  4. CarPlay - Icon Position
6 Posts 2 Posters 50 Views
  • Frappawotsitundefined Offline
    Frappawotsit
    wrote on last edited by Frappawotsit
    The Triangle icon showing your own position is not in the lower centre as it should be (as with other mapping software) instead it's on the right hand side lower, with itself and route ahead almost entirely hidden by the information banners on the screen. I don't know if this is particular to the UK with right hand drive cars, or if all instances are the same.
    When manually moving the screen, as soon as you select "done" the screen moves back to it's default position on the right side hidden by the information banners.
    Currently this is making the app un-useable with Car Play. It's worth noting that the icon is correctly in the lower centre when not connected to CarPlay and just using the Navigation app on the phone.
    • Frappawotsitundefined Frappawotsit
      @Frappawotsit we still need to take UK oriented devices into account πŸ™‚
      Frappawotsitundefined 1 Reply Last reply
        Frappawotsit
        @Corjan-Meijerink Thank you, I did think this may be specific to right hand drive cars as the information banners are on the opposite side of the screen.
        Is this something that's being actively developed, or is it likely to be a low priority and therefore slow progress?
          @Frappawotsit I’m sorry, but you use the old MRA Navigation app - not the Beta πŸ˜‰
          It will be fixed before release for sure! It’s important πŸ™‚
            Frappawotsit
            @Corjan-Meijerink my apologies, thanks.
              @Frappawotsit no need to apologise! Your point is still valid πŸ˜‰ The current Beta won't support this correctly either - but as said we will make sure this is fixed in one of the coming updates!
              Frappawotsit
                Nick Carthew RouteXpert Seniorundefined
                115
              • MRA connector - Zumo XT (+SD)
                Guztundefined
                Guzt
                Cookie On Tourundefined
                Cookie On Tour
                23
                18
                932
              • Routepunten automatisch overspringen
                white.mouseundefined
              • Symbolen
              • Carpe Iter BMW Controller issue
                Steve Jarrellundefined
                Steve Jarrell
              • OU peut on changer les couleurs de la route
                LE DIZES Freddyundefined
                LE DIZES Freddy
