  4. Skip way point works but should be easier to use
7 Posts 4 Posters 123 Views 1 Watching
  • Kenneth de Miranda Offline
    Kenneth de Miranda
    I’ve tested the skip waypoints, it works fine. But in stead of skipping each waypoint ( for example 10 times if I want to skip to 1@), it would be nice to enter an waypoint number where to start the route
    Nick Carthew Corjan Meijerink 2 Replies Last reply
    • Kenneth de Miranda Kenneth de Miranda
      Nick Carthew Offline
      @Kenneth-de-Miranda Touch the route point that you want to skip to and it will skip to that route point.
        Corjan Meijerink Offline
        @Kenneth-de-Miranda simply long press the desired waypoint on the map or the entry in the waypoint list (which can be opened using the menu) 😉
        Kenneth de Miranda MarcM 2 Replies Last reply
          Kenneth de Miranda
          @Corjan-Meijerink aha, there you go! Brilliant, thanks!
          MarcM 1 Reply Last reply
            MarcM Offline
            MarcM Offline
            MarcM
            @Corjan-Meijerink Will work / Works in Carplay too?
              MarcM Offline
              MarcM Offline
              MarcM
              @Kenneth-de-Miranda On your mobile phone or in Carplay?
              • MarcM MarcM
                @MarcM This will also be added to CarPlay natively! 🙂
                While connected to CarPlay you can still use your phone to skip.
                MarcM
                MarcM
                Kenneth de Miranda
                Kenneth de Miranda
                  9.6k
                • Map definition/ clarity
                  309
                  1.0k
                • Startpagina Route Lab
                • Useful Speed Camera Information
