  4. No spoken instructions
16 Posts 5 Posters 341 Views 1 Watching
    The app should ignore the "silent mode" setting but maybe that is causing the issue. Check if the slider on your iPhone is not in silent and repeat again 🙂
    For Android, there isn't a slider as on the iPhone but I would recommend checking the individual volume settings.
    For all platforms: the default audio output is used (configuring this will be a future update). This means that if no devices are connected, sound is played over speakers. Otherwise a bluetooth or physical device will be used to play the sound on.
    Andre Muller
    Andre Muller
    Andre Muller
    @Corjan-Meijerink Thanks Corjan for your response; I have all iphone 12 sound controls enabled. Mute Switch on side is enabled as well as the volume slider is set to max but still no voice prompts. In the original Navigation app by myroute voice prompts work fine on my iphone…………
    Andre Muller 1 Reply Last reply
    • Andre Muller Andre Muller
      Andre Muller
      Andre Muller
      Andre Muller
      @Andre-Muller Corjan, quick update; I reset my iPhone and now it works. I now get a slow male voice 👍
        Super! In a future update the voice will be configurable
          Andre Muller
          Andre Muller
          Andre Muller
          @Corjan-Meijerink Unfortunately the voice prompts only worked once on my iPhone 12 Pro after reset. Since today again silence, even after another reset. There is definately something wrong with voice prompts / audio warnings on an iPhone 12 Pro
            @Andre-Muller Thanks for letting us know!
              Andre Muller
              Andre Muller
              Andre Muller
              @Corjan-Meijerink Also in the latest version I have no spoken instructions or warnings. Just to clarify, I have so far used the app to navigate from A to B using Here map. During navigation I see the same issues as what others quote on this forum, but am I the only one that gets no spoken instructions or audio warnings? In the old Navigation app this works just fine for me, but in the new app I only get silence………and yes I have toggled the switches under settings 😁
                @Andre-Muller Interesting, we will try to investigate a bit more 🙂
                Hubert Thoring Andre Muller 2 Replies Last reply
                  @Corjan-Meijerink : Hallo @ll, dieses zur Info,
                  ich habe ein iPhone Xr, das Thema Ansage hat mich auch schon mehrmals etwas beschäftigt. Da ich eigentlich das Handy immer auf "Stumm = kein Klingelton" stehen habe geht man davon aus das eine App MRA Navigation Next App, die navigieren soll den Lautsprecher automatisch normal nutzt oder Bluetooth und gekoppelte Geräte verwendet, aber das scheint wohl nicht so zu sein.
                  Also: Mal versuchen das Telefon nicht auf "Stumm = kein Klingelton" zu stellen und dann mal das Routing starten und versuchen....., hier lag bei mir der Hase im Pfeffer vergraben.
                  Hello @ll, this for info,
                  I have an iPhone Xr, the topic of announcements has occupied me several times. Since I actually always have the cell phone set to "mute = no ringtone", one assumes that an app MRA Navigation Next App that is supposed to navigate automatically uses the speaker normally or uses Bluetooth and paired devices, but that doesn't seem to be the case .
                  So: Let's try not to set the phone to "mute = no ringtone" and then start the routing and try....., here was the rub in my pepper.
                    Andre Muller
                    Andre Muller
                    Andre Muller
                    @Corjan-Meijerink Today I ‘solved’ the issue. When I switch bluetooth completely off on my iPhone 12 Pro, voice instructions and audio warnings work fine in the new app. As soon as I switch bluetooth on, but according to my iPhone NOT connected to any device, the audio stops working. The same test with the old Navigation app does not give this problem and voice instructions continue irrespective of whether bluetooth is switched on or off. Hope this helps looking for the solution……….
                      @Andre-Muller Thanks for the input!
                        The upcoming update has significant improvements with regards to fully completing voice instructions! We aim to release this update in the end of this week 🙂
                          @Corjan-Meijerink Danke !
                          Andre Muller
                          Andre Muller
                          Donald Prieur
                          Donald Prieur
                          • Units of Measurement
                            Jack 13
                            Jack 13
                          • Weather as a service
                            Tegel Werner
                            Tegel Werner
                          • Eindtijd zichtbaar.
                            Andy Smith 5
                            Andy Smith 5
