  4. Starting location for new route
8 Posts 4 Posters 2.0k Views 1 Watching
  • Tony Doms Offline
    Tony Doms Offline
    Tony Doms
    Hello, I am brand new to this, I note in a tutorial when you start a new route the tutor says the map will open up at your location, my one opens up to a world map, how do I set it up to open at my location, i.e. my home town or address, or is that facility not available in Basic
    Hans van de Ven MR.MRA Con Hennekens 2 Replies Last reply
    • Tony Doms Tony Doms
      @Tony-Doms
      Yes, you can set that up on your PC / Phone.
      You must give permission to use your current location.
      Tony Doms 1 Reply Last reply
        @Tony-Doms, Using Chrome?
        https://support.google.com/chrome/answer/142065
          @Tony-Doms
          Tony Doms Offline
          Tony Doms Offline
          Tony Doms
          @Hans-van-de-Ven-MRA-Master Thanks for this, I see one answer is to change the security settings in Chrome, is that your recommendation also? or can this be done through MRA? if so where do I need to go to find the setting?
            Tony Doms Offline
            Tony Doms Offline
            Tony Doms
            @Con-Hennekens Thank you, I have checked and my Chrome permission already allows sharing of my location, when I open a new route it still takes me to a general map nowhere near my location, what am I missing here?
              @Tony-Doms
              Search for location settings in chrome.
                @Tony-Doms
                @Hans-van-de-Ven-MRA-Master said in Starting location for new route:
                That was already suggested 3 messages above and confirmed not to be of help 😉
                Obviously your computer or your browser does not know where it is...
                If you visit this webpage, what doe you see?
                Do you by any chance use a permanent VPN?
                Jurassic Mike 1 Reply Last reply
                  Jurassic Mike Offline
                  Jurassic Mike
                  @Con-Hennekens I am having the same problem, as well as a lot of others. I have checked and MyRoute App is listed as having access to my location in my browser. Did you find out how to default it to your location?
                  Jurassic Mike
                  Jurassic Mike
                  Tony Doms
                  Tony Doms
                    Thomas Schäfer
                    Thomas Schäfer
                    Kobutex Motorreizen
                    Kobutex Motorreizen
                  • opslaan naar plantomtom
                    chris 18
                    chris 18
                    398
                  • Welke instelling
                    chris 18
                    chris 18
                    928
                  • App loopt vast
                  • Seizoen sluitingen wegen
                    PAT62
                    PAT62
                  • I can't see Road Closures
