  3. WayPoints
WayPoints
4 Posts 2 Posters 813 Views
  • Martin Proudlove
    Martin Proudlove
    Martin Proudlove
    Is there a way to save POI`s or other waypoints rether than in a route?
    • Martin Proudlove Martin Proudlove
      @Martin-Proudlove
      Did you look at the Support section?
      There us a nice support article:
      Manual POI's
      But for some functions you need a Gold account.
      Martin Proudlove 1 Reply Last reply
      • TorqueRider TorqueRider
        @Martin-Proudlove
        Manual POI's
        Martin Proudlove
        Martin Proudlove
        Martin Proudlove
        @Jack-van-Tilburg Hi. So I can add them as I create a route. What I want to do is have a list or folder of POIs that I use requally
          @Martin-Proudlove
          It's some work but doable.
          Create a new route give it the desired name from the POI list and place your POIs as described in the manual.
          When you have placed all points, you export this file via the <Save as> menu according to the type "OV2" or "CV". (remember the location on the PC)
          Now go to <Routelab> and start the <Upload> menu. Use the POI tab and upload the file. (Or follow the instruction "C" in the support article.)
          You can then find your POIs in the Library tab in the <Points of interest> menu.
          Martin Proudlove
          Martin Proudlove
          • Strange translation
            35
            martin-phogel.de
            martin-phogel.de
            10.5k
          • Undo/Redo tool is hidden
          • Crazy routing
          • Which route is shown?
