  4. Next: Suggestion - Skip button on Navigation front page
15 Posts 8 Posters 199 Views 2 Watching
  • UltraStar
    UltraStar
    UltraStar
    @Nick-Carthew I think I have read somewhere that the time to the waypoint might be turned off. I have not tried it yet. It would be a good option though, When I create a route, I always use lot of shaping points; I do not want to play by chance and let the navigator, whichever it is, alter my route. So, the distance to the next point is irrelevant for me. I like the selection on the bottom giving me different option.
    If I turn off the icon display at the top-right corner, the only option for me would be the long press on the point and start the route from here (that option I would leave for the time when I am parked, I would not want to fiddle with it while riding a bike,) or opening the Setting menu to quickly skip waypoint; in this case I would definitely like the Skip waypoint button to be readily available, not buried somewhere down.
    I've got to play with it more to see what is more comfortable, and quick, while riding.
    Thanks a lot for your help.
    ASPK 1 Reply Last reply
    • UltraStar
      UltraStar
      UltraStar
      @Nick-Carthew I just observed something funny. I have started a route (I was by the waypoint 1.) For the heck of it, I have pressed Skip waypoint button. The popup window asked if I want to skip waypoint 3? Strange; it is the same thing that happened to me before, I could not skip the point.
      Also, after I have stopped the navigation, the application was still running, I am guessing using a GPS (Blue highlight of the time on the iPhone 11P in the top-left corner.) (?!)
      I got read of it restarting the navigation and terminating it again.
      • UltraStar UltraStar
        Hi @UltraStar This is way beyond my pay scale. I think we need @Corjan-Meijerink to see and answer this.
        Thanks for taking the time to share your findings.
        Alderweireld Rudi 0 1 Reply Last reply
          Alderweireld Rudi 0
          Alderweireld Rudi 0
          Alderweireld Rudi 0
          @Nick-Carthew Nu jullie het toch hebben over skip button. Zou het niet mogelijk zijn een keuze te laten of je het route punt wil overslaan of verwijderen uit de route.
          Vb: ik wens een bestaande route te rijden en voor vertrek wens ik een lus af te snijden omdat het weer niet zo gunstig is. Als ik dat nu doe en ik skip in een route punt 7,8 en 9 dan wordt de route herberkent vanaf mijn huidige locatie. Dat wil ik niet want ik wens wel route punt 1,2,3,4,5 en 6 te passeren. Dikke proficiat aan het hele MRA team , jullie leveren bijna op maat en gebruiksvriendelijk. 👍
          • Alderweireld Rudi 0 Alderweireld Rudi 0
            @Alderweireld-Rudi-0 That’s a great suggestion that I’m sure will be considered. Thanks
              Will indeed consider it 🙂
                ASPK
                ASPK
                ASPK
                @UltraStar said in Next: Suggestion - Skip button on Navigation front page:
                As UltraStar writes, I also use many waypoints. It is irrelevant that the APP gives not only visual information but also voice information. Giving information on the arrival of the stage points (hard points) would be much more useful and pleasant.
                UltraStar 1 Reply Last reply
                • ASPK ASPK
                  UltraStar
                  UltraStar
                  UltraStar
                  @Alain-Spronck I would also much appreciate that option. 🙂
                  Stanisław 1 Reply Last reply
                    Stanisław
                    Stanisław
                    Stanisław
                    @UltraStar Maybe easy way to go from navigation to route planner with current route to edit it somehow (deleting points, adding new, changing route type etc), and then starting navigating at new by one click would be good solution?
                    Staszek
                    • Stanisław Stanisław
                      UltraStar
                      UltraStar
                      UltraStar
                      @Stanisław Actually, I have tried to do that on one of my rides. 🙂 I got stuck somewhere bypassing the WPs, and I was trying to get to edit (in the middle of the ride) to alter the route. Well, it did not work (I thought it will be implemented in the beta 🙂 )
                      to do it I would have to delete all the WPs until my current location. I did not want to do that because I knew the route will be saved like that, and I will have to recreate the whole route again from the beginning later on.
                      I like the suggestion!
                        Hi @Tore-Teigene. Thank you for your comment.
                        The waypoint icon in the top right of the screen also acts as a skip button. If you touch it you can choose to skip that waypoint.
                        If you want to skip several waypoints, enlarge the map and a long press on your desired waypoint offers you the opportunity to start navigation from there.
                        I hope this helps and thanks for testing 👍
                        @Nick-Carthew that's a nice option. works great if you have to restart a navigation half way through the route.
                        Stanisław
                        Stanisław
                        Alderweireld Rudi 0
                        Alderweireld Rudi 0
                        Tore Teigene
                        Tore Teigene
                        ASPK
                        ASPK
                        UltraStar
                        UltraStar
                          101
                        • Route exporteren uit beta
                          Rob Veerman
                          Rob Veerman
                          79
                        • Startpunt wijzigen
                          199
                        • V6 - Track Navigation
                          BMcG
                          BMcG
                        • Add the last visited folder to "Routes and Tracklogs"
                          Thomas Schäfer
                          Thomas Schäfer
                          1.7k
