  4. How to start navigation in the Beta?
android
13 Posts 8 Posters 142 Views
  • Meirion Towellundefined Offline
    Meirion Towell
    Ok, maybe I'm stupid / not enough coffee yet, but how do I actually navigate with the beta? If I open a route from my library I don't see any option to navigate. Just start tracklog
    Christopher M Kellyundefined 1 Reply Last reply
    • MyRoute-app communityundefined Offline
      Administrator
      @Meirion-Towell just to check really quick: did you follow the instructions to get either the Android or IOS Beta?
      Hans Kremersundefined Meirion Towellundefined 2 Replies Last reply
      • MyRoute-app communityundefined MyRoute-app community
        Hans Kremersundefined Offline
        Hans Kremers
        @Timo-Martosatiman-MRA
        FYI, this might be related:
        I signed up for the Android beta according to the guidelines.
        I uninstalled MyRoute-App and re-installed it from the play store. At this point the app in the play store is called: 'MyRoute-app Mobile (Beta)'
        I do no see any option to start Navigation.
        The version display in the app is 3.3.3 - 138
          Meirion Towell
          @Timo-Martosatiman-MRA I did I have the beta installed. Got the update after I signed up and the play store shows me the beta version installed
          • Hans Kremersundefined Hans Kremers
            Hans Kremers
            @Hans-Kremers Sorry, that was a typo, the version is 3.2.3 138
              Meirion Towell
              @Hans-Kremers I think this is still the previous beta version, dated 23 November? Think we have to wait for the play store to offer us an updated beta
              • Meirion Towellundefined Meirion Towell
                Christopher M Kellyundefined Offline
                Christopher M Kelly
                @Meirion-Towell having selected the route instead of tapping the 'Open Route' button tap the triangle button on the right (iOS)
                I ride for work, I work to ride
                Meirion Towellundefined 1 Reply Last reply
                • Christopher M Kellyundefined Christopher M Kelly
                  Meirion Towell
                  @Christopher-M-Kelly the triangle button for me just opens the route animation
                    Thanks for responding here. To clear things up: the app on iOS and Android are the same but enrolling in the test process is not the same at all. The iOS users are able to use TestFlight (separate from the App Store) but for all Android users the test version replaces the non-test version from the Play Store.
                    The Beta version is 3.2.4 (143) for all platforms.
                    Therefore, if you enrolled in the Android test program please do give Google some time to process this. Once you signed up here: https://play.google.com/apps/testing/com.cloudmax.myrouteapp you should have seen a confirmation message and a message stating: "Note: it can take a while for you to receive the update".
                    Please do give it some time to be processed 😃
                      Meirion Towell
                      @Corjan-Meijerink thanks for the version number information. Bit confusing when Google gives you a beta version this morning but it's the older one 😉. I'll wait for 3.2.4.
                      Maybe lock / close this thread as it's not relevant now?
                      Robert Laudensackundefined 1 Reply Last reply
                        Christopher M Kelly
                        @Meirion-Towell mine has four buttons in order from left to right; edit, download, animate and navigate. The navigation button is a vertical white triangle
                          Robert Laudensackundefined Offline
                          Robert Laudensack
                          @Meirion-Towell looks like I have the same issue. I just updated the app and in the Playstore it says Beta, but on the App itself is indicates 3.2.3 -138..... I'd expect to see the "word" beta somewhere with the version number - I'll look into it this evening again.
                          for the record I am using a Samsung S20FE registered in Switzerland
                            I'm going to lock this thread to prevent further confusion.
                            Issue
                            Android Play Store not showing actual Beta version (3.2.4 - v143)
                            Possible solution
                            Force the Play Store to check availability again:
                            • Navigate to: Phone settings > Apps > Google Play Store
                            • Force quit the app
                            • Click: Storage
                            • Click: empty cache
                            Actual solution
                            Please wait a bit longer for Google to process your access to the test version
                            If the issue still persists after 48 hours, do reach out.
                            • Corjan Meijerinkundefined Corjan Meijerink locked this topic on
                            • MyRoute-app communityundefined MyRoute-app community moved this topic from [Beta] The MyRoute-app on
                            Robert Laudensack
                            Hans Kremers
                            Meirion Towell
                            Christopher M Kelly
                            • I don't need AA to run the app on a phone, right?
                              Peter Zehentreiterundefined
                              293
                            • WAYPOINT Announcements
                              2.1k
                            • Myroute app no se instala en Google Pixel 9 Pro con Android 16
                            • iPad - Changing Text for an Waypoint closes the Waypoints list.
                            • using GPS coordinates for planning not always correct
                              Guztundefined
                              Guzt
                            • Does waypoint have to be on Route Line?
                              Guztundefined
                              Guzt
                            • Anyone with CPMC B6?
