland
                        Maarten v
                        Maarten v
                        Mopetenpit
                        Mopetenpit
                        M PRP
                        M PRP
                        Paul 41
                        Paul 41
                        Ad Koppenol
                        Ad Koppenol
                        Flat Twin Therapy
                        Flat Twin Therapy
                        Jure Sirena 0
                        Jure Sirena 0
                        Simannjo
                        Simannjo
                        Karl Mumford
                        Karl Mumford
                        Willy DEOM
                        Willy DEOM
                        • Map lock
                          tfdahazellgmail.com
                          tfdahazellgmail.com
                          98
                        • Beta abonnement
                          BMW1300GSA
                          BMW1300GSA
                          2.3k
                          Gerard van der Veer
                          Gerard van der Veer
                          520
                        • Uitnodiging
                          Hanza 0
                          Hanza 0
                        • Suggestion: Make the layer icon permanently visible
                          Hans Kremers
                          Hans Kremers
                        • SilverFox Controller C2
                          Hans Lamers
                          Hans Lamers
