  3. Date code for file sorting.
13 Posts 4 Posters 2.1k Views 2 Watching
  • UltraStarundefined Offline
    UltraStar
    I was wondering if there would be a chance to change the date codes format on the saved routes/tracks, etc.
    The format: yyyymmdd would be preferred for the easier sorting of the files by date.
    Corjan Meijerinkundefined infoevertkuiken.nlundefined 2 Replies Last reply
    • UltraStarundefined UltraStar
      @UltraStar In the title of the tracklog we could make this use the date preference of the device as this concerns the Mobile app.
      The second (right) date you highlighted cannot be changed unfortunately due to legacy reasons. However, if you scroll to the top, and click on this column title, you can sort on that date. The availability of this sort might depend on your screen resolution. On desktop it for sure works 🙂
      UltraStarundefined 1 Reply Last reply
        UltraStar
        @Corjan-Meijerink I understand. The mostly I was concerned about the Name column (I have misspoke before mentioning sorting by the date the date.) If you change the date format in the name, the files with the date in the name would be sorted in order they were saved without a need to sort by date. I often change the names of the tracks to something descriptive, and now I have to hunt for the files that were automatically saved. If I record the track on the 4 of every month, year, they all will be clustered together.
        Again, it is not a deal breaker 🙂 ,just a little more work.
        Thank you.
          Thank you.
          UltraStar
          @UltraStar Oh, one more thing. I do not know if this is easy to do; it would be nice if we had a first row "frozen" (like in the excel) to see the titles of all the columns when we scroll down. I know, I am pushing it again. 🙂 🙂 🙂
            Hahaha, thanks. No worries 🙂
            I’ll check this somewhere!
              infoevertkuiken.nlundefined Offline
              infoevertkuiken.nl
              @UltraStar yes! Use yyyymmdd or with hyphens yyyy-mm-dd and maybe the name of the route instead of just “tracklog “. And when riding A to B the destination town. So “2023-02-14 Zutphen” for my first trip today instead of “Tracklog 14-02-2023”.
              • infoevertkuiken.nlundefined infoevertkuiken.nl
                UltraStar
                @Evert-Kuiken Thank you, I understand. The idea was that one does not have to enter the name of the track, just use the default and deal with it later.
                When I finish the ride/track, I do not want to deal with the writing the name of the track on the phone; in my age I can barely see the phone. 🙂
                infoevertkuiken.nlundefined 1 Reply Last reply
                  infoevertkuiken.nl
                  @UltraStar 😂 I have the same issue...👓
                    @Evert-Kuiken
                    Would be nice if the track takes over the route name.
                    I always use (mmdd From A to Better)
                      This has been fixed in the upcoming update!
                        infoevertkuiken.nl
                        @Corjan-Meijerink Tracklogs now are named “Tracklog 2023-04-08”. Can you also eliminate the “Tracklog” part in the name? Would make it even easier for me. And you now a Tracklog is a Tracklog because it is in the Tracklog section of MRA, so why put it in the name also? Do you name all your routes “Route blablabla “?
                          @Evert-Kuiken quite often yes 😉 I’ll have a look at another moment in time.
                            infoevertkuiken.nl
                            @Corjan-Meijerink 👍 There are of course issues with a higher priority...
                            infoevertkuiken.nl
                            UltraStarundefined
                            UltraStar
                              M. Schrijverundefined
                              178
                            • wrong routing
                              John S Parryundefined
                            • Veekeersinfo en omleiden
                              marko 11 0undefined
                              marko 11 0
                              342
                            • Updated beta! 5.2.1 (486)
                              Nick Carthewundefined
                            • Request login credentials
                              Aiello antoninoundefined
                            • Move blocks of routepoints
                              Yannick_van_Vugtundefined
                              Yannick_van_Vugt
