  4. Suggestion: routing options in planner transfer to Navigation Next
suggestionnavigation nextplannerrouting optionsinteraction
24 Posts 5 Posters 170 Views 1 Watching
    @Steve-Lynch I think that only applies to a limited number of Garmin devices. The current MRA Navigation doesn't use the track at all, so obviously it uses and shows the waypoints.
    @Con-Hennekens I'm not sure. When navigating using a track, there is no need to skip anything, you can just drive to the closest location on the track if you ever need/want to leave it for some reason. In the scenario I'm envisioning, the waypoints are only used for additional information, not navigation, and a such there is no need to skip them.
    @Herko-ter-Horst said in Suggestion: routing options in planner transfer to Navigation Next:
    If there is no next waypoint (like on a track) there is no point to guide you back to after leaving the route. The need is for sure there, when you take a wrong exit, or are confronted with a detour for roadwork or anything. That need is NOT there if you prefer to drive back to the route on sight. I used to do that too when still using the Zumo. But it is not ideal and only done because the system cannot lead you back on track (pun intended) when navigating a track.
    But I must also admit that navigating routes as a track with the addition of using waypoints, their info, and the possibility of using them to get back on track sounds like a decent method of navigating. Perhaps a bit complex to code though, I don't know.
      @Con-Hennekens said in Suggestion: routing options in planner transfer to Navigation Next:
      Of course there is, it's just not a fixed, named point, but you can always calculate a route to the nearest location on a track. This location changes dynamically based on the "detour" I am on. So, if I've just deviated from the track, the nearest location on the track is where I left the track. When I'm a bit further along on my deviation, the nearest location on the track will shift accordingly. The app can then calculate a route back to the track at any time.
      As an example, let's say I've planned a route through the center of a village (the green track). On the day, there is a festival/market/whatever blocking the road through the center and instead there is a signposted deviation (red). At any point along this deviation, the possibility exists to calculate a route back to the original track. Two such options are shown in blue.
      There is no need to skip waypoints at all in this scenario.
        ...you can always calculate a route to the nearest location on a track. This location changes dynamically based on the "detour" I am on. So, if I've just deviated from the track, the nearest location on the track is where I left the track. When I'm a bit further along on my deviation, the nearest location on the track will shift accordingly.
        Sounds to good to be true, so I am not really convinced (yet). My fear if this is implemented is that the calculated detour will always guide you back into mess that is the cause of the detour to begin with while you usually want to end up ahead of it. Maybe it could work if you use a "not quite as near location" like 500 mtrs ahead of the nearest point on the track as the goal of the detour.
          @Con-Hennekens You are correct that going back to the track "too soon" could be an issue. Of course, this depends on the reason for the deviation. If this is indeed because the road ahead is blocked, you'll want to make sure you don't go back too early (in my example above, the dark blue line would most likely be too early, however the light blue line further along the deviation could work just fine). It would be awesome if the app could help with that, but this would also depend on how much information is available.
          My current navigation solution does 2 things for me:
          1. if there is a known issue on the track I'm planning to drive that's known ahead of time, such as a closed road, it will automatically create a detour around it, while staying on the track for as long as possible and going back to the track as soon as possible.
          2. If I deviate from the track myself or the issue is not known in advance/available to the app, it will dynamically create a route back to the track from where I am on my deviation. I'll have to judge myself, if the route it provides makes sense (it does show the route on screen of course), based on the reason I decided to deviate.
          • Steve Lynch
            Steve Lynch
            Steve Lynch
            #19
            Lots of talk about “Tracks” in this thread.
            Maybe its just a language thing, but hasn’t it already been confirmed that MRA Next will be based on the Here map using Via and Shaping Points with GPX1.1 or GPX1.2?
            Herko ter Horst Drabslab MotoCon 3 Replies Last reply
            • Steve Lynch Steve Lynch
              #20
              @Steve-Lynch I think the use of the Here map has been confirmed by the recent video. I'm not sure the other stuff has been confirmed. If so, I've certainly missed that. It would be a real shame in my opinion, if there is no option to navigate using a track/pre-calculated route (although it does seem likely there will only be navigation based on way points at the moment).
                @Steve-Lynch said in Suggestion: routing options in planner transfer to Navigation Next:
                I guess that Next, in combination with the routeplanner, will enable options that cannot be translated to gpx 1.1 or 12.2
                This is irrelevant as long as you stay in the MRA universe but will be annoying when you move to a less performant platform like a GPS device from Garmin or TomTom where you can only import GPX files..
                Although this is only a guess, MRA evolution should not be hampered by the limitations of other devices.
                  I really don't know. I don't believe I have read that anywhere. The released example looks like Here, but I do not see why that would dismiss the use of tracks. Garmin does that too...
                  @Drabslab said in Suggestion: routing options in planner transfer to Navigation Next:
                  I agree. So much more is possible with a ecosystem that involves the planner as well as the navigator! At the same time the dedicated device users most not be forgotten of course. MRA is still a plan and share platform.
                    Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    @Con-Hennekens @Drabslab
                    Sorry I had a brain freeze mentioning GPX1.1 & GPX1.2 in connection with Navigation..
                    obviously they are irrelevant for the current MRA Navigation and MRA Navigation Next.
                    Drabslab 1 Reply Last reply
                      That is good if it does not last for too long.
                      If nothing else, it proves you have a brain 🙂 🙂 🙂
                      • MyRoute-app community MyRoute-app community moved this topic from [App-Beta] The MyRoute-app on
                      Steve Lynch
                      Steve Lynch
                      • Log in
                        Rod Sydenham
                        Rod Sydenham
                        38
                        394
                      • Restriction on scenic length?
                        Jeroen ekkel c
                        Jeroen ekkel c
                        Andy Beviere
                        Andy Beviere
                        1.7k
                      • AI pricing is too high
                      • Library Structure
                        John Matthews 0
                        John Matthews 0
                        Juudje39
                        Juudje39
                      • Allow the last entered point to be set as a via point
