  4. Manuell placing of target
17 Posts 5 Posters 99 Views 1 Watching
  • Jörgenundefined Offline
    I can not place point of target.
    Sometimes I do not know the address, but only the place where it is.
    So I look on the map and place a waypoint as target.
    I would like to use this in Navigation Next as well.
    As quick use only. Without planning etc.
    • Jörgenundefined Jörgen
      @Jörgen Will definitely be added later! This is a feature I would also like very much myself so I'll add that in a near update 😏
        @Corjan-Meijerink You are so quick in reply. 👍
        I think you and your team did a great job already and with adding feature it will be THE navigation app.
        Well done.
          Well done.
          @Jörgen Thanks for your faith in the app! 🙂 It really makes me happy knowing that the Beta is going well.
          As I'm so curious about your opinions, I'm quite active today 😉
          Stanisławundefined 1 Reply Last reply
            Stanisławundefined Offline
            Stanisław
            @Corjan-Meijerink Thank you for the beta, seems very good! Is it possible to start navigation directly, not from planned route, and put there destination addresse by hand or MRA planner is needed in all cases?
            Staszek
            • Stanisławundefined Stanisław
              @Stanisław You don't need to create a route 🙂
              If you search for an address using the search bar (top right magnifying glass on the map screen as shown when the app boots), simply select the destination and you can generate a route to the selected destination.
              When generating a route, make sure the right "tab" selected. The other one stays within the Mobile app and doesn't use Navigation Next.
              Stanisławundefined Bouke Entundefined 3 Replies Last reply
                Stanisław
                @Corjan-Meijerink Very simple - thanks!
                Staszek
                  Bouke Entundefined Offline
                  @Corjan-Meijerink is there a way when you generate a trip to select the road type. now it looks like it take fast and highway. will there be options like no highway, no boat, etc.
                  Bouke
                  • Bouke Entundefined Bouke Ent
                    Bouke
                    Nick Carthewundefined Offline
                    @Bouke-Ent Choose how twisty the road is by clicking on one of the options at the bottom.
                    Bouke Entundefined 1 Reply Last reply
                      @Nick-Carthew that is in mobile, left tab. i mean in next, right tab. then there is only 1 option and that is generate.
                      Bouke
                        Bouke
                        @Bouke-Ent Right tab should give you 3 route options.
                          @Corjan-Meijerink said in Manuell placing of target:
                          this i did now test and it seem te work well. even city, street number or street, number, city all work and also adres in other country.
                          bouke
                            @Nick-Carthew said in Manuell placing of target:
                            that is not what i mean. options you can not select like no highway, no ferry, no toll road, etc before generate. you get a few alternatieves and that is nice.
                            Bouke
                              Bouke
                              @Bouke-Ent Those options might come in an update when beta testing is over.
                              You have to remember that this is an early beta release of MRA Navigation Next and it is not the finished product.
                              • Bouke Entundefined Offline
                                when you select a place that is out of calculation limit, let say i select new york or sardine, then you do not get a message destination can not be calculated. result i get only the map with my location. when i select london from NL i get a highway route via traintunnel.
                                  that is why i am testing it. maybe corjan says yes that is for next release.
                                  Bouke
                                    @Bouke-Ent @Nick-Carthew This is something developed in a later stage! For now the Navigation route is simply the fasted one. The alternatives shown (max total of 3) are variants of the fastest route, similar to Google Maps A-B routing.
                                    Generating alternative routes with HERE is quite complex with regards to curviness. That’s why segments also aren’t working yet on the website for HERE.
                                    On a sidenote, please try to respect the thread topic. Now it becomes harder to find this discussion 😉
                                    • MyRoute-app communityundefined MyRoute-app community moved this topic from [Beta] The MyRoute-app on
                                    • Corjan Meijerinkundefined Corjan Meijerink referenced this topic on
                                    Bouke Entundefined
                                    Stanisławundefined
                                    Stanisław
                                      Thomas Neumeyerundefined
                                      Thomas Neumeyer
                                      4.3k
                                    • No altitude on Android Auto screen
                                      Léon Hassingundefined
                                      Léon Hassing
                                    • hoe/waar kan ik zien of MRA de laatste update heeft?
                                      olaf Scherpenisseundefined
                                      olaf Scherpenisse
                                    • How to find hotels in the desktop app?
                                      Peter Zehentreiterundefined
                                    • volume loopt terug
                                      Bart De Medtsundefined
                                    • Altitude does not match
                                      131
                                    • Update 5.1.0
                                      RetiredWingManundefined
                                    • Vreemde BUG in de bèta versie én de gewone versie
                                      Bart 9a 0undefined
                                      Bart 9a 0
