  3. WAYPOINT
WAYPOINT
5 Posts 5 Posters 1.1k Views 1 Watching
  • MASSIMO PIACENTINI 0
    I DONT' SEE THE WAYPOINT IN THE GPS , IS THERE A WAY TO SEE THEM? THE TRACK IS RIGHT AND I FOLLOW GPS FROM START TO THE END, BUT I'D LIKE TO SEE ON GPS ALL THE WAYPOINT THAT ARE IN THE TRACK, BUT I DON'T SEE THEM ON GPS WHILE RIDING, SOMEONE CAN EXPLANE? THANK YOU.....AND EXCUSE ME FOR MY ENGLISH...
    HABVEN aka MrMRA Ray Blighe 0 johnnienicosia 3 Replies Last reply
    • MASSIMO PIACENTINI 0 MASSIMO PIACENTINI 0
      @MASSIMO-PIACENTINI-0
      Hello Masimo,
      Some questions to clarify your question:
      1. What kind of Navigation System do you use?
      2. Do you use the route or do you use the track?
      3. Would you like to share the url of your route here, make sure it is public.
        Ray Blighe 0
        Ray Blighe 0
        Ray Blighe 0
        @MASSIMO-PIACENTINI-0 Hi. I had similar problem, then someone said to change your points in your route from the upside down pear shape to a hand. Click on the route point to open to options box, then the 3 small dots in top right of the box, you will see a hand shape, click that and it will change your route point to a way point.
        That's how I do it and it works for me.
        Hope this helps.
        Scimmy 1 Reply Last reply
          johnnienicosia
          johnnienicosia
          johnnienicosia
          @MASSIMO-PIACENTINI-0 drift boss said in WAYPOINT:
          You can try clicking on the View Destinations button or the Find Destinations button to see waypoints
          • Ray Blighe 0 Ray Blighe 0
            Hope this helps.
            Scimmy
            Scimmy
            Scimmy
            wrote on last edited by Scimmy
            @Ray-Blighe-0 quindi i punti di interesse (waipoint) se li metto tutti con la manina ( ✋ ) funzionano ? e li vedo sul Garmin Zumo 595
            Scimmy
            Scimmy
            johnnienicosia
            johnnienicosia
            Ray Blighe 0
            Ray Blighe 0
            • Rangen
              Pim van Dongen
              Pim van Dongen
            • Informatie Routeplanner Next
            • HELP! The Pyrenees Tour
            • How do I get to the support page?
            • Private POIs
            • Can not move WP
            • Route-plan PDF: detailed map working, but some long directions are clipped
            • A19 Quick info about the WP incl. I miss the picture
