  3. [Beta] Announcements
  4. New Beta! (v4.0.3) Motorhome & Motorcycle
59 Posts 16 Posters 796 Views 4 Watching
    @Doug-Robinson the zoom correction really just slightly zooms in / out. However, the difference between “—“ and “++” is a full zoom level (quite much).
    If the app zoom wasn’t an issue for you, leave it as is.
    If you however always prefer a bit more / less zoom, this is the place to be.
    Besides this option, we improved the app zooming when driving faster >60kph or on the highway. We then zoom out slightly more as community (and personal) opinion was that the app would be zoomed in too much on highways. This cannot be turned off.
    Lynchy67
    Lynchy67
    Lynchy67
    #30
    With this 4.0.3 update I am now getting the following screen regarding Google?
    I am aware others had this in the previous version.
    Should I ignore it and select No?
    Previously my location has been very accurate on Android.
    I can’t get out on the bike to test until tomorrow.
    Nick Carthew Corjan Meijerink 2 Replies Last reply
    • Lynchy67 Lynchy67
      @Lynchy67 If you answer yes, Google will then require further information - shoe size, favourite colour, what you had for breakfast etc etc 😅
      Lynchy67 1 Reply Last reply
        Lynchy67
        Lynchy67
        Lynchy67
        @Nick-Carthew
        Thanks for the clarification Nick.
        Just wanted to be sure.
        • Lynchy67 Lynchy67
          @Lynchy67 yeah, enable it!
          But did you have issues before? I only expect people that had the annoying popup about Google before to see this prompt.
            Lynchy67
            Lynchy67
            Lynchy67
            #34
            No I never had this issue before with any previous updates.
            It appeared with v4.0.3
            I also have an iOS Next account, so considering getting an iPhone.
            • Lynchy67 Lynchy67
              @Lynchy67 thanks! You should have at some point then also seen a notification that the Google services were disabled.
              However, I will make some tweaks based on your response 🙂 As you did not have the issue before, your Google services should not have been disabled.
              • richtea999
                @Lynchy67 said in New Beta! (v4.0.3) Motorhome & Motorcycle:
                Normally you'll see that if 'Google Location Accuracy' is off (found in the Location -> Location services settings of Android).
                When disabled, it used to lock you out of the app. Not any more - so that's a great improvement. 👍
                If you don't want to see it, then press 'Yes' and it will lead you to enable the Google Location Accuracy.
                • richtea999
                  However, for Corjan's benefit, although it's no longer locking you out, the app-based popup (rather than Google's) does continue to nag you:
                  • on restarting a route
                  • on stopping a route
                  • cancelling a selected route (i.e. not pressing 'Start')
                  • tapping anywhere in the default map with no route selected yet
                  It would be nice to remember the users choice, either once per app startup, or even in an app setting somewhere so the nag isn't repeated quite so often.
                  But there are more important things to work on. Just bringing it to your attention.
                  • richtea999 richtea999
                    @richtea999 thanks for calling it a great improvement! 🙂
                    Happy you tested it.
                    I assume there is an issue with the Google location services if the app doesn’t know where you are after 5 seconds. I guess Steve had bad reception when first opening the update and this assumption was then therefore wrong.
                    For the release I’ll either increase this duration and research more if I can actually tell if the services were disabled 🙂
                      @Corjan-Meijerink, I am thinking it has to do with how far you are from routable roads. I had this "problem" too on vacation, on the camping site. Now I am at home, and close to my street, the problem seems to be gone. I am thinking the API assumes not enough accuracy if not near a routable road, and tries to improve it with a less accurate method of location (scanning wifi...)
                      • Arno 0 Arno 0
                        If you turn off the use of toll roads while in camper transport mode, it also turns off the use of highways. This is only in camper transport mode and not in car or motorcycle transport mode.
                        Arno 0
                        Arno 0
                        Arno 0
                        @Arno-0 said in New Beta! (v4.0.3) Motorhome & Motorcycle:
                        Can someone please reply on this comment. This was also mentioned in another topic but als no reply there. I think this is a fault and can maybe be solved before the official release.
                        • Arno 0 Arno 0
                          @Arno-0 thanks! I believe the app does it correctly, might be something with HERE! I’ll check next week 🙂
                          Arno 0 1 Reply Last reply
                            Arno 0
                            Arno 0
                            Arno 0
                            wrote on last edited by Arno 0
                            #42
                            @Corjan-Meijerink Thanks that you will check. The problem is in the app.
                            • Arno 0 Arno 0
                              @Arno-0 I’ll let you know 😉
                                Arno 0
                                Arno 0
                                Arno 0
                                #44
                                @Corjan-Meijerink I’ve just checked and it’s a problem in both the MRA Next app and in the MRA Routeplanner. Thanks for letting me know 👍
                                • Arno 0 Arno 0
                                  @Arno-0 that is interesting info! Then it will most likely be an issue with HERE as our app and website are very different implementations of HERE 🙂
                                    @Rolf-Engelsman Dank voor het delen - de gegevens komen direct uit HERE! 🙂 Wij hebben hier verder geen invloed op helaas.
                                    Fouten kunnen hier gemeld worden: https://mapfeedback.here.com/#/report Grappig dat het een berucht punt is. Dan is HERE niet de enige met onjuiste gegevens.
                                    Rolf Engelsman
                                    Rolf Engelsman
                                    Rolf Engelsman
                                    @Corjan-Meijerink bedankt voor je reply. Ik heb dit gemeld via jouw linkje.
                                    • Nick Carthew
                                      The thinner yellow track line is a great improvement. The blue route line is visible when travelling along a previously used road. Thanks @Corjan-Meijerink 👍
                                        A quick statement about the app ignoring highways while using the camper mode and you are avoiding tolls only.
                                        I've reached out to HERE and got the following response:
                                        Thank you for reaching out to us.
                                        After having ran a quick check with our refClient, I'm also a bit surprised about the behavior and cannot imagine that this is really working as expected.
                                        I will create an internal case with our Routing Team and address this issue to them.
                                        Once I have news, I'll let you know.
                                        TLDR; The issue is with HERE and will hopefully be resolved very quickly!
                                        @Arno-0 thanks for reporting!
                                          @Nick-Carthew thank you. I'll have to play with the zoom setting to see what the impact is. I always felt that the zoom level was too high allowing a look down the road of only about 300 m. I prefer 1 to 2 km.
                                          I look forward to a time when certain settings, such as route options (avoid options for example), can be saved and automatically loaded based on selected travel mode. I tend to use different options when traveling by car vs motorcycle.
                                          @Doug-Robinson completely agree. 300m at 60 kph (stated in a comment above) may be enough, however, not at 100 kph or more.
                                          Knowing the distance each click of the zoom (in or out) is, would be helpful knowledge as well.
                                          Rolf Engelsman
                                          Rolf Engelsman
                                          Arjan de Vries
                                          Arjan de Vries
                                          Arno 0
                                          Arno 0
                                          Edgar Hofer
                                          Edgar Hofer
                                          Lynchy67
                                          Lynchy67
                                            141
                                          • Vergrendel scherm zet alles op z'n kop
                                          • Hallo, wéér een nieuwe gebruiker !
                                            4.7k
                                            Jörg Neudert
                                            Jörg Neudert
                                            5.2k
