  4. "Taschenrechner" while biking? Translation needed !
5 Posts 3 Posters 56 Views
  • Ronni
    Ronni
    Ronni
    I had never understood why I should use a calculator when riding a motorcycle. 🤔 (In German you need it to calculate more difficult mathematical functions 😊 ) So i opened that item in the toolkit menu of HERE. and discovered a great function. I can calculate the distance and time between 2 waypoints on my tour. Very good, I've always missed that.
    I would therefore rename the menu item because it sends you in the wrong direction
    Replace "Taschenrechner"--> with "Streckenberechnung".
    In addition, i would also adjust the following points:
    • In the sentence "Berechnen Sie die Entfernung und Zeit zwischen" I would drop the word "die" before "Entfernung". Sounds better in German, and
    • Replace "Zeit" --> with "Dauer".
    • The text in the button "Berechnung durchführen" should be left-aligned so that the text fits in one line. Or / And extend the background of the switch a little more to the right.
    • Drop "in Kilometer" from the white result block. That's already behind the numbers!
    • replace "Entfernung in Zeit" with "Dauer".
    • The English spelling of "0h 8m" should be replaced with "00:08 Std."
    • The separator at "43.60 km" in German is a comma "," and not a period "."'
    • In the PC version the grey "Entfernung" and "Dauer" fields are slightly up to fit in the white block.
    • In the app version, the white block overlays the switch label. However, if this is left-justified in a line, as described above, this problem is also solved.
    Because it's a lot of stuff in writing, I've roughly adapted it as a drawing. I hope this can be understood in a better way than my bumpy descriptions. (I just see, i forgot the icons in the white box )😖
    Greetings and Helau 💃 🕺 ✌ 🎸 🎤 🎭 🎆 🎇 🎹 💋 😌
    Ronni
    My Suggestion
    PC-Version
    App-Version
    Samsung Galaxy A56 5G
    Android 16
    One UI Vers. 8.0
    Carpuride W712D
    Silverfox BT Cntroller H1+
    • Jörgen
      Hi, thanks for all the suggestions for correct German. You just have to keep one thing in mind, in German everything is always much longer and gives the app makers a big headache to get everything on the screen. If possible, always suggest the shortest option. 👍
      We should get together and talk about the app, we only live a few kilometers apart.
      Ronni 1 Reply Last reply
        @Ronni Once again, thanks so much again for the improvements. I will definitely implement these in the coming week.
        @Jörgen said in "Taschenrechner" while biking? Translation needed !:
        Thanks for saying that, it can indeed be very annoying how a short word in English becomes a whole sentence in other languages 😉 This statement therefore is very true: shorter = better
        • Ronni Ronni
          Ronni
          My Suggestion
          PC-Version
          App-Version
          @Ronni I made sure most changes will be applied in the next website update. However, some changes are not possible.
          Those are not possible as the website does not support this 😞
          All textual improvements will be applied next week! 🎉
          Thanks for the feedback.
          • Jörgen Jörgen
            Ronni
            Ronni
            Ronni
            Hi Jörgen, I'll have this in mind next time. 👍
            Hi, Jörgen, gerne. Ich schick Dir ne PN mit meiner Telefonnummer, dann können wir ein Treffen gerne absprechen.
            @Corjan-Meijerink said in "Taschenrechner" while biking? Translation needed !:
            Hi Corjan, I almost thought so. Perhaps it is possible just to replace the english "h" = hour with "Std." = Stunden?
            As fast as ever. 👍
            Greetings
            Ronni
            Android 16
            One UI Vers. 8.0
            Carpuride W712D
            Ronni
            Ronni
            • Strange translation
            • Undo/Redo tool is hidden
            • Crazy routing
            • Which route is shown?
              martin-phogel.de
              martin-phogel.de
              10.4k
