  4. Offline maps
Offline maps
19 Posts 8 Posters 395 Views 1 Watching
  • Tom Wilmotundefined Offline
    Tom Wilmot
    Can’t see this as an existing topic. Is offline maps a feature of the beta yet? First 2 things I did on install was try to download offline maps and set up favourites. I can’t find how to download offline maps and I can’t work out how to rename a favourite so I’m not off to a great start!
    Corjan Meijerinkundefined Con Hennekensundefined 2 Replies Last reply
    • Tom Wilmotundefined Tom Wilmot
      @Tom-Wilmot Offline maps is currently being worked on! We expect this to be finished within February 🙂
      Renaming favorites is not yet supported within the app yet, something that will definitely be added later!
      Tom Wilmotundefined 1 Reply Last reply
        @Tom-Wilmot, it would be a pity to base your first impression on a beta. Many things are still being implemented. Patience is a virtue 😉
        @Corjan-Meijerink, I was trying to find a timeline or planning for Next to show Tom. I've seen it, but can't find it. Maybe pin a message in the forum with a link to it?
          Rob Verhoeffundefined Offline
          @Con-Hennekens said in Offline maps:
          The only timeline vissible is the roadmap on this page:
          https://mranavigationnext.app/roadmap/
            @Rob-Verhoeff Which needs some updating from our side 😉
              The word "roadmap" did not come to mind at the time 🤕
                Tom Wilmot
                @Corjan-Meijerink great to know. Thank you
                Do not fear - I’m well aware of the limitations of beta apps so will keep coming back to it! I’ve invested in Gold so I want it to be a success! Thanks for the reply and keep up the good work.
                  @Tom-Wilmot Thanks! 🙂
                  • Walter Coadyundefined Offline
                    Walter Coady
                    I'm not sure if I'm in the right area. If not please point me in the right direction. I cannot download offline maps. I thought I had posted the screen shots from my phone but never got a response, or I have overlooked a response.
                    • Walter Coadyundefined Walter Coady
                      Nick Carthewundefined Online
                      @Walter-Coady Open the app and click the menu (3 horizontal lines top left)
                      Now click the settings icon (top right)
                      Offline maps are below Navigation Settings.
                      Walter Coadyundefined 1 Reply Last reply
                        Walter Coady
                        @Nick-Carthew Nick, I'm aware of how to navigate to offline maps, here are the steps just in case I missed a step. The app will not allow me to download them.MyRoute1.jpegI press the three lines and get this screen >MyRoute2.jpeg I then press the figure in upper right MyRoute3.jpeg Then select off line maps MyRoute4.jpeg and then get the following!My Route 6.jpeg
                          @Walter-Coady I’d recommend restarting the app completely. If that doesn’t help try reinstalling.
                          Patrick Roozen 0undefined 1 Reply Last reply
                            Patrick Roozen 0undefined Offline
                            Patrick Roozen 0
                            @Corjan-Meijerink I don't want to hijack this thread but I have downloaded the offline maps I wanted in the Beta version (currently 3.2.10). That worked for me, but I cannot enable the offline maps. I have restarted the app and I have also reinstalled the app (and had to redownload the offline maps). But I still cannot enable the offline map use.
                            Actually the only switches that can be enabled are the ones that are already enabled in the image above.
                            iPhone 15 iOS 17.6.1
                            • Patrick Roozen 0undefined Patrick Roozen 0
                              @Patrick-Roozen-0 Offline routing (which is what the switch does) is disabled on purpose. Offline maps are already supported but you still require internet to (re)calculate routes.
                              Once that is supported - the offline mode preference will be enabled to toggle 🙂
                                Patrick Roozen 0
                                @Corjan-Meijerink Thanks for the clarification!
                                  @Patrick-Roozen-0, An attempt to clarify any further: Offline navigation is not equal to offline maps. Offline maps wil be used in preference to online maps as it already stands. Offline navigation will enable starting a route without having an internet connection available. As it stands that needs yet te be implemented, but offline maps are available, so losing the internet connection while navigating will still work.
                                  • Patrick Roozen 0undefined Offline
                                    Patrick Roozen 0
                                    @Spili Look in this thread to see if that helps you.
                                    Spiliundefined 1 Reply Last reply
                                      Spiliundefined Offline
                                      Spili
                                      @Patrick-Roozen-0
                                      Thx.
                                      Same problem as here...
                                      Something went wrong.
                                      Even after reinstall app...
                                        @Spili I've sent you a personal message
                                        Spiliundefined
                                        Spili
                                        Tom Wilmotundefined
                                        Tom Wilmot
                                        Patrick Roozen 0
                                        Walter Coady
                                          Gianluca 0undefined
                                          Gianluca 0
                                          146
                                        • v5.2 (473) Feedback
                                          white.mouseundefined
                                          Lenny Oundefined
                                          Lenny O
                                          1.2k
                                          nomkoundefined
                                        • Permanent afgesloten wegen voor motorrijders
                                          Leike Lodiersundefined
                                          7.8k
